Extra Pins for the Bypass Hack!
By quarky42 · Jul 05, 2010in Hacks/Mods💬 30 posts👁️ 11,308 views
Page 2 of 2
Posted Jun 26, 2011 · 19:00 UTC#26
I have a pin extractor at work that we use for DB9 and DB25 connectors. Any idea if that would work to release the pin from its holding place?
Kinda looks like this: pin extractor
I think the DB9/25 pins are larger. I had one too and it didn't help on my Z110. I ended up slicing open the nylon connector because I couldn't get mine to release.
Edited Jun 26, 2011 by RonS
Posted Apr 08, 2012 · 17:20 UTC#28
Looks like the minimum order from jameco is 30 now. Anyone have a couple laying around that they are willing to sell?
Posted Aug 14, 2012 · 22:34 UTC#29
I'm in the same situation with my z140. I ripped the mute wire out of the pin by mistake. i was able to get the rest of it out by slicing the plastic with a knife and working it out from there, but it's too screwed up to try to solder back on the wire. Will it mess up the unit if i just plug the rca back in until the new pins arrive in the mail?
Posted Sep 20, 2012 · 05:11 UTC#30
yes - I found that the power cable pins from old 3.5" floppy drive off of an old dead computer power supply works great and fits in the a/v harness pin holes perfectly
you dont have to tear up the connector
the trick is htere is a lift-up "bar" tab across the side of the connector. use a small screwdriver/pry tool to unlock/lift-up the bar at each end, and it will allow the pins to just slide out.
I fiddled with it for a while thinking they were back/front locking pins, til i realized there is that snap in bar on the side holding them in.
Edited Sep 20, 2012 by pionara
Page 2 of 2
