F700BT Trouble
By BFoster · Sep 09, 2010in Problems/Troubleshooting💬 46 posts👁️ 30,826 views
Page 2 of 2
Posted Sep 15, 2014 · 19:06 UTC#26
Sounds like you made a mess of your system. From your description, it sounds like it was the semi typical issue with a corrupt GpsParaX.bin (X=0-3) file. The normal solution to that is to delete the 4 GpsParaX.bin files.
Where you really blew it was most likely trying to do the 3.1 install.
I've noticed that if the version of Windows CE is different between the background windows (done through service menu) and the one on the flash drive you can experience weird issues at times and it will work fine at other times.
I have all the files to restore the F700 to version 2.0. I just need an e-mail address to set you up to be able to download it since it is at a commercial online backup site that uses e-mail addresses as a the user ID and sets permissions from there. The files are not something that can be e-mailed as they are about 1.7Gb for the full image.
Basically, you need to download the files I can share and the V2.3 test mode files and put them on a SD Card (card needs to be at least 2Gb).
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "F700" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. Except for the test mode files/folder (It will say the copying will take 140min but will only take about 20)
Can you please send the files to [email protected]
Posted Sep 20, 2014 · 22:40 UTC#27
Can you help me with the files as well [email protected]
Posted Sep 29, 2014 · 00:41 UTC#28
F90bt here. Can you send it to iamnsxtc@ hotmail
Posted Oct 10, 2014 · 08:46 UTC#29
F900BT, could you send me these too? [email protected] thanx
Posted Oct 12, 2014 · 22:07 UTC#30
Can you please email me this [email protected]
Posted Nov 25, 2014 · 23:11 UTC#31
This still a good thread
Posted Jan 17, 2015 · 15:54 UTC#32
Can anyone send me test for 700 by please. Not having any luck finding them one here. [email protected]
Posted Feb 17, 2015 · 15:52 UTC#33
I would like a copy of the file as well please my email is: [email protected]  Thank you
Posted Feb 20, 2015 · 09:56 UTC#34
Posted Mar 29, 2015 · 03:34 UTC#35
could someone upload the files to google drive plz.
Posted Jun 20, 2016 · 21:28 UTC#36
Posted Sep 08, 2016 · 20:59 UTC#37
Hi all
   When i turn on the car,my avic f700 goes to black screen just after 15 secondes.
Then i decided to formate it but read progress arrive to 100% and then freezes.And with testmode ,I can't enter to windows.
I don't know what i can do ,please help me.
Thanks in advance.
Posted Dec 02, 2016 · 15:04 UTC#38
Hi everyone,
I have an AVIC-F700BT and one morning it decided to get stuck on "starting up system please wait" (something like that) and after a bit it reboots itself. Please help. Does someone have a copy of the files?
Thank you in advance.
Posted Dec 05, 2016 · 22:39 UTC#39
Hi,
Does anyone still happen to have a copy of the 2.0 firmware files? Please send me a message and I will give you my email to send. Thanks!
Posted Nov 24, 2021 · 23:42 UTC#40
I need these files also please and thank you!  [email protected]
Posted Nov 29, 2021 · 02:53 UTC#41
Ok im way late but I need assistance something serious I have the 700bt system settings are grayed out but I would like to upgrade to the latest firmware do I need to go from  2 to 3 to 4 or can I go from 2 to 4 and where can I download also can I use a galaxy note 9 to write the files on an SD via an SD reader. Email is [email protected] please help
Posted Mar 02, 2022 · 16:14 UTC#42
Do you guys still need help? Sorry, but haven't been here in a while.
Posted Aug 14, 2022 · 09:39 UTC#43
Hi there,
Thanks for helping out. I'm having the same problem with my AVIC F700BT system. I've tried everything I've been able to find on different bulletins, nothing seems to work. When I want to delete the BIN files, they're just not there on 'My Flash Drive', so I can't delete them. There must be a way to restore my unit, can anybody help?
Thanks so much, best regards, René de Groot
Posted Sep 16, 2022 · 14:05 UTC#44
Hey, you would help me a lot if u still have the files for the AVIC....are they European or USA/CANADA?
Posted Nov 08, 2022 · 15:25 UTC#45
Hi all!  AVIC 700BT came with my sti.  Worked fine for 9 years, now it suddenly gets stuck on boot up splash, then goes to black screen w/ no response (touch or buttons)  Can anyone email me update files, or help getting my radio and navi back?? Thanks!!  [email protected]
Posted Nov 13, 2022 · 20:07 UTC#46
On 2.03.2022 г. at 18:14, wmitch927 said:
Имате ли все още нужда от помощ? Съжалявам, но не съм бил тук от известно време.
I need those files too, please and thanks! [email protected]
Page 2 of 2
