Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 26 of 35
Posted Jan 19, 2012 · 03:01 UTC#626
Does enyone have a problem with the off button that keep showing on top of everything on the bottom right corner. I try using notepad and I can get the keyboar i turn Primo on and it still there. Does enyone knows how to get it off
Posted Jan 19, 2012 · 03:01 UTC#627
Hey chuck thank's for your help but I figured out. I was using Ryar Mod when I did it and it doesnt work with it so I did it with FX3.1 and it work great. I am still having a little problem with primo though not getting the map but I'll figured out. Hey chuck would it be posible to change the text color in the map I would like to change the clock color and make more bigger. Thank you for sharing Mod and Keep up the good work.
What text color or size do you mean? In my mod or in Primo 1.2?
If in my mod, which text?
Posted Jan 19, 2012 · 03:02 UTC#628
Go to Custom Settings of my mod and turn OFF the A/V button bar.
Edited Jan 19, 2012 by Chuck88
Posted Jan 19, 2012 · 14:06 UTC#629
In your mod, Top right hand corner the MPH counter and the clock that are yellow I would like to change the their color and size. Is kind of hard to look at the clock with the yellow roads on the background.
Thank's, and keep up the good work because if it wasn't for this I would of junk my unit that when crazy while I was driving.
Posted Jan 19, 2012 · 14:27 UTC#630
You would have to do some editing in the file DATA.zip->ui_pioneer\800_480\ui\Chuck88_800_480.ui, under the ";TIME" at lines 74 and 75, change the hex value of "color=#f8cc28" to whatever value you want. Google "HEX color code" to get desired color.
You can use WinRAR to open the DATA.zip file to perform editing with NotePad, then rezip it after exiting your editor.
Posted Jan 19, 2012 · 15:14 UTC#631
You would have to do some editing in the file DATA.zip->ui_pioneer800_480uiChuck88_800_480.ui, under the ";TIME" at lines 74 and 75, change the hex value of "color=#f8cc28" to whatever value you want. Google "HEX color code" to get desired color.
I'll give it a try with Dreamweaver, Thanks
Posted Jan 19, 2012 · 19:23 UTC#632
@chuck88
hello, content de te revoir sur le forum.sans trop rentrer dans les details j'ai mis ton PRIMO directement sur mon avic en supprimant le IGO8 et en renommant le Primo.exe en ezrider.exe
tout fonctionne bien....il y a juste le message 'system startup please wait ' qui ne disparait pas...au bout de 5 minutes il redemarre automatiquement...je pense qu'il y a un fichier DLL qui repere que IGO8 n'a pas demarré et redemarre automatiquement...
saurais tu quel fichier DLL gere le fameux message???
Posted Jan 19, 2012 · 19:36 UTC#633
Salut bandit,
C'est justement cela que les autres chercheaient depuis longtemps mais sans solution! Il faut travailler dans l'assembleur et c'est trop long a faire. Il faut donc prendre ma mod v3.4 comme rampe de lancement du Primo, malheureusement.
Chuck.
Posted Jan 19, 2012 · 19:37 UTC#634
Pioneer FW 4.0 + Chuck88's Mod v3.4a + Primo 2.0 is coming ...
Posted Jan 19, 2012 · 19:41 UTC#635
Ehhh, this doesn't mean that I will come back for good, but just to share my works with others ... I'm truly overwhelming in my daily life to come back, so I urge your knowledgeable guys please support the newbies, and mutually, to continue the good tradition of this forum.
Thanks! :)
Posted Jan 19, 2012 · 19:43 UTC#636
@ chuck88
tu sais ou connaitrais le nom du logiciel assembleur qu il utilise pour acceder au code source??
Posted Jan 19, 2012 · 20:25 UTC#637
@ chuck88
Non!
Posted Jan 19, 2012 · 20:25 UTC#638
2012-01-19: v3.4a posted: Now with Primo 2.0 and Pioneer FW 4.0 Update!
Again, make a backup of your "\My Flash Disk" folder. Should you run into any problem because you have use other mods previously, please delete the folders "\My Flash\Disk\User\UserData\iGo" and "\My Flash Disk\APL2\Primo\save" to get rid of the possible incorrect settings.
Let's make this short!
Pioneer FW update 4.0: This is not an image level update, just some DLL and EXE are updated to include minor improvements to the FW 3.00x, but Pioneer decided to flagged this update as FW 4.0, which is found in some "About" boxes of the system FW. This update is completed by copying some files over their existing FW 3.00x counterparts, and are located in the "\My Flash Disk\APL" folder and the EzRider.exe of the iGo software. Those files also include Warning or Nag messages removals by "carver", and my own Image.res inside the APL folder. This "carver" hack should also automatically start the countdown timer to launch Primo 2.0 if Primo is selected under the "Custom Settings". If you don't want this update, please do not copy the files mentioned in this paragraph.
Nuance TTS Pro 5.0: Those massive files are not included in the zip file but you can download it from ryar's "Primo for AVIC" thread and put them directly under the Primo folder to provide support for TTS Pro. The download should include the VAUTOV5.DLL and the tts_nua_v5 folder.
For those of you who prefer my Mod rather than Primo: Please note that the interface color of the background of the all menu can is selectable under the "Custom Settings" menu. I put the green as the default rather than chrome because this match the interior of my car.
There are a couple of gimmicks when using Primo, and I believe that ryar and other are working hard to resolve them, below:
  1. To have guidance voice and sound within Primo, you have to play music from SD, iPod/iPhone or USB. Radio is not enough to have sound!
  2. After or when running Primo, if the SD card is removed from the slot, it might trigger a reboot!
  3. From time to time, you might see a "Fatal Application Error" message just before launching Primo (KeyScan.exe or Button.exe), but just tape on "OK" or ignore it, Primo will run just fine.
  4. Next/Previous songs command (knob) not working within Primo.
  5. Read "Couple of precisions" of my previous release below:
As always, enjoy!
Posted Jan 19, 2012 · 20:38 UTC#639
Thanks Chuck.Its great to see you back.Very much appreciate all your contributions.
Posted Jan 19, 2012 · 21:50 UTC#640
Nice to hear from you too Ovalball! :)
Posted Jan 20, 2012 · 08:30 UTC#641
Merci Chuck,
C'est super de partager votre travail, tout comme Ryar et ceux qui oeuvre sur ce forum, Encore MERCI :D
Posted Jan 20, 2012 · 17:30 UTC#642
Thanks Chuck, today was the day for the upgrades, and you just made it a whole lot easier.
Edited Jan 20, 2012 by fusion600
Posted Jan 20, 2012 · 20:26 UTC#643
I'm glad that I was helpful. Please keep me posted on your upgrade process on all your three setups!
Cheers!
Posted Jan 20, 2012 · 22:50 UTC#644
Alright, I know Chuck doesn't want too much support duty here, but I am really confused why I can't get this to start. I went from ABB to AVICnet to installing this. I am not able to get the navigation to start up. It loads to the start page, I can click the contacts and music buttons, but when I click iGo, it does nothing. It also says "system starting (or loading) please wait" then reboots after a few minutes. I deleted the save and igo folders, but something isn't letting this load?
Posted Jan 21, 2012 · 02:12 UTC#645
If your using AVICnet is not going to work. I had the same problem until I use Fx3.1 and replace the the APL and APL2 with chuck88 APL and APL2 . For some reason I couldn't get primo working, but then I put map in it conten/map folder and it work.
Edited Jan 21, 2012 by djluis2012
Posted Jan 21, 2012 · 14:48 UTC#646
Thanks, I am totally perplexed now. I deleted the entire MyFlashDisk, then reinstalled my old Disk with Chucks files embedded. Still getting the hang up.
Edited Jan 21, 2012 by nissanfrontier
Posted Jan 21, 2012 · 17:04 UTC#647
hello chuck88,
ton mod fonctionne sur mon avic mais le gps ne marche pas, j'ai le message ' recherche signal Gps' affiché pourtant il a trouvé 9 sattelites...il ne me localise pas...
Posted Jan 21, 2012 · 17:28 UTC#648
Posted Jan 21, 2012 · 17:35 UTC#649
Maybe your having trouble with the update that chuck added to the APL folder. Try copying the IGO and PRimo folder over the one you have in your old one or over the one in FX3.1.
Posted Jan 21, 2012 · 18:10 UTC#650
Thanks, I will try that.
EDIT: Didn't work. I just deleted the entire flash disk and re-installed AVICnet. Worked fine. Just not sure what my f90bt didn't like in Chuck's files.
Edited Jan 22, 2012 by nissanfrontier
Page 26 of 35
