Hey, I'm back from a 3000 km round trip to Vancouver Island and had the pleasure of using Primo the entire trip with no crashes or other unforeseen issues! Primo looked absolutely stunning driving through the mountains with the premium DEM file. Anyways, here is the link: http://hotfile.com/dl/127874074/6a73966/AVICmod.rar.html.
Unzip, copy to SD card and when it boots into testmode copy My Flash Disk from the SD card to the unit. Back up your unit first, and use at your own risk.
A few things to note, changing the Day Skin Theme and Night Skin Theme from the display menu crashes Primo (you can however change the Day and Night Map colors from the Map Settings Menu), and DO NOT Reset to Defaults or you will lose many menu options as well as several hacks in this version which give you extra information on the overview screen (overview mode, bottom info bar, ect).
To launch Primo turn on the GPS as you normally would, go to the Map screen, tap the globe on Chuck88's Mod 3.3 (bottom left), tap the bottom right icon (Applications Menu 1), tap Apps set 2 (second from the bottom on the right), and then tap the middle rightmost icon (Primo). It will kill eazyrider and show you windows explorer and a few seconds later Primo will launch. The sys file is set up to share your Maps, POIs, DEM and Building files with your iGo folder. Samantha was the only TTS voice I could get working, unfortunately and she only speaks through the units speaker. When you exit Primo it will reboot the unit, and if you minimize it will leave you in windows explorer. When the ignition is shut off or the power button is tapped it will send the unit to standby and it will resume to Primo when the car is turned on or the power button tapped.
Please leave any feedback you may have. I have no idea how to map the hard buttons to Primo (Map, Menu, scroll wheel, ect), if anyone does or can point me in the right direction please do so! Chuck, being the Avic wizard that you are perhaps you would have an idea or two on how to better integrate this into our units? Thanks for you patience in answering users questions on this site, much of the information you shared allowed me to get a better understanding of our Avic units and helped me get Primo working.
Hi There:
Is it possible to get step by step of files to install this in another mod? I have built mine over the last two years using a combo of bunch of different mods. I really would like to see how this looks.
Jimbo
