I have same problem: "There is no applicable program" It was after I updated my x930bt to 4.000 and to 4.010... I put an update again and unit works again. Than I trid to reinstall hackmode again and got same error. Dear Condi can you please check what's going on?
To get it to install with 4.0, you can modify the ScriptExec file...
After the Installation will start in 5s and Sleep 5000 lines, add the following:
COPY -c USER\PRG0\APL\Av.exe SD\PRG0\APL\Av1.exe
COPY -c USER\PRG1\APL\Av.exe SD\PRG1\APL\Av1.exe
This will backup the current AV.EXE to your SD Card.
Then before the REMOVE USER\PRG.FLG file add the following:
REMOVE USER\PRG0\APL\Av1.exe
REMOVE USER\PRG1\APL\Av1.exe
COPY -c SD\PRG0\APL\Av1.exe USER\PRG0\APL\Av1.exe
COPY -c SD\PRG1\APL\Av1.exe USER\PRG1\APL\Av1.exe
You will need to create the directory PRG0\APL and PRG1\APL on your SD card before running this!
What is happening, is when the script runs, for whatever reason, it actually recopies the AV.EXE (Hacked version) back to AV1.EXE. This forces it to put AV1.EXE back to stock AV.EXE.
I have attached a copy of my file for you. You can either edit your existing one or use the one I have attached.
Hope this helps!
