on F900Bt they have same looking "unmounted" partition and it contains serial number (with region and model in it) welcome screens, and even windows folder! so.. I think it is very important to read and dump this hidden thing, what software can mount partition after windows bootup has finished?
Is it possible to modify DiscRW program to have default pass to save files to our external media?
I thought the same about default path for saving! I searched for maybe some additional parameters for that app, but its not working. Tried also adding keyboard driver, sip, jotkbd, eurokbd, but none of them worked. Present keyboard driver is working, but only for such keys as: enter, esc, etc. No letters/numbers. Another way to get that data is to get working Storage Manager from control panel. How did you get content of the partition - windows/screens etc?
I'm working now on running newest GpsGate, it wasn't starting, now I'm on the right track!
---edit:
Still no free gps port.. but.. after maaaany hours I've got working newest version of GpsGate - two versions:
GpsGateWINCE.arm.CAB and GpsGatePPC.ARM.CAB. It was very hard, because:
- we cant install .cab's (im working on it..)
- we cant normally run GpsGate.exe (dlls etc. - had to modify a lot of them..)
- we cant run GpsGate without proper registry (error 340), too many entries to write it manually in mortscript, also we couldnt import .reg files - until now! I can successfully import .reg
at last very handy for future modifications.
For now it will not give us working gps - which is propably on com4 or com7(propably that). Few ports are still busy. Busy already after system boot.
From now I think I can get .net framework installed, and try ShortFuse gps utility.
The most important thing for now is also to get to Storage Manager/Control Panel, mount hidden partition and explore it.
---edit2:
I've got some script which will type automatically output-path in DiskRW to read/write rom! Will test it tomorrow! Good night!
