yea, dont worry about it, some times i tend to skip around and miss all the critical info, it happens bro.
so i am underway with this install finally . . . ground is easy, as is finding switched 12v. The mystery is the rear-view wire. I was hoping to use the one in the passenger side harness (grn/blk), but that didn't seem to go well - aka, when I went into reverse, nothing happened. also, the brown input kinda took over the x920, and that's ALL I could look at on the screen.
Obviously, something has gone wrong.
Given these clues, would you bet on a bad camera or a bad connection. Secondly, there is a confusing selection in the camera screen for "polarity".
Any thoughts on which is the correct setting there?
thanks
