Correct me if I'm wrong but the yellow wire is the one that requires high current !
correct, but...
... the yellow wire needs to have power all of the time(for memory) so it cant be used to trigger a relay or else the relay will be engaged all the timeWhat about hooking the wire that normally power the AVIC (yellow wire) to triger the relay (pin 85)
Like that the PAC signal will be use to triger the relay not at full current and it should maintain the accessory delay since the relay will open at the expiration of the delay and the radio will stop..
the problem is that the PAC module (for what ever reason) is not able to keep a steady amount of power on its turn on output (red ACC) when the bass is hitting hard. and that why his system is resetting when it is turned up.
the red wire going into the avic is already like a relay trigger wire, as it does not need much current at all to have the AVIC turn on
