ohhh i liky!!!!!!
Abb's Chrome NAV Mod V3.25 - Aug 30th '10
Hmmm, green is beautiful too
BTW - My daughter gave birth to baby girl about two months ago. Mom and baby (grandpa too) are doing great. For this I am most thankful for.
Congratulations!
Congratulations!
Yeahhh!! Nice! Congratulations from Portugal!! ![]()
Abb, your mod is great and works well across the atlantic ocean!
I was just wondering if it would be possible to change the font (letters).. Can it be done easily? Thanks for your answears!
Congratulations!
I have changed the fonts like this.
Choose whichever font you want to use.
Rename the font to Tahoma and Tahomabd and copy to SD
Copy the new fonts to APL2/IGO from the SD card
Thanks! I'll try that later! ![]()
I have attempted to follow the directions to the letter. The second file, the one that says to put the contents in My flash disk folder I just copied and pasted into My flash disk. Now when I boot the 700 it first says "FFUIERROR: Parse Error [ expected] if I say ok to that it just goes to the Pioneer Sound.Vision.Soul splash screen and it says mainscreen load in the lower right corner and just sits there for a couple of minutes and then goes to my custom splash screen and just stays there till I turn it off. I have copied and pasted the files over twice with the same result. I have done several updates, but have not had any problems in the past. I could use some help here.
Thanks...Gerry
I have attempted to follow the directions to the letter. The second file, the one that says to put the contents in My flash disk folder I just copied and pasted into My flash disk. Now when I boot the 700 it first says "FFUIERROR: Parse Error [ expected] if I say ok to that it just goes to the Pioneer Sound.Vision.Soul splash screen and it says mainscreen load in the lower right corner and just sits there for a couple of minutes and then goes to my custom splash screen and just stays there till I turn it off. I have copied and pasted the files over twice with the same result. I have done several updates, but have not had any problems in the past. I could use some help here.Thanks...Gerry
Have you deleted the files in USER/USERDATA/IGO?SAVE before you installed the new ones?
I deleted the IGO folder after installing the new files in the first folder. Is there a new file to install in the IGO dir after deleting the old files. Do I delete the entire IGO file or just what is inside it?
Well, I restored it one more time and tried it again...it all seems to be working ok now...must have had a corrupted file as I reformatted the SD card, downloaded the update and reloaded it on the card. Thanks so much...
Glad you got it working.It drives you crazy when things go a little wrong............ ![]()
I live in Norway, is the UK version what i should get then?
Yup...when they go major wrong it is usually easy to find...it"s the little things that make you nuts.
I would say so, The major difference is the signs and the highway signs that are blue (european) instead of greenI live in Norway, is the UK version what i should get then?
Ok sounds like the UK version is the most suitable then.
Do i also need to install these?:
Abb's NEW GFX Folder
Abb's NEW Scheme's
Abb's NEW Scheme's
Only if you want my schemes with the skys that you see in the pictures. I would recommend it as it makes the mod look a lot better. They are not necessary for installation though. Remember that these files will take a lot of room, so you may have to clear out some maps that you do not use, I am not to sure though if that is the case with the european maps.
Ok i've installed the UK version but somehow nothing happens then i try to run Total commander, any solution to this?
You would have to install the appropriate applications in the appropriate folders. Found this in the first post:
8-- it has a new 'Application Menu' accessible in the Top Menu which shows the 'resource info' while navigating, gives you direct access to 'Total Commander' while navigating. Applications are in the 'V3.25.rar' file that must be installed for the apps to work
Done that, the Totalcommander is in this folder:
Myflashdisk\System
Myflashdisk\System
Did you delete the IGO folder in 'My Flash Disk\USER\UserData' ?
You did something wrong as I just downloaded it and it works fine, so there is something wrong with your installation.
Deleted the Igo folder yes
Ok, there is something wrong then with your installation. Redownloaded all my files and make sure that my 'System' folder resides in 'MyFlashDisk' alongside APL, APL2, etc.. Also make sure that you have the proper DATA.zip installed as well. My recommendation is to reinstall everything in it's proper location following the instructions. Just say 'yes' to overwrite.
Ok, this makes my third Mod I installed for my unit. The other Mods were like this one, it had directions. LOL. After deleting the other Mods, I installed this one. It came up with an error: "Cannot copy ""Sky.bmp"" error 50". I deleted all folders I installed, redownloaded this mod after formatting the SD disk, and installed it again. I received the same error. With that I can not change themes as they dont load. How can I fix this? Any help would be great, as this is the best MOD yet. Excellent Job!
[installation Instructions!
THIS MOD IS FOR FIRMWARE V3 ONLY!!!
quote]
Question: Any special considerations for installing v3.25 on F900 unit with CNSD-200FM upgrade (see APL # below)? Thanks.
APL-3.0201000 to 4.0001000
DATA-2.000100 to 3.00000
MAP-03.00000
CFIMAGE-6.2214 to 6.2280
MAP-03.00000
It should work as it is still Igo 8.3. Backup your Present files just in case, but I can't see there being a problem. The only problem is if you go and use my mod on firmware V2, as it is still formatted for Igo 8.0 maps
