Hey guys, was a lurker while scouting the unit before the x920bt (x910bt?). Anyhow, took the plunge last summer on the 920 and had a mostly flawless installation including the bypass. Anyhow, my BT disappeared over time. At first it only happened after my car was left in the 100 degree heat for awhile. I'd get in and boom, my phone wouldn't pair. I figured, ok, doesn't like to be cooked in the sun. No problem, it didn't happen that often. Eventually, a few weeks ago, it stopped pairing all the time.
When I called support, the guy was pretty direct and not sympathetic, but took me through a few troubleshooting steps and when we got to 'connection status' in the 'nav settings' he wanted me to engage and release the parking brake and report on whether the status switched from off to on. Obviously it wouldn't as I've already admitted I'd done the bypass. Not being able to admit that to him though, we ended the call with his advising me to have the installation checked.
From what I could get from him, there was not anything necessarily wrong with the bluetooth. It was just listed as being 'off' in the bluetooth settings page. I was unable to access these greyed out buttons, because the deck uses some kind of switch (can't remember what he called it) that made these (and other, I imagine) menu options available when the deck detected the parking brake being set. The fact that the deck reported the brake as being 'on' wasn't enough to make the settings available.
So, was this BS from a pioneer support guy trained to identify a bypassed (and thus warranty voided) deck quickly? or is this real? Either way, I would suppose that the next step would be to "un-bypass" the unit so that I had stock brake action going on and then go to bluetooth settings and switch BT back on.
Thoughts?
PS: I posted this under BT gone after firmware update even though I lost mine prior to updating firmware. It should also be noted that I updated the firmware this evening as an option of trying to trick the BT back on. Initially, it looked like that had worked, but eventually the BT shut back off on the page reporting it's on/off status.
