@bird333 Yes! You too can brick your unit by using condi just like @mauricee93 in the post above yours.
Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
hello,
i want to unpack the zip file but i need a password to unpack it!
can you help me please
i have pioneer AVIC X940BT i am out side USA, HU FM radio tune only odd numbers after decimal can convert in to international mod tune in to even numbers
hello,
Read the first post
Hello,have a complete backup F940BT is the same as for F40BT.Greeting Uli
plz send me F940BT backup file if you have .
thanks
I have a X930BT I installed the hackmode. Didn't delete or change anything.
Then a day later went to use hackmode again so DL the files again and it reinstalled condi now my unit is stuck on the pioneer screen. Any way to fix?
I can go into hack mode still.
didn't took the time to read enough pages to learn that i only needed the testmode.
i think a have a problem now because after hackmode the system doesnt start up anymore. it says i shouldt manually replace av.exe file.
(the password text dump went ok after all, but now im affraid i have a bigger problem)
F930bt
somebody can help me explain it step by step?
gr. Bas
edit: allready worked.
with testmode i went to file manager/user/apl and deleted de av.exe file in pgr0 directory AND pgr1 directory (both 8 kb files)
then i copied the av.exe file (3,?mb) i found here and copied it to the folder user/apl/pgr0. done in seconds and worked right away.
thank you guys for making this topic.
thanks men
I have an issue with this hack.
I had a F930Bt unit with the firm 6.0 recently updated, and EURO maps 2015.
Then I sued Condizec hack, it did start and automatically started the script, so when restarted the unit there was no acces to the file manager, just a banner stating that there is no operating system or something like this in three languages.
I can hear the radio and the controls still work so I need some help.
Thanks in advance.
EDIT: I used the script to undo Condi's Hack and the AVIC went back to life.
Thanks.
what is the hack mode key password? avic411 isn't working for that part
the password is avic411
I have no idea why people keep responding with "read first post" how hard is it to just give the damn password?
Hello ;
İ Have Pioneer X930BT
İ Tried HackMode . Now it is not working. Insufficient video uploaded for the first
1.Can you upload Full video narration someone .
2.Some Body Can You Send Backup Programe.
Thanks..
Hello,
Same for me, the password is not working for "PRGx.FLG"
I have a F860bt
Hello ;
Thanks..
What???
in italy we say... "vuoi anche una fetta di culo?"
C'mon,
enter in testmode with a FAT32 formatted (cluster16k) sd and "supertestmode file" on it, put a fake PRG.FLG file into the USER folder.
It will force the reading from PRG1, and you'll boot again in normal mode.
There's no a backup program, only gramine salis
Hello,
I have a F860bt
what do you mean?
PRG.FLG is a ZERO byte file, you can create it by your own.
Pioneer AVIC HACKMODE by Condi
IMPORTANT! FOR NOW WE STILL CAN'T USE OUR UNITS GPS WITH OTHER SOFTWARE!
WE CAN RUN THE SOFTWARE LIKE TOMTOM, GARMIN, IGO ETC.,
BUT GPS IS NOT WORKING (NO SIGNAL, GPS PORT BUSY..).
WE ARE TRYING TO FIGURE IT OUT TO GET IT WORKING..
V2.0 HAS BEEN RELEASED! THX TO PIONARA FOR FINDING GREAT NEW POSSIBILITIES,
SOLUTION FOR DECODING/ENCODING TESTMODE WE'VE GOT NOW
AUTOINSTALLING HACKMODE!
COMPATIBLE WITH F40BT, X940BT, Z140BT ETC.!
JUST UNPACK HACKMODE TO SDCARD, PUT INTO DEVICE
WAIT AND VOILA!
IMPORTANT - SINCE WE'VE GOT LIMITED KNOWLEDGE ABOUT ALL THE COMMANDS
AND ITS SYNTAX IN PIONEER SCRIPTING - V2.0 WILL WORK ONLYIF YOU HAVE PRG0
AND PRG1 FOLDERS, FOR NOW THERE IS NO SCRIPT-CHECK FOR THAT.
Finally we've got access to new Pioneer units!
After many tries, many scripts, I think that
its proper state to be released.
SO FAR CONFIRMED TO WORK ON:
- F30BT (tested by me
- X920BT (thanks to Krms!)
- X930BT (thanks to Ralpharn!)
- Z110BT with Z120BT firmware (thanks to PatrickFernandes!)
- F920BT (thanks to Tudor Z!)
- F20BT (thanks to wikke!)
- Z130BT (thanks to uglyb0b!)
I'm not responsible of any damage/brick,
so all of this you are doing at your own risk.
Its working on my unit perfectly,
but its not 100% sure that it will work on yours!
FOR EDUCATIONAL PURPOSES ONLY!
THERE IS NONE OF PIONEER SOFTWARE INCLUDED,
THIS 'HACK' IS MADE WITH FREE SOFTWARE,
= NO COPYRIGHTS ARE BROKEN!
On the new units standard testmode with windows explorer
is not working. Funny is, that on the newer units
there is no even explorer.exe!
Fortunately we've got GGS1080 with TESTMODE.KEY,
which is working on F30BT, and other units also, I think.
But plain Pioneers Service Mode is not handy and 'usable' for us.
To hack Pioneer device I used Pioneers 'service mode'.
OK, so everything what we will need is in the attachment.
Below are detailed instructions, but in few words
we need to delete Av.exe, and copy hackfiles to its place.
INSTRUCTIONS:
HowTo backup/use Pioneer UI - Video by JasonH!
pts. 1-9 = BACKUP:
- download the archive, unpack it to root of your 'SD',
- instert SD to your AVIC, Pioneer Service Mode will appear,
**navigating in service mode is little confusing, you've got to get use to the interface,
- move down and enter FILE MAINTENANCE,
- go to USER, select COPY on the menu,
- move up, and go to SD,
- select PASTE on the menu,
- once it finish - BACKUP IS DONE.
- now hold EJECT button for 5s to get to sd card, take it and connect to pc,
- copy USER directory somewhere safe on your computer and delete it from SD,
- insert again SD to AVIC, go to 'USER/PRG0/Apl' and delete Av.exe file,
**you've got to delete it first, because service mode will not overwrite files!,
- go to 'SD/CONDIHACK', select ALL on the menu, and select COPY,
- go to 'USER/PRG0/Apl' and select PASTE on the menu,
- get out from FILE MAINTENANCE (home button),
- reset - turn off and on the unit - enter again service mode,
**afaik its good to boot it again to service mode, I had few times problems with copied files - once they just disappeared after rebooting directly to system,
- go to FILE MAINTENANCE, 'SD', and delete TESTMODE.KEY,
- reboot unit, and done
you can now delete CONDIHACK directory from SD!
To get into HACKMODE you need to have HACKMODE.KEY file on root of your SD.
HACKMODE.KEY is empty/dummy file to easy operate between hack/normal mode.
When Pioneer is booting it will search for HACKMODE.KEY file.
If the HACKMODE.KEY file is on root of SD - it will boot hacked, to file manager.
If the HACKMODE.KEY is deleted/renamed - it will boot to normal/stock Pioneer software.
Also if you have already turned ON AVIC (and for example car engine ON also),
then you can easly jump into HACKMODE - just insert SD with the file,
AVIC is scanning SD every 15s, when it will notice SD with the file,
it will quickly reset and after few seconds you will be in HACKMODE!
Its handy, you dont have to turn off the engine!
And one more thing - you can easly jump out from HACKMODE,
just by closing file manager! After close it will run standard Pioneer software
(also it will not scan for the key in every 15s! after restart it will be back).
Thats all for now. I wanted to give you nice mortscript menu,
but it just doesn't working. Many of commands doesn't work.
It was very hard to get everything working, the devil is in the details!
But after many hours of bricking and unbricking my device, here it is - the HACKMODE
Thanks guys for all 'good luck' words
If you have any questions then just ask.
HACKMODE was checked only on my device, so please be careful in any actions,
Please check if it works with other models!
NOTE FOR UPGRADED FW UNITS:
If you've got upgraded from lower model unit,
like Z110BT to Z120BT, and hackmode
is not working correctly (cant run normal mode),
then probably you've got only PRG0 with new version
of firmware, but PRG1 is with old version!
You will have to:
- make another copy of your backup PRG0 directory,
- rename unmodified copy of PRG0 to PRG1,
- delete PRG1 from the avic,
- copy prepared PRG1 to avic (should be with same content as PRG0),
- install HACKMODE normally like in instructions above the note!
Oh and one more thing - please dont get me wrong, I share it free for all,
but if you want to buy me a beer, then I will drink for you
And as abb1 wrote on his topic - any donations will be greatly
appreciated, but they are by no means mandatory! 'buy me a beer' via paypal
DOWNLOAD: attachment below
PASSWORD: avic411
CHANGELOG:
[28.09.2012]
v2.21:
- small bugfix/typo in script for USB
[27.09.2012]
v2.2:
- compatible with SD and now USB also,
- additional check if the hackmode is on the device already,
to not to get two copies on one device
(prg0+prg1).
[27.09.2012]
v.2.1
[24.09.2012]
v.2.0 AUTOINSTALL!
- installer now check which PRG0/1 is in use, and install in correct path.
- bugfixes, no more 'red screen' because of odd syntax of pio's script
[13.06.2011]
v.1.4 BASE - INSTALL VIA TESTMODE:
- added (modified) working DiskRW utility,
- added (modified) working GpsGate tool - shortcut on desktop (GPS IS STILL NOT WORKING!),
- added (modified) working RegEditor - finally we can import .reg files via mortscript!
(example: Run("\NAND\PRG0\Apl\HACKMODE\Regedit.exe", "-s /SDMMC/your-regfile.reg"),
- .reg files are now associated with new RegEditor! just double-click on .reg file to import!
- added TextFiller tool (in CONDITOOLS directory),
we don't have keyboard - script will automatically
type your text to desired textfield in 10s - edit TextFiller.mscr!,
- added utilities to mount/unmount 3 partitions od Disk1 (Part00 = ?, Part01 = NAND, Part02 = NAND2)
(credits goes to RubinX [cinus] - thx!) - found that app, can be useful,
i've just adapted it to our avic's and made modified copies for oher two partitions,
- added some simple, nice wince wallpaper
- added some (modified) dll's to above apps,
- and some other i don't remember
[20.05.2011]
v.1.3 BASE - INSTALL VIA TESTMODE:
- moved HACKMODE back from HMIManager.exe to Av.exe,
- moved addon apps to seperate directory ('NAND/PRG0/Apl/HACKMODE')
- added (modified) working SirfTech utility,
- added (modified) working Task Manager with process killing feature,
- changed the way to enter hackmode - now you can choose between normal/hackmode on boot,
- and some other i don't remember!
[20.05.2011]
v.1.3 UPDATE FROM v1.2:
Changes via AUTOUPDATE!
moved addon apps to seperate directory ('NAND/PRG0/Apl/HACKMODE')added (modified) working SirfTech utility,added (modified) working Task Manager with process killing feature,changed the way to enter hackmodenow you can choose between normal/hackmode on boot,
added some (modified) dll's to above apps,and some other i don't remember!
[08.05.2011]
v.1.2 UPDATE FROM v1.1:
!!!!!!!!!! WHEN UPDATING DEVICE WILL REBOOT 5/6 TIMES !!!
!!!!!!!!!! KEEP ON WAITING (FIRST REBOOT ~38s, LAST ~25s) !!!
moved HACKMODE from Av.exe to HMIManager.exe
(propably main exe of Pioneer software),added empty directory on desktop with name of HACKMODE VERSION,
(will use it on future updates for 'version check')
[08.05.2011]
v.1.1 UPDATE FROM v1.0:
Small change - via AUTOUPDATE!
replaced FileManCE app with other one, more usefull
(works copy/paste, all files are visible).
FIRST INSTALL v1.0 via standard method,
then copy CONDIUPDATE to root of your SD/USB,
insert it to device, it will run and reboot 'blink' three times, and done!
[08.05.2011]
v1.0:
Works with both SD and USB! just connect hdd or pendrive
with HACKMODE.KEY and enter HACKMODE like before!AUTOUPDATE feature - no more deleting Av.mscr
via inconvenient Pioneer Service Mode.
When new version will be released, you will just copy
'CONDIUPDATE' directory to root of SD/USB, insert it,
and it will automatically update the HACKMODE!!
FROM NOW ON I WILL RELEASE SMALL PATCHES/UPDATES to this version!
[06.05.2011]
v0.2:
with windows ce explorer! of course not everything works,
but we've got desktop, shortcuts with FileMan and Restart,
its getting more and more handy!
another small step to achieve the target!!
[04.04.2011]
added alternative version with filemance instead of total commander!
the only difference is other file manager! - in attachment.
To change from other version just delete Av.mscr and cecmd.exe,
then copy new Av.mscr and FileManCE directory to /PRG0/Apl/.
(special for users who had an issue with rebooting device with total commander!)
, sorry for bad quality, sunny day hereI show iGO8 software running, keep in mind that gps port is locked for now,
(I will take a look at this), HACKMODE is entrance to further developing
Done List:
- HACKMODE access,
- Windows Explorer (not fully working..),
- autorun when SD inserted (scanning for HACKMODE every 15s),
- USB HACKMODE (SD&USB both working now),
- AutoUpdate - all future updates autoinstall with small patches,
- better File Manager with working copy/paste,
- Registry Backup Tool (in this post),
ToDo List:
- get working GPS signal/port,
- fully working Windows CE,
version info of HACKMODE in windows,- crack/modify wince img - EU090PLT.PRG?,
- crack/modify EU090BOT.PRG - to pass modified wince img EU090PLT.PRG? (maybe not needed),
- in-script check for fw updated units (PRG.FLG related),
- internet browsing via bluetooth from mobile? with Internet Explorer?,
- usb mouse (and propably keyboard) are working - enable mouse pointer?,
- change ShellFolders - Desktop directory to NAND, to get permanent not-erasing on every reboot desktop? (need registry/EU090PLT.PRG hack..),
- run emulated image of our devices on PC,
- integrate different GPS software instead of stock pioneer into the system, it should work with standard Player, Bluetooth etc,
- connect usb 3G/GPRS modem to use independent internet access, to load traffic info (for GPS software, that support it).
...any suggestions?
br
condi
Moderator Note: This has not been updated since 2012 and has a very high likelihood of bricking modern units. DO NOT install without a full backup. Testmode is currently recommended in place of hackmode.
Thank you thank you!!!! I just unlocked the X930 BT in my wife's car. Awesome!
Condi's Hackmode v2.21 also works on avic f940bt?
Hello to all!
I need your help i have Avic F550BT Version 1.43.
i have a problem enter into Testmode i try Condi Hackmode etc. but it wont enter.
Help plzzz.
Hello i have a problem the first extraction code works, but there is no second to decompress the zip condo's can you help me please ?
Hello,
I am a new member and I read with great interrest the topic.
I have an AVIC-F930BT.
I would like to just get the testmode function.
How can I do to enter in the TestMode Menu ?
Do I have to push on different buttons on the F930BT, or do I have to download a file ? If yes how can I download the necessary file ?
Thanks a lot for your help.
Regards
What is the hack mode password?
Thanks guys, its nice to hear good words
I managed to run some apps, TCPMP player, iGO8, Mireo Cardinale, and other gps software works too. New mortscript is not working, like some other software also, i think because of lack of some libraries/dlls. Windows in this units is very 'handicaped', there is no explorer.exe, control panel cpl's are not running etc.
But thats not important, not a big thing. It will work
I will make some scripts which will run some custom software/menu if proper files will appear on sd/usb.
For now I must get rid of av going front after ~30s.
When everything will work as I want to, then of course I will release full solution
Hey im trying to use the v1.4 on my z110bt, i downloaded the file and drug it onto my sd card but idk what else to do from there? when i double click and open the test mode it says registered to: and registration/activation mode: im super confused on what im supposed to do i just need to reset my password because the guy i bought my truck from never told me about any password
Stop using this hackmode and delete it. Search for the password reset thread instead.
Hopefully you haven't ruined your unit with hackmode as it does hack your system. There is no need to do any hacking.
