FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 10 of 36
Posted Jun 17, 2010 · 02:18 UTC#226
i downloaded the bluetooth update(which is the same version my avic says i have) and put it on a blank sd card(the same one i used for the fx3 firmware update) and when i put it in and push to do the software update it says "no bluetooth software found, please copy to sd/usb to continue"! omg! my wife has a newer LG phone and the avic doesn't find hers either. i have done all the obvious and this is just annoying now :twisted: i will try again tomorrow, if anyone has any other ideas please post them and i will try tomorrow. thanks guys
I don't see how the FX3.1 FW has anything to do with the Bluetooth though ...
Curious!
Posted Jun 17, 2010 · 08:13 UTC#227
Hey guys,
does your menu etc now look like this one in the video after the update or do they still have that 2.0 MSN Messenger style?
http://www.youtube.com/watch?v=7tKH3C_q ... re=related
Thanks for all your work Retell, I was intimidated by simply removing keybeeps and updating from 2.0 to 2.0000008 :) Your single file seems to do everything I've wanted but have been afraid to do after reading about people having random issues. I to have an F90BT, so I'm assuming that I won't have any of the mild issues that others have been having on this thread while using units other than the F90BT. I had a question though...are the icon, map changes, etc in the video above part of this mod? If not, I don't mind, I'd just be happier with a faster reacting unit...this thing is TERRIBLY slow to react to input, has been since day one.
Seriously, once again...thanks for all your work.
Posted Jun 17, 2010 · 11:06 UTC#228
Curious!
It doesn't..
Posted Jun 17, 2010 · 11:07 UTC#229
Curious!
It doesn't, really..
Mine didn't require re-pairing with the phone after the update..
Posted Jun 17, 2010 · 23:00 UTC#230
Hey guys,
UPDATE: Thanks again for your work Retell...this worked like a champ. After the first reset my WSU startup screen was still there, booted up just like normal (slow but oh well) and then went straight to setting up language, voice, etc. So far, these are my pluses and minuses
PLUSES:
-Definately faster key input
-Key beeps can be shutoff via normal menu options instead of changing the PG*.wav files in testmode
-Larger and easier to read clock display...I could never read the small one
-I like the N arrow option added into the 2D, 3D options while viewing the map
-Seems we do have that option where we can do birdseye and change the angle of the view, quite cool!
MINUSES:
-Only two options for the windows in the bottom left corner, I like it showing 3 options better....MPH, distance to destination and time to destination
-I started playing a movie from SD and/or DVD and I still have to hit ok
before the video shows
-After the SD movie played for about 5 minuts, it hung up on itself and forced a reset...that's the first time that's ever happened to me with this stero. It started up again and had the Pioneer splash screen insteead of my WSU ones. Once I went into the options menu, all the splash screens I've made have been erased. Thanksfully I had them backed up on my computer.
-While watching SD only, I still have the issue where the volume will go shooting wildy up or down when a single touch is made to the steering wheel stereo controls. Im guessing it has something to do with the slower reaction time while watchin SD movies, so a single input gets multiplied until the stereo figures out that I've stopped pressing the button. This never happens on the radio or DVD.
QUESTIONS:
-I've asked this before, but is there ever going to be a possibility of adding a CPU clocker to make the unit run smoother in situations like my volume issue?
What are the odds of a hack to make the brightness go higher than 10?
Posted Jun 19, 2010 · 05:06 UTC#231
thanks for the link
did it tonite including backing up the original files in less than an hour
anyway, how come in 3d mode, the street names no longer show now? it used to show proximity street names..
Posted Jun 19, 2010 · 17:45 UTC#232
thanks for the link
Need to be @ 500 ft or less for street names.
At 300 and closer, they're there all the time. At 500, they show up as you get close..
Posted Jun 20, 2010 · 23:41 UTC#233
Thanks.. I guess by default its set at 500 ft. I didn't know we could zoom in 3d mnode LOL
Posted Jun 21, 2010 · 04:22 UTC#234
Ok i installed this and it worked awesome. Though i do have a couple issues. I dont know if I did something wrong, some files got corrupted, didnt install right or it was intentional.
Is there no longer a phone interface when receiving a call? The volume is way to loud and the only way I can adjust it is to turn down the main volume under the main interface. And I cant hang up the phone without actually getting the phone out of it's case which can be a hassle when driving. Also the audio no longer mute when making a call, which is easy enough to deal with but it was nice to have it do it auto.
This is only when making outbound calls, as I havent had a chance to test incoming calls yet. I'll do that tomorrow if I remember to bring my work phone home with me.
So i made some incoming calls and it mutes the music fine and the new box pops up and pressing the hang up key works but that box never goes away so the whole system is locked out. the music wont come back and cant change any screens. then you have to turn off the car to get it to come back on.
but i'm happy to report that I havent had 1 issue with the Ipod connecting :mrgreen:
Is there a mod I can install to fix this or if I purchase the official upgrade will it install right over this or will i need to revert back to an earlier version?
thanks in advance for any help.
Posted Jun 21, 2010 · 23:13 UTC#235
hello.. i have a problem please someone give me a tip
i make all steps following the guide.. everything install perfect but when i reset after copyng everythin g to my flash disk it goes to the language part but when i finish that it goes to the menu and the icon for music ipod etc dont work and when i press reset again freezes in the pioneer logo
i'm lost i did everything well tried this and the 3.0 firmware but it's the same
i have av avic x910bt US model.. that had the system startup in progress problem (i dont know if that has anything to do) and it came with the 3.02 firmware when i bought it
thanks and cya
Posted Jun 23, 2010 · 17:36 UTC#236
Hi guys..
I followed the instructions,Wince Upgrade > Update SD Format, and now instead of having 2gb in My Flash Drive.. it shrunk down to 880mb, so not enough space for the files.. anyone know how to fix this?
Help plz.. thanks in advance
Posted Jun 24, 2010 · 07:02 UTC#237
Hi guys..
Dont worry bout it guys... i Install the FX3.1 and Install and replace the maps with 34by151 Australian r17 Maps..
And It was under 880mb... And i got it working great!! except for the navi voice..
Thanks everyone
Posted Jun 27, 2010 · 04:17 UTC#238
Will this work on a 500 ?
Posted Jun 27, 2010 · 06:10 UTC#239
So went through the whole process - everything has been fine but, when I hit reset for 5 seconds to reboot, got an error message : "Fatal Error LoadLanguage Not found". Now what?
Posted Jun 27, 2010 · 19:09 UTC#240
Now I can't even downgrade to a previous version of firmware. Unit gets stuck at the "Initialization error: LoadLanguage not found". Getting a little desperate here - should I go buy the firmware upgrade? Erase all of the stuff on the Flash disk? Boot into Testmode to reset?
Open to suggestions but I need to get this fixed one way or another.
ty
Posted Jun 30, 2010 · 00:34 UTC#241
Sorry to say to everyone having issues, but I did this the first, second, and third time with NO issues. I literally followed the instructions EXACTLY as they were listed. The first time was even WHILE I was driving. The only reason I did it more than once is because I didn't realize I could go back into test mode to add the modifications I found under other topics. So I modified and reflashed....twice. Now I know better
Either way, its easy. As they say, RTFM!
/rant
On a side note, I agree with whoever said something about the 2 windows on the bottom left. The original image that I had on the HU had 3. This 3.1 from Retell only gives 2 =/. Other than that, I have no complaints!
Posted Jul 01, 2010 · 02:32 UTC#242
I'm still quite happy with it, I just wish it had the things I mentioned. I was curious though...will it ever be possible to get rid of ALL of the nag screens?
Posted Jul 01, 2010 · 02:37 UTC#243
The Video warning is the one that springs to mind immediately. As mentioned before, the AV section of the F series isn't open, like the NAV functions, so with this being a dying community as far as F series mods, without new blood coming into it or Pioneer opening it further, this is likely never going to be removed..
Posted Jul 01, 2010 · 03:53 UTC#244
Secret ingredient here? (i think). Don't do this stuff on a Mac. I believe that the Mac file format, even the MS-Dos Fat32 variant that you can do from Disk Copy is just different enough that it corrupts small parts of the files being copied onto it. So the install works but there are sub system problems due to key files being slightly corrupted. The result is a system that sort of, kind of works sometimes.
Once I went to a PC, formatted the 2gb Flash disk (long format), followed the steps, it worked like a charm. Very, very happy with the Avic. The only thing I haven't figured out is how to transfer my phonebook from my Blackberry 9630 Tour but I can live without that for now.
Posted Jul 01, 2010 · 10:35 UTC#245
Didn't have a problem manipulating any of the files on a mac..
Posted Jul 01, 2010 · 20:18 UTC#246
Ok so this looks very good. I currently own a F900BT and have a few questions about the software before I attempt to use it. At the moment I am running 3.0 and noticed that the unit requires a windows ce firmware update to make this work, much the same as 2.0 to 3.0. Is there any way to revert back to the older firmware incase i decide I want to stick with the original software?
Also are maps from 3.0 compatible with 3.1? I have comprehensive australian maps (better than the stock iGo) for 3.0 and am not really sure where I would find these for the 3.1 update and lastly what is out there in the way of mods? Im pretty happy with the functionality of my F900 through better boot times and nav software and don't really want togo backwards by updating to 3.1
Posted Jul 01, 2010 · 21:01 UTC#247
This is 3.0, with the features/mods listed in the first post, integrated. Nothing different as far as the base..
Posted Jul 02, 2010 · 07:55 UTC#248
worked great on my F700BT... will be seeding this one for a while, thanks!
Posted Jul 02, 2010 · 19:16 UTC#249
Oh well, at least it's one less screen hit I've got to make now.
Posted Jul 05, 2010 · 16:29 UTC#250
Working Perfectly (for the moment) in my f700bt
Page 10 of 36
