hi there , im new to this forum and im trying to hack my avic 930bt but when i get to the password i got the first one wich is AVIC411 but the second one for the HACKMODE KEY .... thats where i get lost. any ideas ? thanks
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
http://avic411.com/index.php?/topic/36236-x930bt-runs-alternative-navigation/ on this topic you can see the new generation of Pioneer AVIC 920-930-940 hackmode. This software named Pioneerus
so wait i need another password to install the hackmode...i just want to remove the two warning screens
Ralpharn reported, that Igo 8.3 successfully runned at X930 with 4.001 firmware and Pioneerus. Work sound,gps and original shell.
Any thoughts on deleting files in Hackmode v2.2? I'm working on the Navi.exe hack, but I'm unable to delete the file in the Windows Fileshare. It gives me the prompt saying "Are you sure want to delete this?" Hit Yes, and it clears the prompt but nothing happens, no file deletion. Running on an x940 on 4.000.
That's pretty cool.
Thank you Condiczek, works perfect on my F20BT with the CNSD-310FM EU 2012 update!
all i have to do after update to "CNSD-310FM EU 2012" was to copy the PLG0 folder to PLG1!
like the description in your first post:
I have an AVIC-F10BT and from what I read, is compatible with the f20. can you give me the steps from start to install everything if you please? Thank you. I also I have installed the view. cnsd310fm. thanks
This may be a rookie question, but how do i install Garmin to work with Hackmode?
Hi. I have f30bt updated to f40bt. Can I instal defreant map Qatar. Medal est
Can anyone tell me how to fix this problem on a Z130BT? It currently says:
"Program Start up error." There's a small "6" in the bottom right corner of the screen.
I'm afraid I've bricked my device. Even a simple confirmation from someone would be helpful.
Anyone??
I instaled hacks on my unit x930bt but don know where to go still can't get into my unit with out the password l
Anyone??
Does anyone check this board anymore? Just looking for a little bit of guidance on why my Z130BT began a boot loop and then when I restarted the car, I got the above error message. Any help would be greatly appreciated.
Most of the people that started this thread or contributed to it have moved on or no longer have this unit.
Thank you, Vblue42!!
Not working on Avic-X850BT get an error that state cannot enter test mode
We need new testmode.key.
does the hackmode install works?
Does this work on the F-220?? anyone have try to test this on the F-220?
hope some1 can help me out to update my F-220.
Cannot find many information how to update my F-220 ![]()
plz pm message me .....![]()
cheers
I'm fairly new but old to this forum. I'm in the military and I've had my z110 since 09'. I've been overseas a couple time so the only upgrade I've made was from 1.000 to 1.001 if I'm not mistaken. I've read through most of the forums but they all seem to reference upgrading to a 14 from 120 or 130. so my question is, how do I go from the free firmware upgrade offered through Pioneer to the 140 software without any issues and is there a link to the software download?
After hacking my F940BT.. what can i do?
nice work !!!
does it work for the pioneer F900BT ??
cheers
bizdad
Whats up fellas. New guy here!
First I want to say awesome work guys! Its amazing what can be accomplished if minds are put together like what has happened here. I cant wait to see what the future holds for these mods/hacks!
So im kind of embarrassed that im going to be asking for help on my first post but I cant figure out what I did wrong or what happened. My Z130 is stuck on the rear view camera and will not get off that screen. The radio plays and I can adjust volume and stations but that is all. I originally had it set to display the rear camera at boot up which would explain why that is the first screen that pops up but now its stuck there.
Ill explain the steps I took to screw my self
I downloaded Condi's HACKMODE v2.21 - AUTOINSTALL.zip
extracted to a folder and then passed everything over to an SD card.
inserted the SD card into the Z130
everything went smooth and my unit rebooted asking if i wanted to enter hacked mode.
i entered hacked mode and just browsed through everything.
i removed the SD card, placed it back in my computer and copied all the files from the autoinstall.zip back into the sd.(no clue why i did this)
inserted SD back into Z130 and it went through the whole hacking process once again.(oops)
it all went smooth again and the unit rebooted asking if i wanted to enter into hacked mode.
i entered hacked mode and messed around with it again but nothing was changed or altered.
i removed the SD card and rebooted the unit
unit rebooted but got stuck at the rearview screen.
its now stuck there and nothing i do will kick it out of that screen.
so does anyone know what could have happened? is there a way i can get out of the rear view screen? Is there a reset button on the unit somewhere that i can just press and reset everything? or is there a way i can re-install factory firmware and settings to start the unit fresh?
I hope someone out there can help as i use my unit mostly with bluetooth streaming ipod and pandora. hope i didnt screw the unit up. i would really hate to have to listen to the radio only from now on ![]()
Thanks in advanced!
ok so after unplugging the unit, it boots up to splash screen and give me an error. something about av.exe missing from prg0 how do i fix that? i dont have a backup FYI
well i ended up fixing my problem. since i did not have a backup i spent around an hour reading threads on here hoping to find av.exe with no success. what i did was i downloaded the firmware update from pioneer and located av.exe in the update. transferred it over to my sd card and then transferred it to the unit. problem solved.
now, can anyone point me to instructions on what all you can do by hacking/modding the avic units? can we get rid of the annoying warning screens?
There's this for starters: http://avic411.com/index.php?/topic/35523-remove-caution-nag-screen-bypass-hack/
You'll need a hex editor though. I haven't had a chance to try it yet since my Z150 doesn't seem to want to boot into test/hack mode so far.
