Parking Brake Bypass w/AVIC U220
By justinv29 · Jul 28, 2010in Pioneer AVH Series💬 46 posts👁️ 40,181 views
Page 1 of 2
Posted Jul 28, 2010 · 19:40 UTC#1
Hi Everyone,
I just got the AVH-P4200 with the AVIC-U220 navigation add on. I wired up the head unit, used the relay bypass, and everything was working great, could view DVD and videos off an SD card. I then hooked up the U220, and now all it does is display the warning message locking out the video. I didn't have the u220 grounded through the relay so I thought that might be the problem, so I switched it, but still no go. Am I going to have to just wire it up to a switch to bypass the parking brake, or is there another way to go about this with a relay. TIA.
Posted Aug 13, 2010 · 05:03 UTC#2
I had this problem too. i just got the 5200 and the u220 and wired it up yesterday with the relay bypass and couldn't get video either. here is the solution i found:
before you turn the car on simply detach the detchable piec of the nav. turn the car power on and then reconnect the detachable piece. mine is in the glove box so i have easy access and its easy just pop it off, turn on the car, and pop it back on. makes it easy when u want video. then you wont have to rewire. i had video and navigation at the same time when i did this. hope it works for you.
Posted Sep 24, 2010 · 07:16 UTC#3
Anyone figured out a fix for this? I just got a avh 3200bt with the u220 nav attachment and I'd like to bypass it mainly to have full gps navigation.
Posted Sep 27, 2010 · 13:18 UTC#4
I heard that the u220 slows the boot up time of the head unit which nullifies the delay of the parking brake signal caused by the relay. If this is the case, would it be better just to add a switch to the wire (amp wire) triggering the relay? I guess the alternative is to forget the relay and connect the head unit's parking brake wire to the amp wire and put a switch in between. I've also read the possibility of using a timed relay instead. Thoughts/ Advice?
Does anyone know if the u220 have gyro's to further restrict accessing the full menu?
Posted Oct 27, 2010 · 18:04 UTC#5
try this. seems to work well w/ AVH models: www.avhbypass.com
Posted Oct 27, 2010 · 18:04 UTC#6
there's websites out there that sells the modules. I used www.avhbypass.com and it worked beautifully. I have AVH03200BT
Posted Oct 27, 2010 · 18:19 UTC#7
I built a home made relay and it works fine for the headunit (AVH 3200BT). I have access to all functions on the head unit without activating the parking brake. The bypass only partially works for the GPS module (U220). You don't have to activate the parking brake to use the navigation, But certain options become unaccessible when you go faster than 10 mph.
Posted Nov 12, 2010 · 20:47 UTC#8
maxzboy
so the relay from www.avhbypass.com works on your AVH03200BT headunit, what about the avic-u220 addon? does the gps work properly with that relay?
i have avhp3200dvd and tempting for an u220, i purchased a relay from ebay back then and i think it'll end up like 1st post.
Posted Nov 15, 2010 · 22:27 UTC#9
I only have the P3200BT and have not installed the Navi on it. Don't know if it'll work for the Navi as well. From wut I've researched, there's an accelerometer in the GPS which knows when the vehicle will go above 10mph, and deactivates certain functions for safety purposes. The accelerometer cannot be turned off via electronic signals. Im not sure how to solve this yet, and i've emailed the avhbypass.com people for help. hopefully they come back w/ an answer soon.
maxzboy
Posted Nov 17, 2010 · 05:50 UTC#10
I have the AVH-P4200DVD with the bypass relay in place. DVD works when vehicle is in motion. I just bought the AVIC-U220 and from what I am reading, if I hook up the Navi unit, I will lose my ability to play DVDs when moving. Has anyone found a solution to this yet? I do not care so much if I lose some features on the Navi system when going above 10mph. I contacted avhbypass.com and they said:
"Apparently there's an accelerometer inside the Navi unit that tells when the vehicle is moving above 10mph to shut off a certain functions of the unit. This is a mechanical item and cannot be bypassed via electrical circuit. A solution hasn't been found for the navi add on yet."
I just would like to know if anyone has connected the U220 AND can watch DVDs too...without having to detach the unit from its cradle prior to starting the vehicle up.
Posted Dec 18, 2010 · 14:45 UTC#11
I have the 3200DVD and the U220 Nav. I have tried the relay bypass and it works WITHOUT the Nav unit. As soon as you plug in the nav, it will not bypass. I simply installed a switch and flip it off then back on and it will be bypassed. The relay was removed, the parking brake wire was hooked to one side of the switch, ground to the other.
Posted Dec 29, 2010 · 22:24 UTC#12
Get the PAK Universal trigger output module follow instruction and the dvd works not when going over 10ml but at least it works when idle.
Posted Dec 29, 2010 · 22:28 UTC#13
Hi Everyone,
Get a PAK universal trigger output module you hook 4 wires up and you can get video it takes the place of your relay.it comes with instuction it says something about programming it but just hook it up and it works.hope this helps
Posted Jan 09, 2011 · 01:03 UTC#14
Thanks to all who posted on this issue - it really helped me find a working solution. Here it is:
I have the AVH5200DVD and the AVIC U220 and just finished my install with a successful parking brake bypass. I can watch video without unplugging the U220 before startup, no switches to flip, and it works regardless of the speed. I used the PAC TR7 module as suggested (available from amazon for like $20), but instead of just hooking it up as is (which uses the default function intended for Alpine head units) I programmed it to send a delayed output to a relay which grounds the parking brake. If you read the instructions included with the module, it's not that difficult: function #12 sets the module to send three separate timed outputs, but you only need 1. I set the time delay to five seconds and connected the input for the module to the power antenna line from the head unit and the time delayed output goes to the relay. When the unit turns on, the power antenna line sends power to the module, the module waits for 5 seconds then triggers the relay which grounds the parking brake. This gives the head unit the extra time it needs to boot up with the AVIC U220 connected before it grounds the parking brake. Now there are still some options that are unavailable in the navigation mode while driving over 10mph due to the accelerometer, but with this module/relay combination the video works perfectly all the time - from DVD, USB, iPod, AV Input, etc. Hope this help all my fellow Pioneer fans!
Posted Jan 09, 2011 · 03:45 UTC#15
So its not a "total" bypass solution, correct?
Posted Jan 09, 2011 · 17:19 UTC#16
No, not a "total" bypass - I haven't come across anyone who's been able to bypass the accelerometer. This just fixes the video issue which is good enough for me right now. From what I've seen so far, the only functions that are unavailable when going over 10mph are some settings and anything requiring you to type on the keyboard. These functions do come back when you slow back down though, so when you stop at a light, even if the functions had been locked out, you can use them again.
Just a side note, I went through the rediculous process of updating the AVIC U220 with the POI's you get for registering and found out (through trial and error) that your SD card MUST be formatted as FAT32, not NTFS. The nav unit would not recognize my NTFS formatted card at all!
Posted Jan 12, 2011 · 15:50 UTC#17
Posted Jan 15, 2011 · 06:35 UTC#18
how long did you have to wait for the email from pioneer? its been a week and a half now, still nothing...ohh yeah, they charged me 5 bucks for some reason. How big of a flash drive did you have to have?
Posted Jan 15, 2011 · 07:02 UTC#19
Got my email back from Pioneer within 2 days, and I put in my credit card info but the charge showed as $0.00, so I'd make sure you signed up for the right thing - sounds like you might have ordered something different.
I have a 2gb SD card in the nav unit (which you have to leave in it to be able to use the POIs) but I think you could use a 1gb card
I just ordered a 16gb SDHC card to leave in the head unit with music and a 16gb Lacie Moskeyto for the USB port to be used for video. I'll let you know if I run into any issues with either.
Right now I have a Lacinema rugged 500gb hard drive hooked up to the av input with ~500 movies and ~300 tv shows and it works fine, but I'd rather be able to control it all through the touch screen instead of the Lacinema's remote
Posted Jan 17, 2011 · 05:30 UTC#20
i dont think i signed up for the wrong thing, it said poi directions for avic-u220. i guess i'll have to call pioneer tomorrow.
Posted Jan 24, 2011 · 21:01 UTC#21
...but instead of just hooking it up as is (which uses the default function intended for Alpine head units) I programmed it to send a delayed output to a relay which grounds the parking brake. If you read the instructions included with the module, it's not that difficult: function #12 sets the module to send three separate timed outputs, but you only need 1. I set the time delay to five seconds and connected the input for the module to the power antenna line from the head unit and the time delayed output goes to the relay.
Happ999, would you happen to be able to provide a wiring schematic as to how you hooked it up? Did you remove the break bypass relay and hook up another relay? (i.e. "and the time delayed output goes to the relay.")
Posted Jan 28, 2011 · 07:24 UTC#22
I did the AVIC-U220 bypass with a AVH-P5200BT. Here is a diagram of what I did. The colors correspond to the AVH-P5200BT but the wiring is still the same for other models (in case the colors are different)
Posted Jan 28, 2011 · 15:33 UTC#23
That diagram is perfect wooward - that's exactly how I have it wired and I haven't had any problems
Posted Feb 03, 2011 · 05:53 UTC#24
I appreciate the diagram; I installed a U220 with an existing 3200BT. What I don't understand is the connector(?) with the numbers on it. You show the PAC unit and the AVH harness wire colors, but I don't understand the block in the upper left with the black, green, and red wires.
Is this a relay? If so would that already be in the installation, or would I need to purchase one. If I need to purchase, is there a model or part number you recommend?
Posted Feb 06, 2011 · 11:14 UTC#25
Yes that's a relay. The one shown is a 5 pin relay but you can use a 4 pin relay as well. Basically the same except that there is no 87a. You can buy them from all sorts of places. It's a pretty standard relay. Don't need to worry about how many amps it will handle because you will be using it to ground.
http://www.radioshack.com/product/index.jsp?productId=2062477
http://www.amazon.com/Tyco-Relay-SPDT-Formerly-Bosch/dp/B000P61E36
http://www.amazon.com/VDC-Automotive-Relay-SPDT-40A/dp/B0002KR9GG/ref=sr_1_3?s=electronics&ie=UTF8&qid=1296990698&sr=1-3
I believe you can also buy this relay from DEI with a timer circuit built in. This would mean that you wouldn't use the PAC.
http://www.amazon.com/Pulse-Timer-with-Spdt-Relay/dp/tech-data/B0009WP09K/ref=de_a_smtd
Page 1 of 2
