Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 27 of 35
Posted Jan 22, 2012 · 03:52 UTC#651
I've tried the link to 4shared and I'm getting an error stating 'The file link that you requested is not valid'. Does anyone else have a link to it?
Posted Jan 22, 2012 · 04:05 UTC#652
I'm fixing the link problem right now. :) ... should be OK in 20 minutes ...
EDITED: All done! Link works now.
Edited Jan 22, 2012 by Chuck88
Posted Jan 22, 2012 · 04:18 UTC#653
Alright, I know Chuck doesn't want too much support duty here, but I am really confused why I can't get this to start. I went from ABB to AVICnet to installing this. I am not able to get the navigation to start up. It loads to the start page, I can click the contacts and music buttons, but when I click iGo, it does nothing. It also says "system starting (or loading) please wait" then reboots after a few minutes. I deleted the save and igo folders, but something isn't letting this load?
This is most of the time because missing maps, or rather frequently, you have performed a partial copy of the files from the SD card. Always check you have enough free space on "My Flash Disk" by checking "Properties" because copying, because WinCE will not give any error when there is not enough free space. It just stopped and you're ending up with an incomplete set of file.
The 5-minutes rebooting cycle is a security loop implemented by Pioneer to prevent lockup. During this time, it is waiting for EzRider.exe to respond after loading iGo was ended.
Posted Jan 22, 2012 · 04:21 UTC#654
For those of you having trouble running Primo, please delete the whole folder "\My Flash Disk\APL2\Primo\save". It might contain invalid settings for your AVIC setup. Primo will create a brand new set of settings by start asking "Language".
Good lucks!
Posted Jan 22, 2012 · 04:32 UTC#655
Hmm, interesting. Thanks I will check that tomorrow. I would be surprised of disk space issues though when I had Abb's mod installed before without issue. Then installed AVICnet without issue, and this one won't go. No biggie in long run. I will keep working on it.
Posted Jan 22, 2012 · 16:41 UTC#656
Since the map is what take the most space, should try copying the map of the state that you live in. Then copy the rest if you have enough space left.
Edited Jan 22, 2012 by djluis2012
Posted Jan 22, 2012 · 22:56 UTC#657
Yeha, I checked and had 600mb left, so I copied the PRIMO3 folder over (which still doesn't show the Primo 2 icon for me) and still had 500mb left after that. Didn't re-install Chucks mod yet to see what space I have left.
Posted Jan 24, 2012 · 16:15 UTC#658
I am beginning to wonder if AVICnet adds or deletes certain files that doesn't allow allow other mods to work. I really want to try Chucks mod now, and since past versions are not avaliable, I decided to install Diaftias mod and try to transfer over to Chuck.
Using the auto installer I installed Diaftia, but still getting stuck on the "system startup" note, and an error upon first click gives me this:"FFUIERROR Unknown layer reference Identifier [ui_AdvMenu_EU]"
I installed diaftia, deleted all PRIMO folders and the APL4 folder, any other suggestions I can try to get this working. I like AVICnet, but just doesn't suit my needs and now I can't seem to rid the unit of it.
Posted Jan 24, 2012 · 18:05 UTC#659
The error is saying that you're loading an EU version of the iGo software. If you're in the USA, make sure that the device is correctly selected at the beginning of the SYS.TXT file.
It is most likely that you're missing some files under the iGo\CONTENT folder and subfolders. Don't forget to copy all available license files to the iGo\LICENSE folder.
Edited Jan 24, 2012 by Chuck88
Posted Jan 24, 2012 · 18:22 UTC#660
Hmm, thanks. The auto installer must not be picking my US version when I select it.
Last error question then I will have to work on this tonight when I get home to my own computer.
When I load your files, I get this message.
"failed to open file ui_pioneer/common/ui/legacy_variables.ui exiting application"
Edited Jan 24, 2012 by nissanfrontier
Posted Jan 24, 2012 · 20:40 UTC#661
This UI file is within the DATA.zip, which mean that DATA.zip is maybe not copied to "\My Flash Disk\APL2\iGo".
Posted Jan 24, 2012 · 22:12 UTC#662
Hi,
first I would like to thank you Chuck88 and everyone else sharing their expertise and their hard work with the rest of us.
My car is silver with grey interior.. when I switch to Chrome in the interface changer, it does change it in some places, yet the main menu still has a green background and also some other places like the device settings its all green. is that supposed to happen? or there is something wrong in my install thats interfering with the theme.
Thanx
Posted Jan 24, 2012 · 23:48 UTC#663
Hi,
Thanx
Nothing is wrong, just that you have to find a IMAGE.RES file and replace the one within the "\My Flash Disk\APL". I embedded the one that I use that matches the interior of my car ... sorry about that!
You can find an chrome IMAGE.RES pretty easily in this forum. Abb1 has made a great one so look at his Chrome Mod thread and download the IMAGE.RES.
Posted Jan 24, 2012 · 23:50 UTC#664
Hey the Nissan guy,
I think that I might put the finger on your problem. Let's try that ...
Do you have a folder just under the iGo folder called "ui_pioneer". If so please backup that whole folder (if you need it later) then completely delete it, then restart iGo or reboot the AVIC.
Let me know!
Posted Jan 25, 2012 · 00:34 UTC#665
Hey the Nissan guy,
Let me know!
Well, getting closer. I actually deleted Diaftia's APL and APL2 folders and copied yours over to the flash disk. However, while no errors, still getting a hang up on the system starting notification, then a reboot. When I click on the Navigation icon, it does nothing, almost like there is no exe program?
I also realized my maps have the name tom_tom in them (the latest 2011 maps in the thread on here) but have extension fbl, that should not matter, correct?
Edited Jan 25, 2012 by nissanfrontier
Posted Jan 25, 2012 · 01:44 UTC#666
Sorry but that is totally wrong! You can't delete those two folders because no mod in this forum is complete (except the image level hack of FX3.1)!! Mods are provided only as a subset of the modified functions but the base package from iGo/Pioneer is still needed. In other words, you can mod only when there is a working version of the iGo software, let say, the baseline when you bought the AVIC. Then copy the modded files such as mine and overwrite those existing one, then copy licenses file to the right folder. With this said, most of the times, you have to have everything else in place and working before you can change mod.
No problem at all for the filenames, FBL extension is perfect and iGo searches that automatically.
So you would have to restore to something workable with both APL and APL2 before you can continue again, I believe ... unless by chance, you already have everything in place, which I doubt seriously.
Please restart from square one.
Keep me posted.
Edited Jan 25, 2012 by Chuck88
Posted Jan 25, 2012 · 03:36 UTC#667
Thanks. yeah I figured, already been downloading fx3.1 for the past couple hours. I installed Abbs mod last year and haven't modded in awhile to totally forget a lot of things.
But still didn't make sense that I have AVICnet working (which was a complete flash disk delete), then tried to overlay Diaftias-didn't work, then tried to overlay yours-didn't work?
Posted Jan 25, 2012 · 04:32 UTC#668
Except for the map, poi, building ans dem files, AVICnet might be a complete set. Ryar maybe he can confirm that!
Posted Jan 25, 2012 · 19:04 UTC#669
Everything is a go Chuck. Just one last little issue, that I see is fixed by a reboot (Nav settings from PRIMO) Thanks again!
Posted Jan 26, 2012 · 02:48 UTC#670
Glad that it is now working ... for all your three AVIC???
Posted Jan 26, 2012 · 03:41 UTC#671
three AVIC? Not sure following that.
I will say that I used to not like smartzoom, but now consider it a nice little addition. Really was not impressed with PRIMO 2.0. Not enough control over the program as iGo.
Posted Jan 26, 2012 · 17:45 UTC#672
That is great News Chuck, Thanks!!!!
Sorry Nissan guy, I was mixed up you with fusion600!
So fusion600, did you get a chance?
Posted Jan 29, 2012 · 23:37 UTC#673
Ever since I installed the update including primo, music by usb and sd are both slow and laggy when in the music menu. Outside of the music menu, it seems to run fine most of the time with occasional lag between skips. And when I am navigating, music stops after 1 play.
Posted Jan 30, 2012 · 03:00 UTC#674
Are you saying that slow and laggy even when Primo is not running?
Posted Feb 01, 2012 · 02:21 UTC#675
Yes, even when primo is not running
Page 27 of 35
