Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 38 of 49
Posted May 28, 2013 · 20:28 UTC#926
Is it possible to run the AVIC F920BT?
I tried to run it and installed it great, but the installation does not start.
Can someone write step by step how to do it (as you can do it)
Posted May 31, 2013 · 16:44 UTC#927
I have got a AVIC-F840BT.  Will this hackmode work on that mode?
Posted Jun 03, 2013 · 10:32 UTC#928
downloading is possible , but when unzip i get the question password
somebody can help me ?
Posted Jun 03, 2013 · 10:42 UTC#929
As written on the first post, "PASSWORD: avic411"
Posted Jun 08, 2013 · 15:26 UTC#930
Confirmed working on x940bt.
Posted Jul 01, 2013 · 18:21 UTC#931
Hi All, new to this have read upto page 40 so far.
I have a F930bt and want to change the nav software.
My question is is the F930BT the same thing as the X930BT?
If so which forum should i be using? to find out if i can change the software
thanks
Andy
Posted Jul 16, 2013 · 15:02 UTC#932
When begin to install, it comes up caution screen telling test mode failed starting. can somebody help?
Posted Jul 16, 2013 · 21:36 UTC#933
If you're talking about the initial red screen, it's not an error but just... a red screen!  Wait a little and the installation will begin shortly.  If it's really an error, then perhaps it's a compatibility issue with your unit.  On which unit are you trying to install it?
But be warned that HackMode v2.2 can be a devil in disguise.  Many people and terrible experiences with it (including me).  I strongly suggest you use TestMode v1.14
Posted Jul 21, 2013 · 19:26 UTC#934
This password stuff is bull. If it had only a four digit code option it may have been a little easier to remember. It has the whole alphabit plus 0-9 who is gonna remember what the hell they put in 3 years ago. Lol. I still have not even got hackmpde to download.
Posted Jul 23, 2013 · 17:27 UTC#935
Is this workable on a AVIC-X850BT?
Posted Aug 02, 2013 · 04:20 UTC#936
Many thanks for the file Condiczek!  My battery was unhooked to do car work. The AVIC asked for a password which I'm sure I NEVER set!?!?  Your post saved me via a friend of mine.  So grateful!  Would buy you a CASE of beer if I had a paypal acct. . .  All the best to you!
Posted Aug 03, 2013 · 19:24 UTC#937
Figured my issue out, downloaded the auto install for Hackmode.
With version 1.4 it came right up in test mode, I recovered my password and am all set.
DEF WORKS! THANKS A MILLION!
Posted Aug 05, 2013 · 16:18 UTC#938
Hi there,
tnx to condi 4 hack!!!!   I've an F940BT so ..the question is:
1) i backed up my original files:OK
2) when i'll install CONDIHACK and..if it'll works....what can i do with this???
can i upgrade my maps??? can i install another navi software??? if yes...hoe can i launch it, once installed???
many tnx
regards
Posted Aug 05, 2013 · 21:58 UTC#939
Hi there,
many tnx
regards
Well, the basic usefulness of CondiHack is to have access to the internal files of the unit.  You can copy, delete and open files including the file that holds the password (most useful for that).  So, yes it's good to keep a copy of the files in case whatever goes wrong, but you won't be able to do much else with it (ie. it will not upgrade maps or other firmware)
The tool lauch itself.  Just copy the files in the root of a SD card, pop it in your unit and turn it on.  I also strongly suggest you use v1.4.
Posted Aug 08, 2013 · 21:54 UTC#940
How can i put the software on a SD card to unlock my Pioneer X930BT.. It's asking for a password but I don't even remember it.
Posted Aug 09, 2013 · 15:09 UTC#941
You obviously need a SD card writer.  You download v1.4 of the tool, copy the files in the root of the card, turn on the unit while the card is inserted and go fetch the password as indicated in earlier posts.
Posted Aug 09, 2013 · 16:15 UTC#942
Condi's HACKMODE v2.21 - AUTOINSTALL works perfectly on my F10BT but the wallpaper is somehow disconcerting showing "Condi's Hackmode v1.4" as you can see in this picture. I still have many things to learn as, for example, how to show the keyboard on screen in order to run the terminal. And, of course, I long for the GPS signal in order to run OziExplorer ;-)
Anyway thanks a lot for the hack!
Posted Aug 09, 2013 · 21:53 UTC#943
For some reason I cannot seem to get this, (not very computer savy) I have tried downloaded the 1.4 onto my SD card, and transferring it into the unit. I have the x930bt. Can someone please tell me what I am doing wrong? Im trying to delete the password like many others on here. Can someone please try to walk me through this step by step. Ive spent several hours trying to figure this out when it seems to only take 5 mins. Anything will help,
Thanks,
Posted Aug 10, 2013 · 12:45 UTC#944
Thanks,
1) Wipe your sd card and copy files from "Hackmode v1.4 base" on it
2) Insert to unit and boot up car, then it will bootup in testmode
3) Once in testmode, the only buttons and actions that will be needed to navigate the screens are the following:
    * HOME - escape/cancel/go back
    * MODE - enter/select
    * Volume down (left) - move selection on screen down
    * Volume up (right) - move selection on screen up
4) Move the selection on the screen down to #11, File Maintence
5) Press MODE and you will enter the File Maintence screen
6) Select User -> system -> security -> password and do a Text dump of this file.
7) There is only option on this screen that you you are concerned with here, a text dump. You do not have to move the selection around, just press MODE to perform the text dump.  The password that the unit is locked with is displayed near the top left of the screen
Posted Aug 14, 2013 · 03:49 UTC#945
Hi All, I have the AVIC F20BT Australia model and had version 2.003 (APL Program 3.001000) on my unit. I downloaded Condi's HACKMODE v2.21 - AUTOINSTALL and unfortunately bricked my unit. I then restored it by copying the one folder (with the larger filesize Navi.exe) and this kind of saved the unit. The map search function did not work after this and my 2011 map did not install (as I suspect that the registry has already been updated with the details). In my exploration today I had some severe finger-trouble and deleted the STARTUP folder of my unit. So, now it displays the Pioneer badge, and luckily I can control the radio from my steering controls, but that is about it.
A couple of points:
- I am not a pro to this kind of thing, but that does not mean that I am illiterate. PLEASE DON'T think you are the cat's whiskers and take me out for exploring, yes, I do not know everything, but if you have criticism, keep it to yourself, you are not helping.
- When I loaded the Autohack I did not have a back-up of the folders and everything on the unit as I did not expect my unit to be bricked. Again, the latter part of the top sentence refers if you have nothing nice to say.
I am thus humbly coming to the post as a last resort and requesting help:
- Does anyone have any sound and un-condascending advice, please?
- Does anyone have a backup of their Aus unit that I could beg off them to restore my unit?
- Have anyone played with eliminating the NAV NAG SCREEN on Aus units as yet?
Your help will be greatly appreciated.
Edited Aug 14, 2013 by JohannBisschoff
Posted Aug 14, 2013 · 12:02 UTC#946
A couple of points:
Yep, bricking units is what v2.21 usually does.  I have no freakin' clue why they keep it available.  We keep telling people to stay away from it, but when they come here, it's usually because it's too late.
When I ran v2.21 and also screwed up my unit, I solved the problem by simply deleting the PRG.FLG file.  You might want to try that.
I did the anti-nag nav screen and it works great (x930bt).  Can't live without it :)
Posted Aug 16, 2013 · 02:21 UTC#947
Thanks Lyverbe.
I did exactly that and that is where I had the finger-trouble and accidentally deleted the STARTUP folder.
If I may, you (Lyverbe) or anyone else, can you please check what files are in the Startup folder and let me know? I will see if I can then replicate this folder and put it back on the unit - maybe I will then be able to get somewhere at least.
Thanks for helping out...
Posted Aug 17, 2013 · 17:32 UTC#948
Need help my system in rendered useless. I applied condi's 2.2 auto install to my z110bt upgraded to z140 and now it gets stuck on a message that states " There is no application Program"
Please help !!
Posted Aug 18, 2013 · 12:23 UTC#949
Please help !!
...and here's another one...
Download and "install" v1.4 the same way you did with v2.21.  After taking a backup of it, try deleting the file PRG.FLG located in the USER folder and reboot the unit.
Administrators
If it can't be fixed real soon, get rid of that bloody v2.21
Posted Aug 19, 2013 · 01:27 UTC#950
Is there any way to access windows to copy file ?
I was able to delete the PRG file using the testmode however I still get the same message.
Page 38 of 49
