Retell, you are the one that we all should thank! Even if I didn't personally use your files, but you are helping so many others.
One question to the community: what capacities of USB and SD have people tried? I want to get a 32GB SD or USB, but want to know what people have tried.
In Pioneer's manual, it says that the MAX supported for both SD and USB key is 8 GB, but I already connected a 16 GB USB key and it mostly works, but with thing that I don't understand, like the folders order is erradic, if you scroll the folders forward or backward, you got different name etc.
Anyway, I recommend using only MAX 8GB because beyond that, the AVIC will take enormous time each time you insert the Flash, since it has to search through all your folders to build the media files tree, and believe me, the speed sucks for that matter and you will be irritated very much ![]()
Worst of that, before the search if over, you can't hear anything or change anything in the unit, not even switching sources ... some time is up to 5 minutes of waiting
I have however noted that SD is faster then USB.
i updated my avic f900bt with this version.
everything is working fine EXCEPT TTS. anyone the same problem?
F900BT here. It all went through just fine except now some of my options don't seem to save at random. It also (While playing from an SD card) very occasionally will hang and then reboot.
(I was on a hacked previous 3.01 or whatever it was before) and I didn't get the WinCE upgrade part as the blue screen didn't show up. It went immediately into Windows CE where I did the deleted the original files and replaced them with this.
The heck? Anyone know what I was doing wrong?
Rex could you please take a pick of your harness? I am going to attempt to add the wires for the video out.
You have a F90BT right? I have a F700BT and Pioneer's website says that our RCA assemblies are different:
F7xxxx --> http://parts.pioneerelectronics.com/par ... um=CDP1143
F9xxxx --> http://parts.pioneerelectronics.com/par ... um=CDP1091
I don't know if it would help you much, but I still can take pics if you want them. ![]()
I was able to see the files on windows from my SD card exactly, so I know they were there. I reset probably 1 minute after the files were copied...was that too short of a time period?
I finally broke down and called Pioneer customer support, and learned that my unit is under warranty still. So it's on a plane somewhere today from Kansas City to Long Beach, CA. I think there is more wrong with that unit than I know, hence the reason this upgrade would not work. Perhaps I'll try this again once my unit comes back working correctly...or I may just leave it alone and be happy with a functioning unit.
Thanks for the help.
I just hope that Pioneer will not invalidate your warranty because you are trying to hack the unit, and that unknown files to them are stored in your "My Flash Disk".
Did you make a cleanup before sending in Testmode?
I thought about this after I sent it in...One of the problems I'm having is that it does not save the files.
2fup and sgambino . Reformat your SD card as Fat32 filesystem and recopy the files the card and restart update process from the begining. That should fix everything
kj42598 I don't have a Sirius Tuner or any external tuner for that matter, for now all I can suggest to you is to reformat your SD and try it again like the 2 fellas above. Just to completely rule out an install error. I should have a sirius tuner soon that I can play with, If the 2nd time around install doesn't help just go back to regular 3.0 for now, do you have a copy?
I re-installed and when just running v3 without all this great mods, it still scrolls channels when the volume control is turned.
Somewhere i read that this v3 is not the same as the one from Pioneer. Who wrote or modified this one?
hi
does this work with the 910bt ?
sorry for the newbie question ![]()
thanks
hi
thanks
Yes! But please verify as you might already have an update to day firmware. If it say FW V 3.020x, where x is either 1 or 2, then it is up to date.
But it is the mod that i want to do ![]()
so you are sayiing if it is 1 or 2 i can mod the firmware?
hi
thanks
hi
thanks
NO!
If it is 1 or 2, then you are already up to date, so no need to update again. If you bought you X910BT recently, then it should already be up to date.
does anyone know if i flash this image over top of my current stock image on my x910bt with diaftia hybrid mod, will i lose that mod? if yes, can i simply just do the mod again? basically im just looking to get the updated maps, as my maps still say they are from 2008. also i heard that these new TA maps arent as details or as good as the older maps, because no highway signs or something. if anyone can confirm this, ill probably update the maps anyways, just cause to have newer maps.
just did this because I was having problems with my unit after i did the official 3.0 update. my unit was modded prior to my purchasing it and it was not liking the 3.0. everything seems to be working so far with this update. it kept failing the winceimage update from sd format, but i figured that was more because of the fact that i might already have this windows firmware loaded from the 3.0 update.
I just paired my phone and transferred contacts and am making my first call: WORKS (status prior: didnt work)
Put in my Talking Heads DVD: WORKS (status prior: works)
iPod: WORKS (status prior: didn't work)
branded poi: WORKS (status prior: none)
speed camera: WORKS (status prior: had it before the 3.0 mod, but not after)
The only thing i wasnt expecting was the debug mode on the system settings service information button. I was going to check if it updated and its got all kinds of stuff on it. (didnt fiddle)
overall it is working so much better than before, THANK YOU so much!!
OK I finally got it working on my F700bt US version.
BUT I have got following issues:
1. my unit can not detct any SD card ****BIG PROBLEM***** PLEASE HELP
*** I can boot my unit using SD card, but when unit is running in its normal state it can not detect SD card
I will appreciate if some one please shed some lights on the above problem
Thanks in advance
Regards
Shaz
Hey Guys!!!!
if any one of you knows why my unit is not detecting the SD card. I have formatted it with FAT32 put inside simple mp3 format audio files but still my unit can not detect the SD card.
ANY help Please !!1
Regards
Shaz
just reinstalled my 900 and used your mod works great thanks
That is what I said. If you have FW 3.0201 (USA) or FW 3.0202 (Europe), then you don't need the FW upgrade. You have just to download your favorite mods from this forum.
Good lucks.
*** Update ***
I downloaded the uTorrent client and have no issue downloading the torrent...my issue was with my old installation of bittorrent :/
I can't download the torrent for squat...I keep getting an error saying exceptions.OSError...any other way to get this awesomeness downloaded?
Just to confirm with you guys, I have a fully stock F90BT with the bypass installed with the wires grounded, if I install this, will it cause any compatibility problems?
it shouldnt. i have an f90bt with the hardware bypass installed and i have no issues
Ahh hi now i understand what you meant ![]()
but I iked this mod because it semed simple to install .. whereas finding the individual mods is confusing.
so you have recommended links that has just the mods ?
thankjs
i am refering to this mod :
http://www.avic411.com/forum/viewtopic. ... 51#p217463
will it work with 910bt
thanks
Good lucks.
Just wanted to tell you I just used your mod to upgrade my f700bt from 2.0 to current. What a great way to do it. So painless. All I added after was the compass button stop navigation and the no more red boxes mod. Now its perfect! Thanks for all your hard work and time you put into this. Made my life much easier! You did a great job spelling out the instructions. Thanks again!!
hello;
when i arrive to the update menu it ask me update wince sd/mmc or update wince sd/mmc (format).for make sure i must chose with (format)?
