Thanks Abb, made the changes this morning and the system looks great. I've been running it most of the day and it looks like I didn't screw anything up with the install. I had a couple of comments that you might like for your next update (note you made a great system, and these are just my thoughts)
First I noted that when I turned off the "your speed" sign from the display, the "MPH" label remains on the screen. I also noticed that, as with the Diaftia mods, during navigation I normally keep voice directions turned off, however after ending a phone call, the voice directions are back on.
I like having the elevation display on the screen, however, it is located in an odd spot. Just a thought, could this be moved up so that it located directly under the compass? While displaying the house numbers on the screen is a great display, I normally only need them if I am trying to find a location or while navigating. Is it possible to change the option for displaying house numbers to "yes/no/while navigation"?
On the AV screens,the function button has a great graphic but you can't see it because of the text. I'm not sure the text is really needed. Is it possible to modify the top information screen? The channel text is small, and I would like a larger clock.
Anyway, I was very disappointed with the original Pioneer system, and your mod makes this look modern. Thanks, again
