Hi guys! Can you help me to hack my avic F310BT?
It would be a great thing.
your device is different to ours. You better check http://avic411.com/index.php?/topic/31389-f310bt-hack
Oh no.
In that link there is no any useful information.
I'm so tired to have no any information in the internet about my device. I'll just go and kill myself by the wall (((((
Oh no.
try search U310 - it is US version of F310.
are you Russian?
Can you explain it little bit further? I didn't get where this "INFO/My Device/DSK1/Partition Information"...Also interesting thing - check INFO/My Device/DSK1/Partition Information!There is one NOT MOUNTED partition, maybe some pioneers secrets? Maybe some gps/audio/hw related things/apps?
Check attatched DiskRW from previous post!
Ralpharn
you mentioned that we can use scripts (mortscript ?) to start additional programs.
What will trigger the script to start?
best regards
bernd
Ralpharn
best regards
bernd
You dont need to make some extra scripts to run some programs.
You can test/run it with hackmode, and file manager.
Keep in mind that many apps needs to be modified to work with other dlls.
1.3 base works on z120bt
Interesting finding inside EU090BOT.PRG:
Does it mean operator need to push button on keyboard?
Also they have some words that refer to LAN conection, It would be great if we can conect unit to computer by LAN for updates. How to get to this menu on device?
this looklike the bootloader!
are you Russian?
Yes, almost Russian - I'm from Belarus. Whiterussian.
Mouse works but no pointer.
Keyboard does not work. However, Mouse works (no pointer) when plugged into Keyboard Hub.
is possible to use this mod in F20 http://gpssoftware.us/pioneer30.htm
Only if you have F20 F500/700/900.
Yes. you right.Those mods will not work with the F20.
No news??? everyone??? any update??
x920bt could you help me do what I want and I'm using this turkey turkey map of europe in the Turkish language to use the radio frequency set navi
So how's it looking on these units? Is it time to upgrade? Do we have access to me maps?
we have access to a partially disabled WinCE:
5 days from last post from Condiczek...
I hope everything is ok.
Can I use this hackmode to convert my Z120BT to F20BT?
I have CNSD-110FM EU Version. Can I replace existing files on my Z120BT with extracted from SD1\Update\NDATA\NDATA.* (via WinHEX)?
Or may be someone knows how to run CNSD-110FM (2.000) update on already updated to 2.003 device?
I have made fake 2.004 update from 2.003 to bypass password checking (RenewalIFLib.dll patched, in EU090APL.VER changed version to 2.004 and fixed crc of RenewalIFLib.dll). It was successfull updated.
But now I can't run CNSD-110FM EU Update... CARDINFO.cif replaced with US version, in ALLDATA.VER changed version to 2.005, but when I inserting SD with this update there is nothing happens.
P.S.: Sorry for poor English, I'm Russian
Everything is allright guys
Just got a lot of work these days..
- some processes cannot be killed
- mouse works with no pointer
- keyboard doesnt work
- control panel applets dont open
My concern is mainly with the maps and skins. I don't have one of these units so I can't mess around with them directly. Anyone tried putting control panel items on a USB stick and launching them from there to see what happens?
Hey Condi thanks for the update!
Windows boots from an image as i see it, editing stuff in it will not have any effect after restart as it loads windows from that image again. I've written what image file I think it is in my previous post. Unfortunately I haven't managed to decompress it. Damn Windows Automotive 5.5 Basic
--Update--
I managed to decompress the image file with the windows ROM: EU090PLT.PRG with NK.BIN toolset. HOWEVER, before you can use the tools you have to delete the custom header from the file:
ĄZZĄ ÚlŇ‚Ňq EU090PLT˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙B000FFThe file must start with B000FF so delete the above header until B000FF.
After that use the NK.BIN toolset:
I'm not sure if a repacked version of the image file will work, because the bootloader knows the size of the rom, and I don't think it will like a different sized one, also it's a little risky because TestMode might not work afterwards. If anyone has any experience with these, please feel free to share your knowledge
EDIT - USE dumpromx instead. See newer post!
I am able to dump the contents of EU090PLT.PRG from my z120bt.
I have not figured out how to run the bin (remove header from EU090PLT.PRG and rename to NK.bin) in an emulator.
