Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 11 of 49
Posted May 21, 2011 · 20:41 UTC#251
Great work Condi. Will try the new v1.3 ASAP, but for now I forgot my SD card in the car, and it's pouring like crazy outside :)
Try it and tell me what you think :)
Great work Condi!!!
Info from our friend Carver:
As you can see it contains that mysterious AstProc.exe
Also I got recommendation do not mess with EU090BOT.PRG because its look like main boot-loader and error in this file can easily brick device.
Yep, boot shouldnt be touched without full certainty. AstProc could be our curse ;)..
For now we can kill GpsMC.exe and run other version of that app (which should be responsible for gps :>).
That the next thing which I will check.. GpsMC.exe + GPS.dll + GpsTmc.dll.. Anybody got that files dumped from F900BT for example?
I've attached script for running/testing other explorer.exe with other libraries etc. This one in v1.3 hackmode is modified, but I left CEShell.dll unmodified. If I change it to my copy, then it will a)not gonna start, b)start - with oem-info on desktop, but with some problems with icons etc., and of course exploring 'my device' etc still not working. But there is problem with CEShell.dll. So all the other libraries are modified, but not that. If you want to modify exe/dlls - just use hexeditor and change all the names in it - but save the lenght of the file! for example coredll.dll <> change to coredl1.dll or coredl_.dll. The same filename lenght.
Just unpack the attachment, copy 'CONDITOOLS' directory to SD/USB, copy your files to 'WinCE' directory, and run otherEXPLORER.exe.
I've also attached PortSplitter, modified, which is starting. I've made also a script which adds gps related registry from F900bt and then runs PortSplitter.
Just unpack the attachment, copy 'CONDITOOLS' directory to SD/USB, then run 'Port Splitter.exe' or 'RunPSwithGPSregFROMf900.exe' :D
PS. let me know if the attached tools are working ;)
otherEXPLORER.zip
PortSplitter.zip
Edited May 21, 2011 by condiczek
Posted May 21, 2011 · 21:33 UTC#252
Hello.
Thank you for the work done!
I have x920bt
Installation was successful hacking! Upgrading from 1.0 to 1.1 perfectly!
Upgrading from 1.1 to 1.2 is not working.
The process runs fine, but after installing the device continuously restarts again and again.
Please help! What am I doing wrong (translate into the root folder CONDIUPDATE sd cards are inserted into the device)
Is installing updates, pioneer reboots and again and again and again
Posted May 21, 2011 · 21:50 UTC#253
Hello.
I have x920bt
Hi. Upgrade went ok, but propably your card is discovered on the system too slow.
Please unpack attached HMIManager.mscr file, enter pioneers testmode, delete HMIManager.mscr
from unit (/USER/PRG0/Apl/HMIManager.mscr), and copy the new one.
I had to change only 'Sleep' value in script, your card becomes available in system, and it will work :)
Dawgbone had the same problem ;)
HMIManager.zip
Posted May 22, 2011 · 09:44 UTC#254
---moving back to Av.exe - it works better, more stable etc.!
Edited May 22, 2011 by condiczek
Posted May 22, 2011 · 11:12 UTC#255
Hey Condi! Had some problems updating from v1.1 to v1.3. To v1.2 I had to change HMIManager script with the above, because the unit constantly rebooted. After that the unit turns on very slow. It takes a couple of seconds for the buttons on the unit to light up, and then more time for the desktop (or stock software) to show, which is realy annoying. After updating to v1.3 the same reset loop occured. So I just went back to stock for now. Can you please post all the files that are changed on the unit, so I can do a direct to v1.3 hack from stock via testmode. I would also like to try running the hack off Av.exe, maybe that will speed things up a bit.
Edited May 22, 2011 by Tudor Z
Posted May 22, 2011 · 12:10 UTC#256
You're right, even my unit had some problems, and it was about HMIManager.exe.
Working now, got 1.3 on Av.exe. Changing all the updates etc..
--changed. added to first post. give me info if its ok.
Still no GPS signal, but some curiosity - I managed to run TomTom on F30BT :)
So when we get signal - we get iGO, TomTom, Garmin(?), oh yesss... :)
Posted May 22, 2011 · 21:01 UTC#257
Base update 1.3 works. But you forgot about the "Pioneer Software" shortcut, it's still on HMIManager, so it doesn't do anything. :)
Posted May 23, 2011 · 02:26 UTC#258
Im a noob so bare with me please...
A few weeks ago, my Avic x910bt got stuck in a reboot loop with the message saying "Fatal Error"
From my researchon this site, Im thinking i just need to reinstall the firmware?
I dont know what kind of firmware I already have, but if I use your method, will I be able to reinstall firmware 3.1 AND make it hacked?
PS: does having 3.1 mean that I will have the newest maps, and other apps?
Thank you
Edited May 23, 2011 by Afoce707
Posted May 23, 2011 · 03:11 UTC#259
The X910 is a completely different unit and nothing in this thread applies to that unit. You need to view the topics pertaining to F and previous X units.
Posted May 23, 2011 · 17:44 UTC#260
Got it, I'll look into it more. thanks!
Posted May 23, 2011 · 22:01 UTC#261
Hello
any idea if this hackmode works on F500BT !!!!!
Posted May 24, 2011 · 00:17 UTC#262
Hello
You post it to wrong tread. This hack is NOT working for you. but use search, F500 hacked complitely, so you can do almost watever you want.
Posted May 24, 2011 · 02:05 UTC#263
Hello
No.
Posted May 24, 2011 · 12:10 UTC#264
I have a suggestion to ToDo list:
connect usb 3G/GPRS modem to use independent internet access, to load traffic info (for GPS software, that support it).
Posted May 24, 2011 · 14:52 UTC#265
I am thinking about other way to break in to our devices.
First- connect it via USB. we need to run UsbClientSwitch.exe first. This file sits in Windows folder and if we can run it we probably will be able to connect to our devices by straight USB-to-USB cable. But I can't start it.
second option- previous Pioneer devices had Service mod, when only bootloader runs- it is made for repair Windows in case windows is not operational. To enter this mode they had to hold some buttons while switch device ON. It is pretty much as BIOS on PC. So... we can try "brute force" this key combination. if we find this service mode we can download firmware and start to play with EU090PLT.PRG (winCE image)
Third option- in testmode on third screen we have "Program Forced Write" option and in service manual it says that it is designed to "Write / Read Fixed Data" but I am not sure that TestMode works without WinCE.
Last option- Jtag. we have connector.post-51370-0-64274500-1306248757_thumb.png
Edited May 24, 2011 by Ralpharn
Posted May 24, 2011 · 19:57 UTC#266
Added :) yes after we will get gps working, then it will be very handy thing. Like in Navigon in my android phone :)!
1) UsbClientSwitch.exe - you can just change between ActiveSync and Mass Storage mode. There is registry for usb, maybe it works already - you've got to check ;) My unit is installed in car, and there is no indication that I will unmount it ;)
2) I think that even if we delete EU090PLT.PRG - our winceimg, then it should not be totally bricked. Testmode should work. As far as Im concerned testmode is checked before PLT is loaded. Im ready to play with EU090PLT.PRG - test modified, test other etc. But there is one problem - PLT in F30BT doesnt have 'B000F' header of image.. And also dumprom/dumpromx gives us incomplete, corrupted files. I could test simply modified img, with added explorer.exe for example, but we need to figure out how to add some files without messing the image.
3) Yep, good thing to look into :)
Im attaching working DiskRW, there is one problem to read data - we have to point OUTPUT directory, but:
1) virtual keyboard is not working, jotkbd.exe is not working properly,
2) browse [...] button is not working (propably because of not fully working explorer/windows/ceshell),
So first we need to somehow give OUTPUT parameter, and then we can read/write image via DiskRW :)
Also interesting thing - check INFO/My Device/DSK1/Partition Information!
There is one NOT MOUNTED partition, maybe some pioneers secrets? Maybe some gps/audio/hw related things/apps?
PS. Flugwerk wrote that usb mouse is working, anybody has usb keyboard to check with avic?
DiskRW.zip
Edited May 24, 2011 by condiczek
Posted May 24, 2011 · 22:17 UTC#267
i Try ms Desktop 3000 Wireless Mouse and Keyboard , the mouse works but the keyb is dead!! Ps: Work with no arrow! but click right click and move ok but no sow arrow!!
i didnt try with a pure usb wired keyboard , and the virtual keyb not work too.
i search into my emulator its have a drive and registry entry about Keyb while in Avic not, maybe add some reg entry could work!
Edited May 24, 2011 by PatrickFernandes
Posted May 26, 2011 · 01:26 UTC#268
2) I think that even if we delete EU090PLT.PRG - our winceimg, then it should not be totally bricked. Testmode should work. As far as Im concerned testmode is checked before PLT is loaded...
TestMode.exe - uses COREDLL.dll NStandardLib.dll NEventBaseLib.dll GraphicLib.dll NPCommonLib.dll ... So it is winCE programm. So if this archive is 'corupted' you will have brick with probability of 99.99% after reboot.
Also TestMode.exe inside EU090PLT.PRG itself <_<
How to disassemble file EU090PLT.PRG
First 0x200 bytes - header, CRC32 firmware and size.
then 0xC0000 bytes - unknown area.
After that imadge data starting from nb0 - you can use dumpromx to exstract or add files (do not forget -5 key for dumprom/dumpromx )
so... cut block from nb0, do whatever you need, put header back before nb0, change size and crc32 in the begining of EU090PLT.PRG,
Then try to put it in AVIC, not upload - Use update feature - it will be last chance to let AVIC to check this modified file for consistensy.
But it is realy risky. Very risky. As I said testmode inside this imadge, so if somethig went wrong it will brick device.
Edited May 26, 2011 by Ralpharn
Posted May 26, 2011 · 02:11 UTC#269
so... cut block from nb0, do what we need, put header before nb0 back, change size and crc32 in the begining of EU090PLT.PRG,
I agree!
but i wanna make a add-on
i update my unit to z120 bt
in the stock unit two folders pr0 and pr1 are the same
i did the update , its change only pr0, the pr1 still with z110bt software, when i try firt hackmode by condi i cant boot to original av.exe because the hack mode call av.exe from pr1 since the pr0 is the hackmode it self!
"MAYBE" if the image into pr0 could not acept, the avic will call the backup into pr1! there something about a PRG.FLG file into garrettoomey's Z its point to pr0 or pr1 ... but i can try this because in Brasil has no Pioneer Service to this unit!
Edited May 26, 2011 by PatrickFernandes
Posted May 26, 2011 · 02:52 UTC#270
Interesting finding inside EU090BOT.PRG:
U) UPDATE image from SD/MMC card
R) UPDATE Ready Guard OS image from SD/MMC card
B) UPDATE logo from SD/MMC card
D) DOWNLOAD image
L) LAUNCH NAND FLASH image
S) LAUNCH SD CARD image
F) Low-level FORMAT Boot Media
Enter your selection:
Does it mean operator need to push button on keyboard?
Also they have some words that refer to LAN conection, It would be great if we can conect unit to computer by LAN for updates. How to get to this menu on device?
Posted May 26, 2011 · 04:16 UTC#271
..."MAYBE" if the image into pr0 could not acept, the avic will call the backup into pr1! there something about a PRG.FLG file into garrettoomey's Z its point to pr0 or pr1 ...
That would be great! Oterwise we will need a way to delete this RPG.FLG..
Posted May 26, 2011 · 05:53 UTC#272
Dear condi, Dear All
I follow closely your initiative to get full acess to AVIC F30BT. Nevertheless the huge amount of details confuses me a little bit.
Therefore a few simple questions related to Condis's Hackmode v1.3:
1. is it possible to install individual programms (.exe) to the AVIC device?
2. is it possible to make a menu button to start individual programms?
3. is it possible to run individual programms (.exe) from SD-Card / USB-Stick or do they have to be installed on the internal memory?
4. can we switch the CE device / internal memory into mass storage mode and acess internal memory directly from the computer via USB?
Thanks a lot in advance for some easy answers, good luck for a sucessful project, I will keep my fingers crossed!
Bernd
Posted May 26, 2011 · 12:13 UTC#273
1. Possible manually install some programs.
2. No.
3. Yes.
4. No.
Posted May 26, 2011 · 14:01 UTC#274
Ralpharn
thanks for your answers.
Does this mean we can start additional programs only within Hackmode via explorer?
Is there a more convienient way to do so from the shell?
Best Regards
Bernd
Posted May 26, 2011 · 14:11 UTC#275
we can use scripts.
Not yet.
Page 11 of 49
