I installed my 120 yesterday and have been having a weird problem. I have a 2007 tahoe and when the automatic headlights turn on the unit pretty much becomes useless. Audio hardly plays from any source, meaning the volume could be set to 30 and there is just a slight wisper audible. When I turn the volume up, the volume doesnt change, however a minute to two minutes later it will respond and turn the volume up super loud. It also seems to disconnect from the sub as there is absolutely NO bass at all when this is all going on. To fix it I have to shut the truck off and turn it back on, in which case it all works again without problems. I cant figure out what the deal is....might disconnecting the illumination/dimmer/whatever it's called wire solve this, so the unit just doesnt know when the lights are on or off?
Thank you again for the help!
