Updated 2011 maps
By ill.die.trying · Aug 09, 2011in Hacks/Mods💬 83 posts👁️ 59,518 views
Page 3 of 4
Posted Dec 10, 2011 · 18:18 UTC#51
Just in case that you are interested, I found this post about the Navteq 2011 Q2 Maps for North America.
http://gpsundergroun...g-unlocked.html
I tested with FX 3.1 on a F90BT and works great, in my area Navteq seems more accurate.
Just FYI.
That is great, but is there a torrent somewhere for this? It will take two days to download all three files unless you BUY a premium upgrade for Link-Safe :(
Posted Dec 10, 2011 · 19:26 UTC#52
check back in a day.. the maps are like a moving castle since they are getting whac-a-mole'd... they are behind a few levels of redirection..
also, you may want to do a search for a torrent called "q1uscan2011"
Posted Dec 11, 2011 · 17:27 UTC#53
I finally got the Navteq 2011 maps installed. Comparison of Navteq VS TeleAtlas 2011 maps:
The TA maps have been nicely updated. The hwy signs now have route numbers on them as well. Also, there are many updated speed limit signs here now in Canada. New roads that have been constructed here are also now showing up in these new maps.
The Navteq maps do not really have any changes in them. Still no hwy signs are present that I can see. New roads have been updated, but that is it. Here in Canada, Navteq maps have always been more accurate, especially when on Rural roads, but that is now changing as TA is catching up in that dept, and the TA maps have more features (such as hwy signs and exits).
Using both, I would definately recommend the TA maps, however, it is definately wise to have both on the system, in case one is lacking the street in question (which has happened with older versions of the TA maps)
Edited Dec 11, 2011 by abb1
Posted Dec 11, 2011 · 20:01 UTC#54
Will I need an updated DEM file or Can I leave the DEM folder empty?
Posted Dec 11, 2011 · 20:43 UTC#55
Highway signs do work for me, and exit numbers too, the only thing is it seems to have few speed limit information, but i have not yet compared to TA, so I'm not sure if this is true. I will verify and comment back later. I guess it depends on where do you live, I would say try to get the latest maps from both and try then to see what works for you one provider might be better in some areas than the other.
Also, it looks like TA has more POIs, so for now I'm using Navteq maps with TA POIs.
Edited Dec 11, 2011 by forbitel
Posted Dec 13, 2011 · 21:40 UTC#56
any links for euru maps?
Posted Dec 17, 2011 · 17:58 UTC#57
Highway signs do work for NT maps, however, not the same way as the TA maps. Using NT maps, I only see hwy signs in major cities such as Toronto, Montreal. However, using TA maps, I see signs for EVERY exit on major hwy's all across Ontario. The hwy signs are there in NT, just limited.
Posted Dec 25, 2011 · 19:38 UTC#58
Unfortunately no links are working, torrent or otherwise. Can anybody assist?
Posted Dec 25, 2011 · 22:30 UTC#59
does the update work on a x930 ?
Posted Dec 26, 2011 · 05:23 UTC#60
no you want to look at CNSD-210FM in x-series forum
oh wait. you said 930.. what, does this not have 2011 maps?
Edited Dec 26, 2011 by pionara
Posted Jan 23, 2012 · 00:12 UTC#61
the piratebay.org link is a torrent for those that needed it as a torrent
Posted Jan 26, 2012 · 00:42 UTC#62
None of the links work. Anyone have a new link or a different place to obtain Map updates? BT900
Posted Jan 26, 2012 · 00:54 UTC#63
I used the Piratebay link last night. Worked fine
Posted Jan 26, 2012 · 20:58 UTC#64
how do i install these maps on f700bt w/fx3.1. step by step would help. thanks.
Posted Jan 28, 2012 · 05:38 UTC#65
didnt work for me
Posted Jan 29, 2012 · 23:19 UTC#66
Thanks, torrent link is still working. I'll seed to 2x ratio
Posted Feb 07, 2012 · 01:03 UTC#67
Posted Feb 12, 2012 · 19:27 UTC#68
www.gpsunderground.com or use spotnet !!
Posted Feb 18, 2012 · 20:57 UTC#69
Hello,
I'm new to this and would really appreciate some help. I have already updated my firmware on my F90BT from pioneer but i need to update my maps. Since I haven't done this before, I've been reading some of the post and I have downloaded the torrent file. Do I also need the hacked ezrider?
Also how do I back up my unit so if my update goes wrong I can go back?
Thank you all in advance for your help.
Posted Feb 19, 2012 · 00:07 UTC#70
How about the Q3s. Can we get a torrent for those?
Posted Feb 25, 2012 · 19:20 UTC#71
Thanks to those that seeded for the torrent. I am seeding as well and will continue to. Also seeding FX3.1 for anyone that needs it.
Posted Mar 01, 2012 · 02:38 UTC#72
Sadly, doesn't appear to be seeded at the moment. I would be happy to leave it running for a week or so, if someone would seed long enough for me to get them.
Posted Mar 26, 2012 · 13:26 UTC#74
Has anyone done this with a modded AVIC? I used to be really involved in the community but My AVIC had been running so great to the way I wanted it I stepped aside for awhile. I have checked back in and Daftia's new mod looked amazing so am running that rhather then the variations of the ones I combined. Does anyone know if I can plug this ezrider in instead of his or do I need to go in and mod his?
Posted Apr 27, 2012 · 20:32 UTC#75
Does anyone have detailed instructions on how to update these maps on x910bt also will it work on stock fw from pioneer?
Page 3 of 4
