Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 39 of 49
Posted Aug 19, 2013 · 13:21 UTC#951
How do you access WinCE on the z110bt ?? And also can you place the files there you need to change such as the platform version. I applied a z140bt upgrade and my unit currently still has the look of a 130bt even though in the service screen it states 4.0000. When i boot into test mode the platform version states 3.0000
Posted Aug 25, 2013 · 05:11 UTC#953
How to set the language to English carozeria avic mrz90?
Posted Aug 28, 2013 · 22:10 UTC#954
Please! What is password for hack mode.key?
Posted Aug 29, 2013 · 01:30 UTC#955
Please! Read the first post of this thread.
Posted Sep 21, 2013 · 15:52 UTC#956
AVIC-F950BT radio tape recorder
HACKMODE v2.2 will work?
Posted Sep 22, 2013 · 22:19 UTC#957
Go with v1.4
Posted Sep 23, 2013 · 02:44 UTC#958
Go with v1.4
 thanks
Edited Sep 23, 2013 by gmaker
Posted Sep 28, 2013 · 14:08 UTC#959
Go with v1.4
It isn't launched, gives out an error.
CAUTION
Testmode Failed Starting
turn off ACC
Posted Sep 29, 2013 · 01:29 UTC#960
CAUTION
turn off ACC
Could be because you don't have the right TESTMODE.key file.  There's another one somewhere in the forum.
Posted Oct 06, 2013 · 08:52 UTC#961
Help!
Make for AVIC-F950BT the testmode.key file.
Any file from a forum doesn't approach.
Thanks in advance
Posted Oct 14, 2013 · 07:52 UTC#962
hi all,
i have a question. I installed igo primo on my pioneer avic f320bt. Everything works perfect. Only tmc. Whitch port and baud works tmc on igo primo. In igo8 u have a automatic search. In primo not. Can someone help me.
Posted Oct 21, 2013 · 21:42 UTC#963
anyone ever get "error, installer files not found. is the sd inside the device?" please help me. i have no clue what else i can do.
Posted Oct 22, 2013 · 12:27 UTC#964
Hello guys
I have forgotten my Password in my Avic F940BT, and I can not start the radio, because at the beginning of the password directly held quest. how or what do I do so I reset the Password?
Greetings from Germany
Posted Oct 23, 2013 · 09:45 UTC#965
going to test it on a F940 this weekend!
Posted Oct 25, 2013 · 19:14 UTC#966
Hi All,
after running the auto install and remove the password.dat file my keyboard is disabled and most of the features in the menu are disabled... anyone a clue on how to fix this?
Posted Oct 25, 2013 · 21:48 UTC#967
Hi All,
Remove?  Why did you remove it?  I believe the system expects to find the file and, if it doesn't, it locks up the unit.
Create an empty password.dat file and put it back in the folder.
Posted Oct 25, 2013 · 21:52 UTC#968
I bought it from the internet, and the person told me there was no password on it but unfortunately there was a password,.. so I removed the file to gain access...
will try to put an empty file in that folder tomorrow morning ( its 11:52 PM here)
Edited Oct 26, 2013 by mightymike1988
Posted Oct 26, 2013 · 05:45 UTC#969
So far no luck, will try to put the original password.dat file back and see if it makes a difference.
but please keep your suggestions coming.
if it fails is it an options to create a dump out of a F930 (all the directories etc) and then copy it back on the F940? (my other car has a F930 radio)
EDIT:
Just tried the Original file which contains the password but it does not even ask for a password.
I even checked the log files, as far as they are written in several directories, but no error or what so ever.
the weird thing is sometimes after rebooting I get the question if I want to set a password, and if I say I want to the keyboard is disabled,...
I also though I saw 2 files in the NAND/SYSTEM/SECURITY directory, but their was none before I copied the password.dat file.
I cant remember the name of the other file.
could someone create a dump of their F940 and provide me the files?
Kind Regards
Posted Oct 26, 2013 · 13:19 UTC#970
Have you properly connected the parking brake wire? Check in your connection settings in "Navi Settings->Connection Status->Parking Brake" to make sure it's "On" when the parking brake is pulled.  The keyboard is always disabled if the parking brake is not pulled to ensure you're not typing while driving.
Posted Oct 26, 2013 · 14:15 UTC#971
alright will check that  asap, sounds like a legit reason,.. the only function from the menu I could enter are the sound settings and A/V settings. all the navigation and keyboard stuff was disabled
Posted Oct 26, 2013 · 14:36 UTC#972
MAN U ARE THE BOMB!
I tested it on the table with a PSU... never thought of the handbrake signal cable
Posted Oct 30, 2013 · 18:34 UTC#973
Hello, did you donate 5$
F930BT my device sd card giving you copied the file to the device plugged v2.21 hackmode took place predicate, he said, and came to the green screen. there is no applicable program screen but then stayed to help me.
I sent a picture.
Posted Oct 30, 2013 · 21:52 UTC#974
I sent a picture.
If you would have read the many many many many many many many many many many posts made about v2.21, you would have never touched it.  This thing screws up units.
Try to put a PRG.FLG file in the USER folder.  If there's already one, try to remove it.
ADMINISTRATORS:
Are any administrators in this forum reading this?!  Please add a SERIOUS warning about the dangers of v2.21 and strongly suggest readers to use v1.4 instead or, hey, remove v.21 completely!  We're the ones stuck with helping users who fell in the trap of using v2.21.
Posted Oct 31, 2013 · 07:18 UTC#975
How to turn back to normal ?
Page 39 of 49
