CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 2 of 11
Posted Aug 24, 2011 · 11:40 UTC#26
Hi to everybody. I'm Luk, a newbie from LUgano (Switzerland).
I'm just trying to download this file....so long :(
I have a Pioneer avic f20bt, europe version...
How to update it with the new maps?
It's available a torrent file`?
see ya
Did you see post #16 in this thread? Since you have a f20bt, start at step #10. If you have specific questions or don't understand the steps then ask. These instructions are a little "sparse". You should probably browse several of the related threads to fill-in some of the missing details. Like the format of the fake password. Just do some reading. Good luck.
Edited Aug 24, 2011 by RonS
Posted Aug 24, 2011 · 15:34 UTC#27
but if i have already updated the device to 2.003, I had to to this crack too?
Posted Aug 24, 2011 · 16:18 UTC#28
You need to install the hacked software in the 2.004 patch, regardless of whether you installed 2.003 or not. That is what allows you to get by the unique password verification when you install the V3.00 upgrade.
Posted Aug 24, 2011 · 17:01 UTC#29
understand....nut:
There is always a risk of bricking your device!!!
it's that real?
Posted Aug 24, 2011 · 17:18 UTC#30
understand....nut:
it's that real?
If you don't feel comfortable, just wait a while. The procedure will eventually get better documented and you will have more confidence when many others have successfully done it. I suppose it would be possible to brick your HU - but not likely. Biggest concern would be if you somehow lost power in the middle of it. Make sure your battery is fully charged. Don't touch your ignition key while it is installing.
Posted Aug 24, 2011 · 18:30 UTC#31
I will do with the engine switched on...
Posted Aug 25, 2011 · 00:51 UTC#32
when is the usa version gonna be avaliable for download?
Posted Aug 25, 2011 · 03:02 UTC#33
As soon as you buy it and post it :)
Posted Aug 25, 2011 · 06:24 UTC#34
Nobody has the US yet???
Posted Aug 25, 2011 · 11:27 UTC#35
All is OK for my F-920BT
2.003 ->2.004 cracked
30 min update with the CNSD-210FM SD (when asked say "PASSWORDPASSWORD")
Thanks to PeterMmX tiemen26 and others
Posted Aug 25, 2011 · 22:53 UTC#36
but this will work with avic f20bt too?
and I had to use CNSD 210 FM o CNSD 230FM to update my f20bt european to maps of 2011??
Edited Aug 25, 2011 by lukas78
Posted Aug 25, 2011 · 22:59 UTC#37
i can't download srefanski 2.04 crak
and if I click on the CNSD 230 FM I will download 210FM???? that's a mistake?
Edited Aug 26, 2011 by lukas78
Posted Aug 26, 2011 · 06:46 UTC#38
It's updated now - my mistake. CNSD-210fm is the correct version.
StefanSki crack attached in post 1 and here: AVICZ110BT-2.004.zip
Posted Aug 26, 2011 · 13:59 UTC#39
2.004 done...but if i go to info, the system tell me that the version is 2.00000000000 ?
tonight i try to do 210fm... :rolleyes:
Posted Aug 26, 2011 · 14:10 UTC#40
Did you follow the instuctions in the 2.003 update - on how to display the CORRECT Application Version number?
Check the version number of your current software by completing the following steps:
1. Press the “HOME†key
2. Select the “Settings†tab
3. Select “System Settingsâ€
4. Select “Service Informationâ€
5. Press & hold left upper corner of the “Service Information†screen for a few seconds
Edited Aug 27, 2011 by RonS
Posted Aug 27, 2011 · 08:02 UTC#41
Merveillous!! I do the update...everything work fine...
Now I had to do the step 13:
bluetooth update...
if I do the first bluetooth update, the navi says if i wanto to update the firmware from 3.11 to 3.0 it's that right?
then I do the update to the 3.22?
Posted Aug 27, 2011 · 12:41 UTC#42
bluetooth update...
YES - Exactly! Update with SD1 your 3.11 to 3.10 and then 3.10 to 3.22
Posted Aug 27, 2011 · 13:01 UTC#43
fine..now i go to update th ebluetooth too :D
can I make an other question?
I plug an Hard disk of 500 GB, USB 3 (and is well recognized...)
but if I go to usb, I can't see the song and the directory alphabetically ordered, hot to patch it?
Posted Sep 02, 2011 · 05:15 UTC#44
Step 7. Download EUROPEAN version of CNSD-110fm from THIS website: http://linkcrypt.ws/...r919151s0xxj509
How on earth do you use that link for downloading ? all that i can see is that it downloads a program named iLivid Download manager ? and can't see what to do with that :-) please help :o
Posted Sep 02, 2011 · 05:34 UTC#45
http://linkcrypt.ws/dir/r919151s0xxj509 it asks you to click on the circle with the correct answer and then it brings you to download 30parts so i don't understand what kind of problem u have. If u see a pop-up window just click on the schliessen in the top right corner (it means close in german) and then u will see all 30 parts. I have just checked that now and it works perfect.
Posted Sep 03, 2011 · 18:14 UTC#46
yea i see that now, i did not think that the circle was the way :) just seemed like another pop up ;D
but anyhow, I thought it was free to download?
Posted Sep 03, 2011 · 22:21 UTC#47
Hi Friends.
I have got Avic-F9220BT
Platform Ver: 2.000
Application Ver: 2.003
Version : 02.0000
Bluetooth Ver. 3.11
The map version is older version of my country. I want to update CNSD-210FM but my device ask me password. How do I update?
I have to put " X:\Update\USER\PRG\EU090APL.VER(StefanSki 2.004 crack file)" ?
Please help me.
Posted Sep 03, 2011 · 22:28 UTC#48
Jh121069 - it IS free!
Armylmz - yes, you have to install stefanSki 2.004 hack and then update to cnsd-210fm using passwordpassword as a password :-)
Posted Sep 04, 2011 · 00:04 UTC#49
Wrong SD card please insert to correct SD card message on %98. What can I do?
Posted Sep 04, 2011 · 02:49 UTC#50
Since the first torrent is totally un-seeded, I wasted a couple hours and downloaded all 30 parts to create a new torrent.
This will be seeded up for a while... after that, it's on you guys to keep it up.
CNSD-210FM SD.zip
Edited Sep 04, 2011 by Wrathernaut
Page 2 of 11
