FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 21 of 36
Posted Nov 24, 2010 · 17:07 UTC#501
OK so i see a lot of people getting frustrated with not being able to download this fast so what i did is found every torrnt site that people have re posted this one and im putting them here for everyone for quick download. all you have to do is go to each site and download the torrent from each site it will tell you u already are downloading this then ask if you want to add the trackers to the torrent click yes( this is what pops up for u torrent anyways)any questions feal fre to im me or email me.
http://www.torrentv.org/download/[email protected]
here you go enjoy
:D :D :D :D : 8-) 8-) 8-) 8-)
Posted Nov 24, 2010 · 18:36 UTC#502
does this work for the x920bt
Posted Nov 25, 2010 · 02:23 UTC#503
No! Sorry but the X920bt is currently not moddable! :mrgreen:
X920BT use a difference OS than Windows CE.
Posted Nov 25, 2010 · 15:55 UTC#504
SO i figured... "this worked for everyone else, why back up my system?" Big mistake. I downloaded the torrent to 100%. Copied the files to a 4gb flash drive. updated win CE (format). Copied all files from storage disk to my flash drive. And hit the reset button and all I see is "Caution: Image may be reversed." Any Ideas guys? Thanks.
Posted Nov 25, 2010 · 18:52 UTC#505
Okay, so my headunit works, tinkered while i was driving. I got rid of the screen after hitting the menu and map button at the same time, but that screen comes up everytime i start the car. Any Ideas? I'm running an f700bt.
Posted Nov 25, 2010 · 20:19 UTC#506
The "false" warning message is from the AVIC because it thinks that your back-up camera is switched to ON at startup. Do you have a rear camera mounted?
Edited Nov 25, 2010 by Chuck88
Posted Nov 26, 2010 · 02:47 UTC#507
Thank you so much, that was just what was wrong with it. I switched it off and all is good with the world. I Appreciate it. Thank you and Happy Thanksgiving!
Posted Nov 26, 2010 · 03:36 UTC#508
You're most welcome and I'm glad that I can be helpful :rolleyes: .
Posted Nov 26, 2010 · 06:49 UTC#509
I just hooked up my backup camera and I noticed the same warning message. You have to wait untill the unit fully boots up then go to main menu and press audio source and then choose radio, ipod etc and them it goes to what you have choosen. This is very annoying. Is the only way to avoid this, is to turn off the camera after you use it and then turn it back on when you need it again. Am i missing something in the settings or how it is wired.
I have a x710 and the camera is wired to the backup lights so it only comes on when you put it in reverse but the message stays on (caution images may be reversed). Any body got any ideas how to work around this as it seems like a very clunky operation.
Posted Nov 26, 2010 · 15:35 UTC#510
Check in your AVIC audio/video setup for the polarity of your camera, you might have to reverse it.
Posted Nov 26, 2010 · 20:28 UTC#511
Hi, can I use FX3.1 for EU units too ? I think yes, but not sure..
thanks
Posted Nov 29, 2010 · 19:14 UTC#512
ok so im looking for a little help I am USAF stationed in Germany and im having a hell of a time converting over to EU maps for my the AVIC F 900bt I know this thread is for the complete fx3.1 but bear with me I've canned many parts from this DL and im seeding it aswell. anyway my problem is as follows... after deleting contents of the MAP POI and BUILDING folders on my HU (made backups of everything first) and replacing them with maps,poi, and building from an IGO8 torrent (filenames look like this Germany8_2008.01_080215.fbl) I just cant seem to get it all to work right. Im using the ezrider from this fx3.1 and the generic licence file, and even replaced the basemap.fbl that i deleted when clearing my map file the first time, all from this post shouldent it all be working properly? im getting the looping problem i start the truck everything boots fine untile system startup in progress screen, about 8 seconds later... bam! lets do it all over again! should i maybe try doing this fx3.1 install completely insted of just canning parts from it... would the new maps automatically work with a simple cut and past after this fx3.1 upgrade? maybe someone out there can tell me what im doing wrong or where my modding abilities went screwy. (ok quick outline because i know i jump around alot when explaining things deleted all contents of MAP POI BUILDING> replaced stock ez rider with this one> added generic licence from this post> added basemap file from this post to MAP folder on HU > added all the new maps, poi, and building from IGO torrent= a very frustrated airman)
Posted Nov 30, 2010 · 16:14 UTC#513
Can someone seed this please. I recently updated using the CSND-200FM on my F90BT and it screwed up playing MP3's from my SD card (The feature I use the most). I wanted to try this to see if it fixes it.
Posted Dec 03, 2010 · 05:30 UTC#514
it would be awesome if someone would log on and seed this file for me, I would really appreciate it, thanks.
Posted Dec 04, 2010 · 11:10 UTC#515
bump
Posted Dec 04, 2010 · 16:56 UTC#516
ok so im trying to do the fx3.1 upgrade and i get stuck with a blue screen saying read progress 100% at the bottom middle any thoughts?
Posted Dec 04, 2010 · 18:24 UTC#517
ok so i figured out all my woes YAYA!!! I just went ahead and did the full fx3 upgrade per instructions (had a bit of a hang up after step 4 got stuck at the blue screen *you should emphasize the need to format the SD card to FAT32)then deleted enough US maps to make room for germany maps and poi and buildings... all is well so far. next step is to remove the rest of the US maps (keeping a backup on my PC of course) and replace them with current European maps. ill keep seeding this FX3 for all im normally on around lunchtime for you USA residents but ill leave my laptop on for the weekend and into next week for you so get it while you can electricity is expensive and internet is slow over here HAHA laters.
Posted Dec 04, 2010 · 23:42 UTC#518
hi, im downloading the fx3.1 right now, but my unit already has 3.020100 and some 2.0xxxx version of the maps.
is it ok to install the update to get the maps and the other hacks even if i already have the updated firmware.
also is there an easy way to save what i have already so i dont loose it if the firmware update fails?
thanks for your help.
Posted Dec 05, 2010 · 03:27 UTC#519
woohoo even faster than before. the windows ce screen is pretty cool, i wonder if you could turn a f90bt into a car computer. a lot of work tho,but probably possible, but im happy with it now with the upgrade. thanks again.
Posted Dec 05, 2010 · 04:22 UTC#520
Heck while I'm on the subject of windows ce. I might try to figure a way to dual boot this thing. I notice that when the flash drive is in while I turn on the unit it goes into wimped ce. I'm guessing the fash drive has a file like a boot disk on it?
Maybe I could keep a sdhc card for my windows ce booting and load programs on it. I figure the internal memory is somewhat limited. I would love to fine a windows ce media player that will play flac audio. Maybe I could even find a way to teather my iPhone via Bluetooth to windows ce and pickup internet with a windows ce browser. I think there are a lot of options here.
Has anyone actually tried any of these things. I checked out control panel on there it had some stuff but I didn't mess with it
Posted Dec 05, 2010 · 05:24 UTC#521
First and foremost, I'd like to thank the OP for the contribution. Greatest "mod" ever.
Today's the first day I'm running the new firmware. I have a couple issues with the update. After reading 35+ pages of this thread, I see many also encounters these.
1. Illumination color can't be set and it returns to "random" every time I start car.
2. Screen brightness can't be set and always return to "10" every time I start the car.
3. Voice is always English-Jason after I restart the car.
4. No street names in 3-D mode unless it's zoomed in.
Anyone with solutions to these problems? Quite minor, but just wondering.
Posted Dec 05, 2010 · 05:35 UTC#522
I used this because my f700bt kept shuting of after the splash screen. But the first time i installed it it didn't work. So I tried again, and again and ... well you get the picture.
So I finally deleted the all the contents of the "my flash drive" on the unit then started over...Works Great!
Thanks, Retell. You're awesome!
Posted Dec 05, 2010 · 05:45 UTC#523
I just installed on my F700bt and have been able to change illum. color and brightness. Saves my changes even after restart. I assume (you know how dangerous that can be) i can change voice and street names as well. I did delete everything in my "my flash drive" on the unit though. Don't know if that matters, but it worked for me.
Posted Dec 05, 2010 · 06:01 UTC#524
hmm so far mine has kept the settings. are you sure your main power wire stays on when you turn the ign off?
Posted Dec 05, 2010 · 12:34 UTC#525
I've been using FX for the last two months on my 700BT, everything you mentioned also is working fine on mine. I only have to reset the illumination, etc; if I hit the reset button.
The on thing I wish I could figure out though.... the mute/attenuate option for the navi voiceover is always greyed out and stuck on MUTE. I really want it to only lower the music volume for TTS, not mute it totally. Anyone have ideas on that?
Edited Dec 05, 2010 by slightlyevolved
Page 21 of 36
