http://softnews.su/7332-sborka-programm-dlja-navigatora-pioneer-avic.html
This looks to be just what I'm after - but its in Russian ![]()
works 100%, you can change the language on the main menu as well as voice and also you can change the language garmin
Cut paste the web link into Google. When the search responds back, click 'translate'
I have tried it too and I have to agree it seems to work 100%.works 100%, you can change the language on the main menu as well as voice and also you can change the language garmin
I also changed the main UI to English but it would be an awesome mod if it was all in English.
I was referring to the UI being in RussianCut paste the web link into Google. When the search responds back, click 'translate'
The UI IS NOT in Russian! However, I can't see it being incorporated into our mods. The UI is really weird. Our mods are incorporated into the Data.zip for a direct change. In this mod, the original Data.zip is untouched and stock. All the scripts, icons, bmps, etc. are done in UI and subfolders outside of the Data.zip which are found in the IGO folder and a 'System' folder in 'MyFlashDisk' which overrides the original UI. This is entirely different than what we are doing here. I am still trying to understand this process ![]()
Does it work with other models? Has anyone tried it with F90BT?
I managed to change the original UI to English but is all of the modded stuff not in Russian?The UI IS NOT in Russian!
Not the version that I downloaded. It is in 5 parts, then I unzipped it, and all the UI files are in English. I never installed it, just glanced through the UI.
The UI files may be in English but I have installed it and the icons etc are definitely in Russian.Not the version that I downloaded. It is in 5 parts, then I unzipped it, and all the UI files are in English. I never installed it, just glanced through the UI.
That is weird, I dont want to install this as it is something that I want to work with, not use, as the graphics are primitive, can you post a pic?
I'll take some pics later on.That is weird, I dont want to install this as it is something that I want to work with, not use, as the graphics are primitive, can you post a pic?
I like the stock look of the graphics - its really what I'm looking for, but not in Russian ![]()
Check Translator...
Follows THE MFD to install backup. Create a shell-based Avic Net 2.0.3 (allowing access to the Internet); with the navigation and the possibility to use "Cork" services: iGo 8.3 (from the Office Update 3.02) Navitel 3.5″ (Atlas) Avtosputnik 3.2.6 (Moscow), SitiGid 3.7 (no maps), iGo 8.3.4.117940 (skin diMka 1.1.39 map TA Russia), Garmin 5.00.20 (no maps).
Release date: August 2010
Version: AN 2.0.3
Language: Russian
Tablètka: not required
System requirements:
Navigator Pioneer Avic-F 500, WinCE 5 (800 x 480)
Also installed programs: miniOpera, CorePlayer, CheckEngine (for use with adapter OBD-II diagnostic engine) and system utilities.
Screenshots:
it has checkengine obd-ii software installed....Now i really want this mod
me too, also garmin!!
please some brains around here?? please!!
The interface can change the language, but anyone know how you can change the language to mod?
In my case I need to change to Spanish ![]()
has anyone got this to work. it seems to freeze up on the loading screen. the only thing i got to work was the things in the APL4 folder.
I am confused, how can anything work if it freezes up at the loading screen?
The igo in the APL2 folder doesn't load for me. the other igo in the APL4 works fine.
Someone needs to find this russian and pick his brain we need a damn screen off button!!!!!!
oh, and an full English version.
Any one downloaded this mod? If yes is it possible to upload somewhere. Got some ideas with it.
Looking through some of the Russian forums, I noticed version 2.1 was released w/ auto-installer in Dec 2010. Haven't found a download yet.
Release Date: 2010, DecemberVersion: 2.1
Developer: Serhy
Language: Russian
License: Freeware
System requirements: Car Pioneer Avic-F900BT
Coverage Area: Russia
Description: The shell of AVIC_NET Serhy:
Already has in its composition settings (scripts) that is adapted:
- For the use of additional navigation software, the Internet
- And equipment (USB modem) needed to connect to the Internet.
- Also, it should be noted that, thanks to built-in shell hub port GPS (PortSplitter):
You can use the two simultaneously operating naviprogrammy!
Ext. Information: Uploaded not a complete image, but only necessary for installation.
Sam Avic2.1
New maps (IGO8.3) Russia83_NQ_2010.Q2_100908
Wince image without the gyro
Testmode
Additional programs:
Calculator
Hours
CorePlayer
Game
Opera
Weather
Navigation program, modified to work on a pioneer:
Navitel 3.5 (with sound)
Autosputnik 3.2.6 (with sound)
SitiGid 3.7
Igo Primo 8.5.9.142948 (May 2010) (co audio)
Garmin 5.00.20 (with sound)
Just copy the folder to the root of APL4 stick and start the installer.
All by itself will do.
Thanks for download links. I installed on one of my f500 and it worked flawlessly. I was able to change language to English and use most settings. Most mods are taken from this forum and improved upon.
Since russian maps are very small in size they were able to add multiple map options like igo, garmin etc. Main option navigation is completely in russian and highly modified.
It's using checkEngine for windows CE for OBD-II and there are help files in English to set it up.(www.check-engine.ru)
It would be great if someone who is familiar with Russian can help on this with known . all the mods done on this really looks interesting and everything is incorporated in apl4 folder.
