HDD unlocking FREE
By providers · Feb 07, 2011in Hacks/Mods💬 84 posts👁️ 82,663 views
Page 1 of 4
Posted Feb 07, 2011 · 01:40 UTC#1
Hi guys
I want to tell you a way to unlock your HDD for free.
So from today you dont need to pay for unlocking anymore...
even better, this solution keeps your data safe.
Yes this look to good to be true, but it realy works.
It look like Pioneer made there own service disk, and you can now download it via this torrent (inside rar file).
remember to seed when you are done so other people can download it also.
This torrent also includes a service manual.
Title: Service Test Disk (STD) for Pioneer AVIC-Zx/HDx
Year / Release: 2007
Supported languages: English
Compatible with: Pioneer AVIC-Zx/HDx
Description: Service Test Disk (STD)
A disc that allows you to test your navigation system.
Best of all, there is a function for removeing the internal hard disk lock
Ext. Information: Advanced - Brochure Service Manual
The procedure to unlock your hard disk
1. Burn "Service Test Disc" on DVD-R disc (+ R does not work)
2. Ignition Key to the ACC
3. STD inserted into AVIC
4. When the disc is inserted, the following title shows "06 INTERNATIO NAL NAVI TEST DISC: GGV1194"
Then the "Test Menu appears"
5. During the "Test Menu", select next page
5. Select option 6 "HDD FLG Set" - p. 214 manual
6. Now the AVIC unlocks the hard disk
7. Return to the main menu by pressing the "AV"
8. On the menu screen "6 HDD FLG Set" will be marked with an asterisk - * which means that the password is temporarily removed
9. Open the display to horizontal;
10. Turn the ignition key to 0
11. Unscrew the two HDD cover T8 screws
12. Now you can connect the HDD to your PC and perform all the necessary updates
14. Replace the hard drive into AVIC and tighten the screws
15. Turn the ignition key to AC
16. The unit starts and the screen is shut. At this point you can click the Eject button and remove the disc into the drive
Press the switch "RESET" (This action is always advisable to do after work in test mode, the prepare the system for everyday use)
17. master password will again be restored to disk.
Happy unlocking
/Providers
Pioneer_Service_Test_Disk (STD).rar
Edited Feb 07, 2011 by providers
Posted Feb 07, 2011 · 05:55 UTC#2
Great find! I read the forum post on RUTracker for this torrent and noticed that the disc is actually for the HD3, not the Z3.
Have you personally confirmed that this disc works in the Z series?
Posted Feb 07, 2011 · 06:49 UTC#3
Hi,
I have not checked the Z Serie, but the service manual are for the Z serie
So im almost sure it works.
Posted Feb 07, 2011 · 16:12 UTC#4
Props to providers for providing the test service disc!!
I have done some testing today on the USA version of the AVIC Z, and I have slightly modified the instructions. Please note that I used a CD-R to burn the image and NOT a DVD-R.
This will only unlock a drive that was shipped in the specific head unit. You can not take a drive from one Avic Z unit and unlock it in a different Avic Z. I will confirm this as soon as I have a factory locked hard drive.
I have also attached a Zip file that contains the ISO image and PDF Instructions to print.
1. Burn "Service Test Disc" on CD-R disc
3. Insert the Service Test Disc into AVIC
-it will say "The media is being checked"
-followed by a title shows "06 INTERNATIONAL NAVI TEST DISC: GGV1194"
-Then the "Test Menu appears"
5. At the "Test Menu", select next page with 'TRK ->' button.
6. Scroll down to option 9 "HDD FLG Set" with the 'PLIST DOWN' button - p. 214 manual and press 'MENU' button to enter setting mode
7. At the "press POS to change flag" prompt, press the "MAP" button
8. Now the AVIC unlocks the hard disk
9. Return to the main menu by pressing the 'AV' button
10. On the menu screen "9 HDD FLG Set" will be marked with an asterisk - * which means that the password is temporarily removed
11. Open the display to horizontal
12. Turn the ignition key to 0
13. Unscrew the two HDD cover T8 screws
14. Now you can connect the HDD to your PC and perform all the necessary updates
15. *OPTIONAL* use MHDD program on PC to disable the ATA security.
16. Replace the hard drive into AVIC and tighten the screws
17. Turn the ignition key to AC
18. The unit starts and the screen is shut. At this point you can click the Eject button and remove the disc into the drive
19. Press the switch 'RESET' (This action is always advisable to do after work in test mode, the prepare the system for everyday use)
20. master password will again be restored to disk. (unless you disabled with MHDD).
Test Disc.zip
Edited Mar 05, 2011 by garrettoomey
Posted Feb 19, 2011 · 02:32 UTC#5
question how did you burn this? There is 2 files.. .mds and .mdf
Burn both as data? or..
Posted Feb 20, 2011 · 05:01 UTC#6
Just upgraded my HD, this worked perfectly, thanks provider :-)
fresh --> Downlad and install ImgBurn or Daemon tools. ImgBurn will probably be easiest. Open the .mds file in ImgBurn and tell it what optical drive to burn the image to and you should end up with a "Service Test Disc" in your drive.
Good Luck.
Posted Feb 26, 2011 · 20:21 UTC#7
can someone tell me how i would benefit from this, please.
Posted Feb 27, 2011 · 01:45 UTC#8
Awesome find ! Thanks for posting up :mrgreen:
Posted Mar 03, 2011 · 05:46 UTC#9
thank you so much!! any other things we can do with this disc? I went to GPS options and it kept saying failed to initialize and now my gps signal is really low or non existant sometimes. Anyway to reset what this disc did?
Posted Apr 11, 2011 · 10:21 UTC#10
great!but iwant a help:how to upgrade my avic-hd3 to z2 via hdd to pc and howto put my music into my hdd
Posted May 03, 2011 · 17:14 UTC#11
Can someone please tell me if the GGV1194 could work for the F900BT/X910BT models?? I will burn an image and test it, but since I can not do this right now (and maybe just by next week) it would be good to know if anybody already tried it.
Service Manuals for F900BT/X910BT mentions either GGV1340 (US) or GGV1322 (EU), but unfortunately I wasn't able to find neither for download...
Besides that, does anyone know if it would be possible to unlock or change the DVD region number by using a Service Test Disk? I tried some mods on the WinCE but later I found out that the DVD mechanism is a RPC-2 type and it seems independent from the OS. I saw that both Head Unit from US and Europe have the same DVD part number, so I assume it should be possible to change the region some way, and probably by software... My hope is that a Service Disk would have such option!!
Posted Oct 14, 2011 · 20:47 UTC#12
hey i have a mac and i have a msg that popped up saying "no application to open file" is there someone else who has a mac or know of an application i can download to finish this project?
Posted Oct 14, 2011 · 21:16 UTC#13
Download the file from my post above. It's a zip file.
Posted Oct 25, 2011 · 23:17 UTC#14
Cool, but how do one make the map and DB update then ?
I've seen its possible to update at HD3bt to HD3-II but how ?
If i want to do all of the above on a new HD is there any software i can dl and if so where ?
Btw. im a total noob just installed my unit today, so i'm sorry if i sound lame :)
Edited Oct 25, 2011 by Dohnerd
Posted Jan 11, 2012 · 15:02 UTC#15
Hey I have a problem a problem with unlocking my HD3 - II. I doing like in the description. I burn CD-R in Nero, CD (UDF/ISO) with test disc.iso. When I inserted the disc to my HD3 displays only the inscription "CD-ROM inserted" and nothing more. The same thing happens when you want to install the software. Please help me because I do not know what to do.
Posted Jan 29, 2012 · 20:09 UTC#16
Dear,
I have ford expedition 2008 with AVIC-XD 1377ZF, is this one working with ur procedure. How I can change NAV software
Posted Jan 31, 2012 · 00:48 UTC#17
Dear,
Your model does not have a hard drive, so this method would not work.
Posted Jul 29, 2012 · 10:26 UTC#18
Hi, I have followed the instructions and all has went well. I have updated my maps etc to 2010 eu on my HD 3. Can anybody tell me how to transfer the telephone data from the old hard drive 2007 maps to the new drive 2010 maps. I have an Iphone and had to do the stuff manually which took a while. If somebody could point me as to which files to copy across. Thanks.
Posted Aug 08, 2012 · 08:10 UTC#19
No Problems. Found how to do it myself.
Posted Oct 31, 2012 · 20:31 UTC#20
Work for the Avic Z110BT? Didnt think this had a HDD but the software has to be stored someplace....
Posted Nov 01, 2012 · 01:52 UTC#21
No HDD in the 110BT. Nothing to unlock. Check the forums for the 110 series.
Posted Nov 14, 2012 · 05:08 UTC#22
i burned the dvd-r and inserted it into the drive and it said " 07 INTERNATIONAL NAVI TEST DISC" v3.000200
it did not say 06 international navi test disc or GGV1194
is that ok? Is it the right service disc to use?
Edited Nov 14, 2012 by jaimbot
Posted Nov 15, 2012 · 13:59 UTC#23
Yes.
Posted Jan 11, 2013 · 17:42 UTC#24
Will this work on a HD3 II unit? (I'm in Norway)
JP
Posted Jan 11, 2013 · 20:53 UTC#25
JP
Yes.
Page 1 of 4
