130BT Bypassed.
By DrBass · Mar 21, 2011in Hacks/Mods💬 51 posts👁️ 40,286 views
Page 2 of 3
Posted Feb 26, 2012 · 20:54 UTC#26
i have an 08 chevy silverado 2500 Duramax and want to know if theres anything special i need to do when doing the bypass because of on star or anything. i already had the HU installed but they wouldnt bypass for me... and my pioneer date is april 2011 i think wanted to know if they made it unable to do the bypass???? i read something on youtube about it let me know thanks
Posted Feb 27, 2012 · 05:09 UTC#27
need anyones input on this gotta get in done tomorrow in hurry thanks
Posted Feb 27, 2012 · 16:49 UTC#28
OnStar has nothing to do with the bypass - except that the Mute wire, which is normally moved to do the bypass, might already be used by OnStar. That would be a problem - only because you need some compatible wire to insert into the "bypass" position in the harness. The Mute wire is the common choice - only because it is normally not used. You'll need another wire to insert instead. Sorry, I can't help with Onstar, never touched one.
Edited Feb 28, 2012 by RonS
Posted Feb 28, 2012 · 05:10 UTC#29
well i had the audio shop put everything in and they didnt use the mute wire and i did the bypass and it works hope everything else works but i dont use onstar let me know if anyone else has done one with on star and thanks for the info and help RonS
Posted Mar 12, 2012 · 05:57 UTC#30
will this work on an avic z140?
Posted Mar 13, 2012 · 03:04 UTC#31
Just letting you guys know,the bypass worked from the z130
Posted Mar 26, 2012 · 02:27 UTC#32
I did this and functions are still greyed out when driving. Is there something I'm not doing correctly?
Posted Mar 26, 2012 · 04:19 UTC#33
You did it wrong or you have a bad connection.
Posted Mar 26, 2012 · 14:51 UTC#34
Confirmed for the Z140!!
Posted Mar 26, 2012 · 14:51 UTC#35
Yup
Posted Mar 28, 2012 · 01:18 UTC#36
I had a shop do the bypass for me. I guess they didn't do it right.
Posted May 20, 2012 · 11:51 UTC#37
One more in the confirm department for Z140 - works like a charm.
Posted May 20, 2012 · 18:32 UTC#38
Same thing with my bypass as Alky181. I did exactly what the Youytube video showed. As soon as I start driving, the ADDRESS touch command goes gray. All is fine when stopped and in gear with P-brake off. However, I do get the message about the P-brake being disconnected.
My unit was already installed by a shop that said they were liable if they did the mod, so I had to do it. The P-brake (light green) wire was already connnected up. I just cut the wire and connected like the vid and left the end running to the P-brake connected.I am thinking that I need to connect that cut lead as well to the ground.
Any thoughts?
Posted May 20, 2012 · 18:51 UTC#39
Any thoughts?
This statement shows that you should not be doing anything install related in your car.
Posted May 20, 2012 · 21:11 UTC#40
Nice advice there "bro"...how about a solution rather than a stupid ass comment. This is supposed to be a helpful forum genuis. I suspect this isn't the first time you got grilled for this kind of posting.
Posted May 21, 2012 · 21:49 UTC#41
Any thoughts?
I'm having a similar problem. Avic z140bh already installed professionally. I've grounded the green wire and moved the mute pin up just like in the video etc and grounded. Functions still shut off when driving. Any thought?
Posted May 31, 2012 · 19:08 UTC#42
If i am using and ms-frd1 harness ( to retain my ford sync) will that mean I cant use the jute wire since I need that for sync? Anyone try this?
Posted Jul 08, 2012 · 00:42 UTC#43
MicroBypass has extra pins for sale with instructions if you don't want to remove the mute wire. I was using mine for onstar, so I needed a pin too. They have the oem pins from Japan.
Posted Jul 11, 2012 · 04:28 UTC#44
this is the exact thread i need.
i'm having problems similar to the last few guys. ford f150 w/ sync, ms-frd1 harness, and the pioneer Z140. used an extra wire for the parking brake bypass. tested it out before assembling the rest of the dash and it worked great. could use full nav functions while driving. then i used the mute wire for the sync and tested it out and LOST the parking brake bypass. why? am i doing something wrong? do i need an extra pin because i am now using BOTH the mute wire AND the extra / unoccupied slot?
someone help me out here. thanks!!
UPDATE:
i pulled the unit back out to see what the deal was. turns out everything was connected (mostly) property; the right wires were connected; wires were grounded appropriately; BUT, the bypass wire had slipped ever-so-slightly from its seat in the pioneer harness and no longer had a good connection. so i pushed it back in, made sure the plastic stop in the harness was in the full lock/down position, and TaDah! it works like a champ now!
good info in this forum. thanks guys!
Edited Jul 14, 2012 by vlcmstnaz
Posted Aug 02, 2012 · 17:14 UTC#45
Check Out the Microbypass.com Website they sell the replacement Pins. there the same for the Avic X & Z. Ive been using them I go thru about 10 every 2 weeks.
Edited Aug 02, 2012 by InstallerGuy1
Posted Aug 21, 2012 · 02:50 UTC#46
Ok this might be off topic, I did the bypass on my z130bt it works great. Wondering though if I can put a switch on the ground wire so I shut the bypass off so it won't work if questioned about it if "someone asks".
Edited Aug 21, 2012 by onevmo
Posted Aug 21, 2012 · 02:52 UTC#47
Yeah this question gets really old. You can but there is no reason to do this. Its not illegal anywhere to have the bypass. Its illegal to watch video. The two are totally different.
Posted Aug 21, 2012 · 02:53 UTC#48
And that's why "someone might ask" if i was and want to show i wasn't
Posted Oct 23, 2012 · 04:06 UTC#49
vblue is right. these are two different things.
so lets say they pull you over.
and if they caught you because they saw you use it, its pretty a done deal. you got the ticket. they would not pull you over if they didnt see you do it in the first place. kind of like they asking you how fast you were speeding? if they pulled you over for speeding your done... its basically a rhetorical question at that point.
now if they pulled you over for something else and ask you if a video is playing while you drove, then you basically say no you were not watching anything. only you can screw yourself by admission during the traffic stop by the officier. plus they can NOT physically go into your car and turn it on. you also do not need to show if it does or does not do it as they never saw it happen before the traffic stop.
Edited Oct 23, 2012 by 949
Posted Oct 26, 2012 · 04:01 UTC#50
Hi guys,
I have an avic f40bt which looks pretty much the same z130/z140. I installed mine awhile back ago and just grounded the hand brake. Everything seems to work, as far as i can tell. I am able to ise the GPS and have video playing.
Only recently i joined this site and i've noticed you guys re-pin this wire and ground it. Why is that?
Page 2 of 3
