cant get the streaming files I captured with real player to work on my 930. they are in mp4 format. tried using handbrake with no results
AVIC-X930BT won't play any video files
I haven't been able to see my pics or play iPhone video since I went to iOS 5.1.1.
5.0.1 worked fine.
Is your encoder h.264. Or MPEG4?
I've found the same same resolution file I've converted (from FLV YouTube) only work in my unit if I choose MPEG4 over H.264.
Even though my manual states it can handle h.264.
h.264 does work but only at a lower bit rate than mp4. h.264 max bitrate stated in the manual is 576kps vs 1000kps for Mpeg4
I had some trouble getting this to work in the begining... here's a screen shot of the selections that have my videos working and looking good.
Cool. I'm going to checkout handbrake. Haven't used it before, but your screenshots make me want to check it out.
Great give it a try but you can emulate the settings in the software of your choice. Just be sure use mp4 and under 1k total bit rate (800k video + audio) and should work out.
Should each of my videos be placed in a separate folder?
One or many doesn't matter.
I was haveing problems playing video on my X8500BHS and i got mine to work with the setting used here. The only diferance is i set source at 1280 x 720. I think the key to getting it to work is setting video codec to MPEG-4(FFmpeg). I also set my avg bitrate to 2500.
They work fine for me. I use handbrake for h.264. I'll upload a small clip to test.
Quicktime also works well with the export for iPhone option.
Download this and give it a try:
As the other have said, this clip works well. I can make clips that work, but they do not fit in the screen perfectly like this clip does. Is there a special aspect ratio or zoom to use to get it to fit perfectly?
When I examine the properties of this samle clip, it says it is 320x128, yet when I make clips of the same dimensions, it does not fill the screen like this one does. Any suggestions?
OK, I got it to fit perfectly. I guess our screens do not like normal aspect ratios. So, if you use a multple of the 320x128 and keep the aspect ratio OFF, it should fit perfectly.
I doubled it and used 640x256 and it looked nice and worked fine.
I Went through all the steps but couldn't get ot working properly. Let me detail what I am trying to do and if any one can help me would be great.
Model : AVIC F90BT.
Trying to : Download Youtube video and play it on the player.
Can any one tell me step by step how to get it converted and which kind of video should I download through youtube HD or normal and wht pixels???
Help appreciated
