Give me your emai
I'll send it to you
Give me your emai
I'll send it to you
if u wont u can download them here http://www.4shared.com/file/7vV6pcKz/f310bt_prg.html
hi. i did the testmode. its in my understanding, that this thing loads an "reduced" version of wince 5.0 so it runs few applications.
when i tried to run tomtom navigator, it found libraries are missing. i've load some dlls i've found on the net, but no success.
so, how did you manage to install the tomtomnavigator, or the igo8 in this unit?
thx
Hello!
I tried a test mode by Charlie F310BT and it worked successfully. WinCE loaded it and after I closed the window test, i've run the card Igo Primo, worked well, found the GPS receiver is not reset in an hour as I walked through the city. I tried to install MioPocket but do not remember anything. After each reset, simply disappears everything else on the card. Also I run and TestMode 1 of GGV1345 and we tested display, microphone, buttons, everything! What to do to retain settings? I just want a map for Romania. To a Pioneer dealer it cost 250 euro , double the buyng price of the unit!!!
uite ce o sa ti spun pana no sa avem stickul cu updatul cnsd 130 no sa mearga nimic deoarece asa e structura programului el automat porneste navigatia pioneer cand voi avea continutul cnsd 130 totul complet voi continua sa lucrez cu instalarea unui meniu alternativ de tipul avic.net dar pana atunci o batem in cap deoarece toti sunt sgarciti si nimeni nu vrea sa divulge de unde lau descarcat desi nimeni nul poate instala fara media cod dar eu am reusit sa trec de media cod dar nu am restul continutului pentru a continua lucrul asupra programului asa ca daca ai continitul da mi un link de unde sal descarc si imediat cum il am lucrez in continuare si ti dau instructiunile cum sa l instalezi fara media code
asta o sa fac, o sa rup torentele. cel mai nou am vavut ca este 239fm , varianta 2011, care are update nu numai de harta ci si de soft. ar deveni un fel de f320bt
chiar si cu cnsd 130 e deja un 320bt dar nu o gasesc nicaieri in torrenturi pe filesharinguri nu e pur si simplu o caut si eu deja de vro 2 luni succes cum dai de ceva spune astept
poti face ceva cu cnsd 110fm?
cnsd 110fm eu il am de vro 2 luni dar e pentru alt model e pentru z11o american
Hello!
which is primo. you can upload without cards. primo software only thank.in test mode is not mode button.briefly tested igo8 and tomtom with me is okey,primo 1.2 is not
Does anyone have service manual for F310BT/ U310BT ?
will this work on a f320bt?
the test mode is same, yes is must go
topcu58, would you mind explaining how you ran tomtom from testmode please ?Thanks. Somniacwhich is primo. you can upload without cards. primo software only thank.in test mode is not mode button.briefly tested igo8 and tomtom with me is okey,primo 1.2 is not
I can not english , I use google translator .
Unlock with TestMode_by_charlie.rar (94.32K),
tomtom for wince 5 on sd
that you can find in google search.
only disadvantages MODE button does not work with the unlock,
Radio is running background.
someone has a solution for MODE button ??????????????
Can someone can copy the My Flash Disk folder and post it here (US version)
Has anybody try Garmin Mobile XT for WinCE 5.0?
I made it work (Garmin mobile XT) but have to enable gps with gps spliter. Does anybode know com port and boud for this device (u310bt)
topcu58,
I've tried every version of tomtom for CE 5.0 on the SD card but I can't get it to work.
It freezes when I choose a voice during setup.
Where did you get the tomtom software from ? (I already have appropriate maps).
If you can talk me through what you did to get Tomtom working I will find a way to run it with the mode button and post here.
Somniac.
topcu58,
Somniac.
http://www.megaupload.com/?d=FZTCBED7 PW: thanks
Ok trying the update I screwed up the unit, I need the contents of the "My Flash Disk" folder from a US version unit with either version 1.0001 or 1.0003 if anyone can post it or sends it to me by email, I will make it worth your while.
I can give you the contents of europe if you fit
I tried the ones you posted earlier, but now everything is in another language and the unit doesn't allow me to change it to english
bump, come on! it takes less than 10 minutes
as I said I will make it worth your while
topcu58,
thank you for the link ! But I'm afraid it still does not work for me.
The problem is that the UniqueDeviceId in navigator.bif shows as '**********' (asterisks) after I try to start tomtom the first time.
There is no 10 digit code for me to use in the activator.
It could be because I'm using a f320bt.
Anyway I'll keep searching for the answer and then start on the "mode button" fix once I have tomtom to run from the avic menu..
Somniac.
