Anonymous said:Actually, you're both wrong, I don't touch ANY switches, nor do I lose ANY functionality...I'm not doubting that you're little flasher thing works, but the relay I have works flawlessly, and has NOTHING to do with the lights, and you must be mistaken about the internal motion sensors, either that, or this relay takes that into account...Hate to break it to you, there's a better way.
Anonymous said:Marc said:I don't know about flicking lights, or circuit boards, or soldering, but the guys who work on my car made a relay to bypass everything...He said it was only about $30 in parts, works perfectly....Now if I can just disable the splash screen and figure out how to UL a data disc I'll be happy....I imagine any good audio shop can do the bypass as mine was only the 2nd install they had ever done.....
To add to what ducatiboy said, your audioshop really doesn't test properly. Had they tested, they would see that they've limited much of your functionality unfortunately. I would use the flasher bypass and undo those relays, or just leave the relays on all the time and install a flasher bypass. The relays are not worth the headache you will face.
More than likely they wired up the relays to flash the illum wire then. Not sure why you are making this into a "contest," we're all here to learn from each other. If you can post schematics and explain why yours is a "better way" we'd love to hear it, though I'm not sure how a bunch of relays is better than a $30 solid state device, again though, I'm all ears, please enlighten us poor souls.
