Seems like the test mode exists.
Procedure:----------
• Insert CARD1 into the PND and press Reset
Ok, but were can i get the CARD1???
Is anybody knows, where to download it?
I'm looking for it
Does anyone have service manual for F310BT/ U310BT ?
Can anyone get it from here?
http://www.smpcshop.com/AVIC-F310BT-AVIC-U310BT-AVIC-F320BT-p-9192.html
Uh, I think you guys mean the new Condi Hack.
http://avic411.com/index.php?/topic/31534-condis-hackmode-v01/
I tried it with no success. I unpack the files to my SD card and then insert it into F310BT.....and nothing happens.
Any ideas?
Look what I've found in service manual for F310 U310:
How to Use TestMode
Jig No: GGV1345
Startup procedures
1. Store the TestMode folder that can be found inside the TestMode folder on GGV1345 to directly below the SD card.
Note : “ Test Mode †folder must be on the SD card root.
2. Download a ID file from the Service Site and copy the file to the “ Test Mode†folder on the SD card.
3. Attach the PND into which the SD card containing the program has been inserted to the main unit.
4. Turn ON the BUP and ACC of the main unit.
5. Press the Reset button.
6. TestMode will start up automatically.
I have the GGV1345 files but the problem is ID file. How to get or generate it?
How to Use TestMode
Jig No: GGV1345
Startup procedures
Have you tried standard TestMode 2.3?
GGV1345 has got TestMode directory with NNTestMode.exe, like in TestMode 2.3.
Try it ![]()
Ok, I'll try
Tried testmode 2.3.... no success again.
Any ideas how to get the ID file?
I think that you need special-named empty file to get into TestMode?
There are some key files in TestMode 2.3 like:
63D21BEFE088433dBE3CF942347464C7,
164C549550B84211BA8C4B84AC5C0081,
etc.
You need the correct file to get access to TestMode.
There is available firmware for F310BT, you can search
for someone who maybe took off the key from fws?
Another option is to modify firmware update with my prepared files,
to get hackmode, but its risky without having access to standard pioneers testmode!
br
condi
yes is real to start test mode on 310bt if anyone can do anything with a files from internal memory i can put here a test mode files to start them and is run with this files in test mode. put the test mode file from archive on sd card put this card in f310bt and push reset. and is done is test mode
I will try it
Great it works
Now It is time to think about alternative navigation software and top menu
Does anyone have an idea?
yes i was try alternative menu from f220 and is gone but navigation don't work because a programm can't run a gps port but is runing igo and alot of programms and i have make a images of internal disks is anyone who can make a programs for this unit?
Can you tell me the way you have installed alternative menu? ( with files if possible)
I tried to run Navitel - it works but doesn't see gps port too ( Seems like I have seen the solution somewhere... will keep looking for it)
i was say is runing alternative menu but a navigation doesn't work now we must make all for launch programms this folder is alternative menu for f220 from this we can make a alternative menu for f310
but i don't know how to do this all!!!!
Try asking from F series forum. Seems like they are able to help us
i go to tri it
can anyone try the hack mods from z series because is the same named files on updates? i cant because tonight i must go in vacancy and my wife make me a kube head
Hi , I need backup files PRG0 and PRG1 from f310bt , any one can help me ?
thank's
