rear view camera options
By cpkdude · Jan 12, 2011in General💬 36 posts👁️ 7,076 views
Page 1 of 2
Posted Jan 12, 2011 · 23:56 UTC#1
I'm thinking of adding a rear view camera just for the hell of it.
So, cost won't be very high. I will likely pick up a camera built specifically for my 2007 Mazda 3 (chinese - Ebay).
These are between $30 and $80, depending on CMOS or CCD.
In order to have the ability to A:) trigger the reverse screen while in reverse, and B:) be able to switch to the screen when in other gears,
how many wires need to be present on the camera itself?
I know that red usually goes to the tail-light power, and black is ground, but what gets hooked up to the screen for full-time viewing?
Posted Jan 13, 2011 · 00:13 UTC#2
Wrong!
Posted Jan 13, 2011 · 00:25 UTC#3
Wrong!
is that your best, constructive answer? I don't mind learning from someone who likes to teach.
Posted Jan 13, 2011 · 00:29 UTC#4
It needs to be powered from the head unit.
Posted Jan 13, 2011 · 00:56 UTC#5
The red lead doesn't go to the tail light, it goes to a ignition switched power source. I don't know what u mean by what gets hooked up to the screen for full-time viewing.
Posted Jan 13, 2011 · 16:46 UTC#6
on another thread, a user complained that when in reverse, an image appeared on the Pioneer. But when he "selected" the rear-view camera, in any other gear besides reverse, he got a black screen.
I would like the ability to have both.
Is that reliant on how many wires come from the camera, or are all cameras created equal in this regard?
And, what would be the correct wiring to achieve both situations?
thanks
Posted Jan 13, 2011 · 16:48 UTC#7
and if the unit is powered solely from the head unit, and not from a tail light, then the Pioneer can display an image in any gear, in addition to automatically switching when in reverse?
Posted Jan 13, 2011 · 16:48 UTC#8
thanks
It most likely means that the camera is powered by the reverse light, so when you simply switch the head unit to camera's input, it still is not getting nay power. Hence no picture.
Connect the camera correctly, and it should not be an issue.
Posted Jan 13, 2011 · 17:31 UTC#9
and "correctly" would be to a constant 12v source?
Posted Jan 13, 2011 · 18:34 UTC#10
no, if the camera is connected to constant, then the camera would be on all the time and would kill your battery every day.
you need a camera that has two wires(power and ground) and a video out RCA, thats it.
ground the ground wire, hook the power wire up to a ACC source (the easiest one is the red wire at the radio) that way every time the car is turned on the camera will be also, then you can select the camera as a source at any time you would like, then there is a reverse wire from the radio that need to be connected to the car so that the radio knows when the car is in reverse and will switch automaticly.
it really is that simple
Edited Mar 02, 2011 by 1loudls
Posted Jan 13, 2011 · 23:03 UTC#11
ground the ground wire, hook the power wire up to a ACC source (the easiest one is the red wire at the radio) that way every time the car is turned on the camera will be also, then you can select the camera as a source at any time you would like, then there is a reverse wire fromt ehradio that need to be connected to the car so that the radio knows when the car is in reverse and will switch automaticly.
ah, that all sounds simple except for the last bit - do you know where the reverse wire from the radio gets connected to? You said "the car". Where on the car.
thanks
Posted Jan 14, 2011 · 01:23 UTC#12
The reverse light.
Posted Jan 14, 2011 · 15:10 UTC#13
yea the reverse light itself is the easiest place to get it at since the camera has to go back there anyway, some times you can find the wire somewhere else but its usually a lot harder to find and you will need vehicle wiring diagrams
Posted Jan 14, 2011 · 16:32 UTC#14
ah, OK. So the Pioneer actually connects to the reverse light, as opposed to connecting to the camera in any way?
Posted Jan 14, 2011 · 18:58 UTC#15
yes
Edited Jan 14, 2011 by 1loudls
Posted Jan 14, 2011 · 19:58 UTC#16
yes
thanks
Posted Jan 16, 2011 · 20:29 UTC#17
no problem and good luck
Posted Jan 17, 2011 · 04:48 UTC#18
I also bought a cheap back up camera from ebay, 2 actually. The first one didnt make after the first time I power washed my truck! The second is the kind that bolts to the license plate. So I ran the red wire to "hot while key is on" black to ground of course. The reverse wire to reverse and tapped into that so I can toggle it on any time not just in reverse. Very simple to do.
Posted Jan 24, 2011 · 16:18 UTC#19
do you remember, or have the info for the one you bought off ebay? That's where I'm looking. Does this brand seem familiar? It's more of a novelty for me, since I haven't backed into anything in many years :)
But if a car-was would trash it, that would be bad.
http://cgi.ebay.com/ebaymotors/MAZDA-3-CCD-NTSC-Car-Rear-View-Backup-Camera-_W0QQcmdZViewItemQQhashZitem3f03be851aQQitemZ270645757210QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
it's a CCD, and I wondered if that factor would improve its chance of longevity
Posted Jan 24, 2011 · 20:13 UTC#20
I doubt it. Its from eBay, is cheap, and ships from China so I would say those are going to be the deciding factors on its longevity, or lack there of actually.
Posted Mar 01, 2011 · 18:49 UTC#21
Rather than starting a new topic. My cam has a power (Red) and ground (Black) wire. I know that if I only hook the red wire up to the reverse light, it will only come on when backing up. Is there a way that I could modify the wires somehow ie (add another wire) so that I could use the cam whenever plus when backing up? I haven't found a good explanation on this.
Posted Mar 01, 2011 · 20:05 UTC#22
Well its been explained a hundred times on here before. Power the camera from the red wire on the head unit.
Posted Mar 01, 2011 · 20:17 UTC#23
If you power the camera from 12v live (with the key on) then it will always have power to it when the keys is on. Going into your nav's AV menu, pick 'Back-up' as the source from the top of the screen. I use this when pulling a trailer sometimes to check the load.
hg
Posted Mar 02, 2011 · 00:55 UTC#24
Maybe this might help. My cam does not have a reverse wire on the harness. Guys don't have to be mean since I'm just getting use to all this.
edit: I saw some how to's on youtube. I get the idea now. Just gotta make sure the cam will automatically show up when in reverse. Gotta look in the x920 settings.
Edited Mar 02, 2011 by ma_ttcald
Posted Mar 02, 2011 · 01:51 UTC#25
The backup wire is on the unit.
Page 1 of 2
