Map accuracy - lagging behind
By ADE · Aug 07, 2010in Problems/Troubleshooting💬 41 posts👁️ 7,635 views
Page 2 of 2
Posted Sep 04, 2010 · 12:58 UTC#26
I have the vss wire hooked up. It's using the units sensors and the vehicle speed sensor to determine location. When I unhook the vss, it goes to simple.
At the calibration screen on mine the learning status is set on Simple Hybrid instead of 3D Hybrid. I'm not sure what the difference is.
Posted Sep 04, 2010 · 14:21 UTC#27
The xm just means that is the audio source I was listening to. It changes with what ever source. I'm actually using the factory xm radio antenna, so disconnecting it does nothing.
The problem is the same with the vss bicker up or not.
My suspicion is the sensor in the unit is bad. I may just yank it out on Monday and send it back to Pioneer.
Off about 1/2 block, sometimes it's blocks off. The vss is connected. The gps antenna is on the roof of the vehicle and reads exceptional reception. I can post pics of this stuff when I get home.
Wait a second - your screen says XM - so I take it your X920 is receiving signals from two sets of satellites for both GPS and XM. It would be interesting to disconnect the XM and see if the problem remained. Maybe there's a software glitch there - anyone else with XM? What happens when the antenna is inside the car?
But still, the Pioneer guy may be on to something - aka there's something amiss with the VSS hookup; a short, a loose wire, the wrong signal (how are you getting the VSS feed - is it digital or analog?)
Posted Sep 04, 2010 · 16:33 UTC#28
you know, these nav units, across the board are a crapshoot at best. We just drove up to central California, in a brand new Jetta with OEM nav, and roads that have been there for 60 years, and lakes that have been there since the ice age were not present on the map system used by VW. As far as the nav was concerned, we were driving through the forest.
Posted Sep 13, 2010 · 03:17 UTC#29
Perhaps some of the map files have slightly incorrect lat/long information. That would explain why the nav software doesn't think you've reached the intersection and could also explain why the issue seems to be sporadic among members.
Of course, you'll never know unless you can find another x920 owner to drive that route...
Posted Sep 13, 2010 · 03:32 UTC#30
that sounds logical. In the 20 minutes I had with my x920BT the other day before it died, I hooked up VSS - got good data and satellite links. The streets were all where they should have been, the turns in the right place (ok, I found there was about a 35 foot lag - big woop), and the nav woman announced the street names properly.
However . . . when I asked her to program a route back to my house (programmed as home), she went about one-half mile out of her way for the route. Made it more complicated and longer. But, she was moving "forward". I'm wondering if Pioneer's nav people didn't understand the concept of "turn around, go back".
If the nav woman had known that, she would have saved me 1/2 mile.
Also, I drove past my street on purpose to see what she would do with re-routing.
As I passed my street, and was about 400 yards from my house, she declared victory and said "you have arrived at your destination".
Not quite.
How many of you have that problem?
Even as I kept driving, the nav lady packed it in, assuming I had believed her incorrect proximity.
That's a little worrysome
Posted Sep 18, 2010 · 15:11 UTC#31
What's your U-turn threshold set to?
Joe
Posted Sep 18, 2010 · 17:30 UTC#32
Joe
Good question . . . time to consult the mega-manual again I guess - what should it be?
Posted Sep 26, 2010 · 18:26 UTC#33
Just finished installing the Z120BT, and also seeing some lag on the nav screen, how much lag would be considered normal? I get great reception under Nav settings/connection status screen? :?:
Posted Sep 27, 2010 · 06:49 UTC#34
In my car, the NAV rolls up to the street ahead by about 15 feet late. It's exactly the same as my Garmin portable. If I count the back of my car as the marker, then it's only about 5 feet late. Totally acceptable for what I'm using if for, and that's NOT as Kimi Raikkonen's navigator.
Posted Jan 20, 2011 · 07:39 UTC#35
Not sure why people put the GPS in the AVIC-X920BT down so much. I wasn't real happy with it at first, but after a few tweaks, I think it works pretty well. It shows all the street names, announces turns with the street name and seems pretty accurate on short trips, I haven't taken any long trips with it yet. When I first got it, I noticed when parked at home the position of the arrow on the map was a little off, but after I adjusted it, it seems pretty good now. It still announces you have arrived at your destination maybe a hair to early, but not bad. I had (and still have) a portable Garmin Nuvi before this I really liked, but like the Pioneer GPS, so far, and it's built in, always ready to go. :)
I have VSS connected and it's still 200-300ft behind the point, for $700, that accuracy is not acceptable, Pioneer needs to work on it asap, I am still using my Garmin, paid $120 and it rocks!!!
Edited Jan 20, 2011 by awesomeprius
Posted Jan 20, 2011 · 16:38 UTC#36
If it's that far behind, either it's malfunctioning, hasn't come close to finishing the 3D Hybrid set-up phase, or you've somehow buggered the install. Try disconnecting the VSS and check the GPS screen, and just drive with it for a few days un-connected. Even with VSS not connected, mine was only around 20-40 feet shy of the target.
300 feet is WAY off. And the Garmin? If it's like my portable, it's only about 5-20 feet off, depending on what part of your car is the reference point.
Posted Jan 20, 2011 · 18:02 UTC#37
Funny....mines has never completed the 3d Hybrid set-up phase. The bar indicator never finishes the last 5-6 bars.
Posted Jan 20, 2011 · 18:20 UTC#38
You may be right - I'll check that as well, but I believe mine finished for straight lines, just not left and right turns
Posted Jan 21, 2011 · 04:10 UTC#39
I've had the same issue with my X920, seems to be about 30-50 feet behind. No VSS connected. Our other cars with OEM Lexus nav are spot on accurate (center of the arrow), as is the X710 in my ES (also no VSS connected). The X920 for whatever reason isn't as accurate.
Posted Jan 21, 2011 · 17:26 UTC#40
It's likely the reason is multiple GPS antennas, or at least on that is driven by a $50,000 dollar purchase price?
The Pioneer doesn't seem to be quite that lofty, hell, it's not as lofty as a $300 Garmin portable.
It does do quite a lot for the price, but it seems the NAV is truly the achiles heel of the unit.
Posted Jun 23, 2011 · 22:42 UTC#41
I also have the X930BT. I was having the same problem. The location of my vehicle was different from what showed on the GPS reciever. I changed to main GPS unit and also the antenna, but the problem still existed. The real problem is the vehicle speed sensor. If you go to the 3D calibration screen the MPH should to the same speed as your car is going.
Page 2 of 2
