F700BT Trouble
By BFoster · Sep 09, 2010in Problems/Troubleshooting💬 46 posts👁️ 30,826 views
Page 1 of 2
Posted Sep 09, 2010 · 14:27 UTC#1
Hello all-
I have searched and search this forum but have yet to find what I need.
My U.S. F700BT started getting stuck at "System Startup in Progress. Please Wait." It would show that message for a few minutes and then reboot.
I checked the Pioneer support site and saw that there were firmware updates available so I tried to use one of those to correct the issue. This resulted in the headunit showing the splash page and then shutting down completely.
So then I had the bright idea to try some of the other solutions I had seen on this board, upgrading to 3.1, upgrading WinCE, etc. So far everything has resulted in a completely unusable system. Right now all it does is show the splash page and then eventually shuts down.
Many of the solutions I found here had files associated with them that are no longer available. Could someone please post the required files and instructions to basically reinstall my entire headunit? At this stage I dont care what version it is as long as the system will stay powered up, play the radio, have the default maps of the U.S., etc. and play music from SD or iPod! :D
Thank you in advance for any assistance you can provide.
Posted Sep 09, 2010 · 18:00 UTC#2
Sounds like you made a mess of your system. From your description, it sounds like it was the semi typical issue with a corrupt GpsParaX.bin (X=0-3) file. The normal solution to that is to delete the 4 GpsParaX.bin files.
Where you really blew it was most likely trying to do the 3.1 install.
I've noticed that if the version of Windows CE is different between the background windows (done through service menu) and the one on the flash drive you can experience weird issues at times and it will work fine at other times.
I have all the files to restore the F700 to version 2.0. I just need an e-mail address to set you up to be able to download it since it is at a commercial online backup site that uses e-mail addresses as a the user ID and sets permissions from there. The files are not something that can be e-mailed as they are about 1.7Gb for the full image.
Basically, you need to download the files I can share and the V2.3 test mode files and put them on a SD Card (card needs to be at least 2Gb).
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "F700" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. Except for the test mode files/folder (It will say the copying will take 140min but will only take about 20)
Posted Sep 09, 2010 · 19:13 UTC#3
Thanks for the quick response another gsxr 1k! About an hour after posting this I finally ran across a thread with a valid download (viewtopic.php?f=34&t=32351).
At any rate I downloaded this torrent, followed the instructions and everything seems to be working again.
Thanks again for the assistance!
Posted Nov 10, 2010 · 00:58 UTC#4
another gsxr 1k
Can you help me. My unit crashed and my backup doent work.
Posted Mar 02, 2013 · 22:36 UTC#5
Hi, i need all the files to restore the F700 to version 2.0. please my email is [email protected] thanks
Posted Mar 18, 2013 · 23:13 UTC#6
I need the files as well. My e-mail address is [email protected] Thanks
Posted Mar 19, 2013 · 15:18 UTC#7
I need the files as well. [email protected]
Posted Apr 05, 2013 · 15:52 UTC#8
I'm having a completely different problem and was hoping someone here could help. Everything was working great until one day when my daughter connected her iphone to the USB to play her ipod. Everything came up. you can switch songs, see how far into the song it is playing. Everything seems normal but no sound. No volume! I always played my iphone on it but now mine has no sound either. No matter what device I hook up, no sound. Does anyone know if there is a fuse and if so, do you know where to locate it? Any other possible problems? Any thing will help,
Thank you,
CindyO
Posted Jun 15, 2013 · 23:03 UTC#9
Thank you,
CindyO
Did you make sure that the settings for the input are set to iPod? Press the "Menu" button and touch the "Settings" tab. Select "AV Settings", and touch the
"AV1 Input" button until "iPod" is displayed.
Posted Jul 25, 2013 · 14:30 UTC#10
will this work on a avic-f900bt?
Posted Jul 25, 2013 · 14:30 UTC#11
if so my e-mail is [email protected]
Posted Sep 18, 2013 · 23:28 UTC#12
can someone email me the files [email protected] thankyou
Posted Oct 02, 2013 · 15:28 UTC#13
Hello all-
Do you still have the "I have all the files to restore the F700 to version 2.0" files, my F700bt is now doinf the same thing? If you have them can you send them to me please. [email protected]
Posted Oct 02, 2013 · 15:29 UTC#14
Do anyone still have the files to  restore the F700 to version 2.0" files, my F700bt is now doing the same thing? If you have them can you send them to me please. [email protected]
Posted Oct 02, 2013 · 15:30 UTC#15
Posted Dec 11, 2013 · 17:24 UTC#16
hi, i have the same problem with my avic f700bt can you send me the file please to [email protected]
thanks
Posted Dec 11, 2013 · 18:36 UTC#17
please send me to my email [email protected] thank you
Posted Dec 26, 2013 · 09:20 UTC#18
Hello.
I've AVIC - F7010BT version 2.0, I've donwloaded V2.8 and after unit reset, system stuck to " system is starting up  please wait"  and keep rebooting every 5 min.
I highly appreciate you to help me
Thank you very much.
Posted Jan 10, 2014 · 21:06 UTC#19
If I have a copy of the 3.1 will this work or is it better to update to 2.0 ? If it is better to update to 2.0 My email address is [email protected]. Thanks again. I bought my truck and this was the installed radio and the version running is a custom version and I just want to have a stock system. I cant use the GPS features I dont know how to work it at all.
Posted Jan 11, 2014 · 01:38 UTC#20
Anyone looking for step by step directions and the files on a SD card with the latest maps just message me.
Anthony
Posted Jan 12, 2014 · 23:45 UTC#21
I need these files as well
[email protected]
Trying to fix the reloading loop error after I got car back from getting the coil packs replaced. I know nothing about this unit nor do I even begin to know the pass key code. Unit was in the limo when I bought it.
Posted Jul 27, 2014 · 17:12 UTC#22
Hi, i need all the files to restore the F700 to version 2.0. please my email is [email protected] . thanks
Posted Sep 08, 2014 · 12:24 UTC#23
8)
Edited Jun 17, 2015 by CDD
Posted Sep 08, 2014 · 12:29 UTC#24
Posted Sep 10, 2014 · 05:32 UTC#25
Im having similar issues with my f700bt. Ive had it for maybe 5 years installed by Best Buy. It powers on after about 20 minutes of me driving but will shutdown and power on. It will eventually stay on once my car has been on for awhile. Im not sure if its a power supply problem or if it is the software? Ive read a lot of threads and its kind of hard to do any kind of updating on it since it reboots shuts down and I'm not sure if its updating files that i need to do or if i have to just suck it up and buy another expensive double din? any help or suggestions would be greatly appreciated.
Page 1 of 2
