I did read.... you say to remove the GFX folder... before you install the new one... BUT I DONT HAVE A GFX folder to remove.... the only GFX folder that I already have IS in the DATA ZIP when I go in it... not the apl2/igo folder...(the data.zip is in that folder though) dont know why you guys get so hostile... just asking.. thought I explained it clearly enough.. for now I just installed everything except for the GFX folder and the schemes and the Image.res.... It works fine... all is ok... 3dcars look nice... its like having a whole new AVIC... just would like to get the new schemes..
I don't think that we are hostile in any way, and please don't take it that way. Many people don't really read, instead they ask question, in your case, the image.res thing is explained so many times in so many places in this forum ...
If you are still searching, instructions for the new GFX folder is here (copied from post 1), but it is big though. If you don't have an existing folder, that is OK (nothing to delete):
NEW SCHEMES - Instructions
-Install my GFX folder (after it has been extracted) to 'MyFlashDisk/APL2/IGO' folder. Afterwards it should look like this:
'MyFlashDisk/APL2/IGO/GFX'
-Install my schemes into 'MyFlashDisk/APL2/IGO/CONTENT/SCHEMES' folder. Once it is installed, you should be able to open up the CONTENT folder and see all my schemes along with 'Pioneer_blue_day.zip' scheme
*YOU NEED MY GFX FOLDER FOR THE SCHEMES TO WORK
**If this is too complicated for you, DO NOT TRY THIS!
*To install the NEW GFX folder, delete the present one first and then add the new one! THIS IS A MUST!
Good lucks.
