Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 15 of 49
Posted Jun 13, 2011 · 22:14 UTC#351
We all want to have that possibility. If you can release gps port to be used with other software, then yes - you can help :)
If not, then - we've got a lot of tools, possibilities right now to try to achieve that.
I don't know what F220 is based on. Try to copy TESTMODE.KEY to root of SD and check if it works on your unit.
br
condi
PS. V1.3 to V1.4 UPDATE ready :)
Thank you for your reply :-) I'll try in a few minutes ;-)
Posted Jun 13, 2011 · 22:55 UTC#352
br
condi
This is the AVIC-F220... It doesn't work standalone: it's connected to a AVH-5200BT:
I've just copied TESTMODE.KEY on the SD and inserted it into the F220. Nothing happens.
If the SD is IN i get this:
In
When the SD is OUT i get this:
Out
What can i try?
Edited Jun 13, 2011 by socci4
Posted Jun 13, 2011 · 23:42 UTC#353
v1.4 ready :)
I need help with Part00 - our secret partition! In new ver. there are mountUNmount tools - .exe's to automount or unmount partitions. It works on Part01 and Part02 (NAND and NAND2), but not on Part00! Maybe some missing registry? Maybe bad MountFlags, MountHidden etc? - Info about that misterious partition in DiskRW.
Great work Condi!!!
1.4 working well on my unit.
DiskRW now works, but I have problem to save IMG file- it says couldn't write log file, and SD card full (before it was 3.8GB free) but image is 514KB only, it looks I need full 4GB free space on SD or USB. So I will try with clean 4GB or 8GB one.
Edited Jun 13, 2011 by Ralpharn
Posted Jun 14, 2011 · 07:20 UTC#354
Great work Condi!!!
Yes ignore log error, it will create it also ;) yes, for full image you need almost 4gb, you could also decrease size to be dumped, first 100mb should be our secret partition ;) will investigate it later!
Posted Jun 14, 2011 · 10:02 UTC#355
Condi, I tried with the SD already inserted before the boot, without success. How did you discover the test mode? What is in the testmode.key file?
In the F220 I have the possibility to launch application like photo viewer... Do you think I can use that to enter in test mode?
Maybe in the F220 the GPS port is already unlocked, who knows! But... The first step is to enter in test mode!
Posted Jun 14, 2011 · 10:50 UTC#356
Please try old testmode for other units (TestMode 2.3) maybe from this thread
Posted Jun 14, 2011 · 11:10 UTC#357
Ok, i already did it in the past but maybe it was an earlier version... I'll let you know soon!
Posted Jun 14, 2011 · 17:45 UTC#358
x920bt
What time will help me please
Posted Jun 14, 2011 · 21:58 UTC#359
Nothing happens :-( the F220 si the european versione of the U220...
Posted Jun 15, 2011 · 00:12 UTC#360
in brasil we have a f220 unit too , if u can dump the maps of this unit , i can try dump the brazil maps from a brazil f220 unti and try put into my z110bt, aparenttly the gps software is the same, maybe i can add the missing files and get my maps
Posted Jun 15, 2011 · 01:07 UTC#361
Hey condi , its work perfectly! Good work lets foward! 1,4 ok
Edited Jun 15, 2011 by PatrickFernandes
Posted Jun 15, 2011 · 03:14 UTC#362
thanks u all,,is there a way to free gps port for using IGO SOFTWARE?
Posted Jun 15, 2011 · 07:24 UTC#363
Great to hear that! :)
Its our no.1 objective. We are looking for the solution.. For now - we can't.
PS. 100 post :) !
Edited Jun 15, 2011 by condiczek
Posted Jun 15, 2011 · 17:29 UTC#364
How can i dump the maps? I can't enter in testmode or something similar... :-(
@condiczek: Any ideas?
Posted Jun 15, 2011 · 18:17 UTC#365
x920bt
1. I want to set up the map of europe
2. I want to set up Turkish language
Posted Jun 15, 2011 · 18:41 UTC#366
is iGo the software of choice? I have used garmin and Navigon (iphone) and have been impressed with both of those.
Posted Jun 15, 2011 · 22:46 UTC#367
when we finish, you will can run the software of your preference, today the problem is open the com port of gps, once we can do it , all software will work
Posted Jun 15, 2011 · 22:50 UTC#368
x920bt
hey man, wait a little, at this time we can`t do this things, in a near future maybe, but not now!
try search at the z110bt/130 forum , about the crack of pioneer update, i see something about put the eu maps into a us unit making the update with eu cracked update! by shortfuse member!
Posted Jun 15, 2011 · 23:35 UTC#369
I read through the thread and have been watching this all go down and first thing I wanted to say was thanks for all the hard work. I dabble in SW development, and was wondering if anyone has been able to crack the image and remove parts of it. I assume that on startup of Windows, it captures that com port and won't let us get to it. But that isn't a native function of windows, and we should be able to remove the process that captures the port, leaving it open to us to play with.
Where do we stand? I will be uploading the hack to my Z110bt with 120bt firmware, and I will take a look around this weekend. Condi, where do we stand on finding out the process that is capturing that port?
Posted Jun 16, 2011 · 00:09 UTC#370
I've got read.img file from memory and using ImDisk Virtual Driver can mount them to my PC but
it shows 2 unmounted partitions, and if I mount any of them it says that drive is not formated.
Fat32 partitions can be mount as normal drives.
Edited Jun 16, 2011 by Ralpharn
Posted Jun 16, 2011 · 01:38 UTC#371
We do not know which port is our GPS antenna uses.
We do not know which module keeps this port occupied.
Posted Jun 16, 2011 · 13:19 UTC#372
Its times like these where it would be nice to know a pioneer engineer
Posted Jun 16, 2011 · 14:19 UTC#373
When i try run the pioneer software from Z120 dump into my emulator the debug window show the Software trying open com 7
Posted Jun 16, 2011 · 14:21 UTC#374
Please explain what emulator you used.
Posted Jun 16, 2011 · 16:28 UTC#375
Download Emulator at Attachments! Sorry i can´t attach this , there a error !
contact-me with PM and i send to you!
Just unzip and Click Run.bat
if u have a dump put it into My Dump folder and open in emulator
GPSMC.exe try open Com7 look at photo
Edited Jun 16, 2011 by PatrickFernandes
Page 15 of 49
