Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 33 of 35
Posted Jul 15, 2012 · 19:15 UTC#801
To Ovalball and Steelth,
I'm really so sorry since I don't mod anymore. I am quite happy with my setup, my own iGo mod and if I have the mood, Primo 2.0.
Ovalball, I don't have any memory issue with Primo 2.0, both Dimika and Gurjon's latest skins. I have the max_mem set ... etc.
Steelth, I'm not aware of any limition of 17 schemes (I didn't play with that part of code anyway); you can try isolate out the files having problem by putting one by one ... etc.
Good lucks guys!
Posted Jul 16, 2012 · 08:03 UTC#802
Ok. I tried, and I change. Do you know what ist the darkest level?
Hummm, check on the following lines of chuck88_800_480.ui and change the alpha level to your liking:
<layer ui_NavigateMapPerm z=3000>
;Mod on-cockpit buttons -------------------------------------------------------
<SPRITE xxx bmp="CW_map_info_bg.bmp"  x=583 y=53 z=1 alpha=16 visiblemodel="gps.valid">
<SPRITE xxx bmp="CW_map_info_bg.bmp"  x=567 y=53 z=1 alpha=16 visiblemodel="!gps.valid">
Posted Jul 18, 2012 · 15:54 UTC#803
using gps and playing mp3 from my sd card at the same time... my songs freeze there.
can you check?thx
Posted Jul 19, 2012 · 12:42 UTC#804
Chuck88..
I used to get elevation in feets, now it is changed into decimal point miles.. Which is pretty inaccurate since it is rouded off. For example my elevation at home was 1100 feet and now it is showing .2miles. and it remains same where elevation was 800-900 feet.. if you can guide me how to change it.. it would sure help.. Thanks.
Posted Jul 19, 2012 · 18:44 UTC#805
Chuck88..
Go to Diaftia's mod and download the alternate EzRider.exe, at his first or second post, and replace the one in my mod.
Posted Jul 19, 2012 · 18:45 UTC#806
can you check?thx
Sorry, I don't have the answer. Anybody can help?
Posted Jul 20, 2012 · 01:31 UTC#807
Thanks a lot. I will try it tomorrow.
EDIT: I tried his EZrider and it did not change any thing. I even deleted user data. Still no change. Upto Abb1s mod I was getting elevation in feet, even with your mod I am getting it in feet when I go to GSP details, but on main screen it shows .2miles. I put Abb1's EZrider and Diaftia's modified one, but still no change. It must be something somewhere and I do not know.. If you can please help. Thanks. ( I live closer to mountains and very easily my elevation goes up to 2300feet. FYI.)
can you check?thx
have you tried another SD card? I used to have same issue, but changing to better Class SD card helped me. Also, leave some room on SD card, like 8GB sd dard do not put 8GB stuff on it. leave 1gb space on it. It may be used for buffer?
Edited Jul 20, 2012 by Steelth
Posted Jul 30, 2012 · 13:27 UTC#808
HI community
i have two questions and hope some one can help me.
I have Avic F920bt Europ.
1. If i make the custom rom on my device, can use my steering wheel remote controls?.
2. Can use my reversing camera and starts automatic?
Thank you in advance
Posted Aug 09, 2012 · 12:10 UTC#809
Hello everyone.
Also my Englisch are not good but I try.
I use in my mobilhome the 700bt with the Dafnia's mod. Nice and good. BUT :? I like it to use IGO primo TRUCK (it is for my mobil home) and I don't use only the motorways (almost never 8)) and they are somtimes (to) small
So:
- can I do /install this (truck version) with this mod?
- are this mod also in metric
- on the start of this topic I see also Pioneer update 4 but when I look on the pioneer site I see this update are only for the 200 serie. And I have a 100 serie :neutral:
I hope you can help me
greetings and thanks
Posted Aug 09, 2012 · 18:15 UTC#811
First of all, thans for the quick responce.
But there are a big different between the select a another verhicles and the primo truck version. In the truck version you can set the heigt, widht e.g. special from the vehicle.
To set only the vihicle type in Igo set only the speed and arive time but do nothing with sizes from the vehicle :-(.
Ore understand I you wrong ? (my problem)
I try your link but the motorhome are not by home now (but this weekend he is here)
thanks and regards from the netherlands
Edited Aug 09, 2012 by knorrr
Posted Aug 09, 2012 · 19:47 UTC#812
In Primo you can set height,length weight etc.I have done this for my motorhome and it works very well.
Posted Aug 10, 2012 · 15:49 UTC#813
Thanks again Ovalball. Sound fine. I try it this sunday than is my mobilhome bij home.
I think I have also needed new maps, poi's e.g.?
The IGO 8 dont work I think??
When I need new maps e.g. I have to put them in the same maps/structure/name as Igo (after deleting IGO)?
thanks again
Edited Aug 10, 2012 by knorrr
Posted Aug 10, 2012 · 16:38 UTC#814
Put the maps in apl2/Igo/content/maps.If you are using non pioneer :)maps you will need generic license files.Let me know if this is the case and I can e mail them to you.
Posted Aug 12, 2012 · 14:10 UTC#815
Thanks all.
It have works till...... :?:neutral: my problem. I have deleted somting to mutch :? . But I am recover new and start again.
A question. Did I needed in app2 the map VBT?
It take a lots of space. And space (memory) is wath a needed in the FB900bt (Ihave a "better" one so not the 700 but the 900)
Please lett me now from the VBT map.
Thanks again
Posted Aug 27, 2012 · 14:06 UTC#816
O.K. all is "working".
I have drive a week with the primo 2 on the FB900 en it look nice only ....
- only sound when I use a sd card (I have reas someting about this in this forum but where....) Dit I have to beack to Promo 1.x(1.2?)
- straing somtimes I have nu GOPS signal.... also after restart (off/on unit) as after the reset from the system.... (push pen in little hole left corner radio) somethimes it help but almost :-(.
I have than 11 sitellits al most 90% so that is not the reasen.
Have some one a solution?
I use a 900BT europian version.
Posted Sep 15, 2012 · 02:05 UTC#817
i click the 4shared links but nothing loads up?
Posted Sep 15, 2012 · 13:44 UTC#818
signed up and everythings good....now if I am already on pioneer fm 4. Can i just add the apl2/primo folder?
Posted Sep 20, 2012 · 05:48 UTC#819
Has anyone got Primo 2 running smoothly yet ?I gave up after constant freezing.I read somewhere you need 128 m of RAM to use the advanced features of Primo 2.
Posted Sep 21, 2012 · 14:11 UTC#820
i am very new to F900 unit (UK version) and previously updated my system with 'Hybrid-4001', link below:
http://avic411.com/i...-guide-updated/
I have read couple of pages of this post and realised how much time and effort has been input by Chuck88. So thank you very much in advance. I haven't got complete understanding of 'How to' but i will give it a try over the weekend.
Thanks Chuck88
In the meantime, is there anyone who could advise me if it is fine to use Chuck's file on my current version of software and maps i.e. Hybrid version + Europe Q42011 maps.
Edit: I have also downloaded Chuck's file named "NavMod3.4a.zip" but when I try to open it, i get an error "Cannot open file; it does not appear to be a valid archive". Am I missing some thing here ! *Now resolved*
Edited Sep 24, 2012 by matyana
Posted Sep 27, 2012 · 08:31 UTC#821
Hi Ovalball,
Ive been running Primo 2.0 since it came out with no issues, even running it simultanious with HOBdrive. I don't use TTS or have any waypoints displayed on the map (except favorites) although I do have some raster maps. I remember at one point after selecting the option to show all gas stations and whatnot that it did crash a few times. Also, are you sure the ezrider process is killed prior to the launch of Primo? I'm not sure what else to suggest besides doing a wipe of your My Flash Disk and starting from scratch. Don't we have 200+ MB of ram on our AVICs? It should be plenty enough, Ive read posts where people were running Primo on 64 MB units (can't recall if it was 2.0 however). Odd it freezes on you, usually when I have experienced memory issues Primo crashed and an "out of memory" box popped up. Keep trying, you will get it working. :)
Posted Sep 27, 2012 · 14:27 UTC#822
Hi Ryar
Thanks for the reply.Im thinking it may be my unit which is at fault because I've started to have a few issues running IGO aswell.I think the years of going into test mode has finally taken its toll.I will try going right back to basics when I get a free weekend to spare.Otherwise I will have to replace it.What with ??
Posted Sep 29, 2012 · 02:11 UTC#823
In dash? Hard to say. Can't beat an AVIC f-series. If it is a dashtop you want any android tablet with gps and a mount work very well. Currently running Torque (Android OBDII software) on the dashtop and Primo 2.0 on the in-dash. Once you have dual screens, you can't go back xD.
Edited Sep 29, 2012 by ryar
Posted Mar 10, 2013 · 20:59 UTC#824
Is not possible to remove the button at bottom right during navigation? (sd, off....)
Edit: ok solved! I used search  :mrgreen: .....in custom options i found the solution
Edited Mar 10, 2013 by marmotta
Posted Mar 15, 2013 · 15:15 UTC#825
FIrst, this is a great mod! Everything I could want all in one package. I do have 2 questions though. I got everything installed and working just fine. I am having 2 problems. First, when I change the illumination color to a custom one and set it, when I restart the unit, it goes back to the scanning colors. It wont save the custom color. Second, when I try to change the interface color, it shows all the pop up windows and says that it has been done successfully and asked me to reboot the system. I do it and it is still stuck on the chrome interface color. I have wiped the user data but am still having both these issues. I tried searching for an answer to these two but haven't had any luck. Thanks in advance.
Page 33 of 35
