@Tail24: I am now downloading the files right now. Very strange, but Azureus Vuze did not want to download the files, but uTorrent does? In any case, now I'll get the test mode v2.3 file.
Avic-F900BT wont boot,cant enter test mode.
Odd since I'm sharing with vuze
Hi you all. I found the topic: A FIX for Euro F900BT that hangs on splash screen with all Euro files needed . I followed it step by step and it solved my problem! Many thanks to whirlwind and tail24 for their many posts, instructions and shared files!
hi, "stuck on system startup in process screen"
my f900 messed up on me last night basically i was trying to update the firmware, which i downloaded and it updated correctly after the update reboot the screen stayed on 'system startup in process please wait', only think i can do is go to AV, i cant change my setting or go into maps either, after a short time the system reboots itself, i have tried resetting via the reset button, eject but still no luck. i may have downloaded a wrong firmware or something im not sure what went wrong, version before the update was 1.900000, map version 01.000800 but after the update i dont know what it is as i can't get into settings.
please help me i would really appreciate it, thanks
Does anyone know how to turn off the camera when the screen is stuck on the "caution, items may apprear reversed" ?
I've tried to reset the system and the screen goes back to the "caution" error message.
please dont double post and hijack threads
Hi guys,
I'm having the same issue as in the first post- avic won't boot and I can't enter service mode (blue screen).
I have all files downloaded however can't figure out what to do.
Could you help?
same problem
I'm also after some help please. F900bt was fine on the way to work yesterday, but when I started the car to come home the unit had a black screen. The button lights lit up for a few seconds and then went out.
Today I tried reinstall the wince image etc. I can get into the service mode (holding buttons, release reset etc) and the unit reads the wince img on the SD card, but it won't write it. It gets to 100% read and then freezes.
Is my unit unrepairable? Any help would be appreciated.
Thanks.
i got the blue screen...but continue to get: press reset button again! What should i do?
Thanks.
Did you ever get it fixed? Mine is doing the same thing now.
same here
Have u guys downloaded update files or have you bought on the internet (ebay)??
My motherboard died. Bought a new on on Ebay.
i thing the problem is IC 610. M30878FJBGP A U3 810B2A2 (PEG446A).
hi,
i've got the some problem as TenneT
it freezes at 100% read, I turned it off, format sd card en put tetstmode, put it back in my f900bt but nothing happens
it does not go into testmode
Somebody help please..
