CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 4 of 11
Posted Sep 11, 2011 · 15:57 UTC#76
Hi giuseppe, the only thing I did was follow the steps that Dr Mong wrote a little higher, you get off the 2003 version, to put it in SD, you have to format a FAT32 SD and record whatever you want, as long do the same. Installs, then get off the 2004 version that are 2 files, paste thefolder to overwrite the 2003 version and installed this version in the 920bt.
Finally, to install the maps you put the 3 files from the SD 1 and SD to install, it will ask for a password that is "passwordpassword" and are already installed. To update the bluetoothfirmware put the folder in the SD 2 SD, and install it.
It is best to follow in the footsteps of Dr Mong is best explained step by step. # 68
how do I download software from linksave map, I need to register or is there a torrent link?
Posted Sep 11, 2011 · 16:49 UTC#77
In the explanation of Dr Mong # 68 you have to go to the link mapping software and downloadthe 32 parts, I did it with jdownloader.
Posted Sep 11, 2011 · 21:20 UTC#78
One question, anyone know if the maps have radar?
Thanks.
Posted Sep 12, 2011 · 15:35 UTC#79
Can't get the Upgrade to firmware 2.004 to work. i'm sitting on a mac an i just downloaded the firmware update from pioneers homepage, because i can't se the exe file.
and then i copied the 2.004 crack and replaced the to files. But my f20BT keeps saying- failed updating, try again.
But i can put in the CNDS-210FM but the password= PASSWORDPASSWORD doesn't work. Any solutions?
Posted Sep 12, 2011 · 16:06 UTC#80
What is the difference from the first post I downloaded the file NCDS-210FM composed of 30 parts, then I found another file NCDS-210FM with 32 parts, there is difference between them, I should be fine for the update also first.
Edited Sep 12, 2011 by giuseppe
Posted Sep 15, 2011 · 19:05 UTC#81
I thank all of you, the 'update my F920BT perfettamente.Grazie succeeded.
Posted Sep 17, 2011 · 13:16 UTC#82
Hi I have exactly the same problem "failed updating, try again" Anybody a tip how to solve this ?
Posted Sep 17, 2011 · 13:39 UTC#83
Usually, assuming your files are not corrupted and are in the correct directory, the problem is the SD card. Try again with another 4-8GB SD freshly formatted FAT32.
This is a common problem with all the updates and has been asked and answered 100's of times.
Posted Sep 17, 2011 · 14:15 UTC#84
@RonS SD card seems not to be the problem, I have tried 3 different SD cards. AVICF20BT starts updating but after 15/15 installs it says "update failed - please try again" So I think theres something wrong with the software, I used the 2003 from official pioneer and the 2004 update
Posted Sep 17, 2011 · 15:57 UTC#85
i did the same. different SD cards.
Posted Sep 19, 2011 · 17:05 UTC#86
i dont get it... i did everything from the posts above , started from 2.000 and ended with 2.004 so the cracked part from 2.003 to 2.004 appear to have worked. but then when i put in my microsd with the : Firmware, Update folder and file: CARDINFO.cif into my avic-f920bt i dont get any popup saying it will update the europe maps or anything... the bluetooth upgrade independed works perfect and does its magic.. but the important thing for me the new maps installation dont give a response..
who knows what i am doing wrong???? i use the same kingston 8gb sd card with witch i did the upgrade firmware 2.003 > 2.004 earlier :( please help
Edited Sep 20, 2011 by Sentic
Posted Sep 20, 2011 · 19:31 UTC#87
Hi Guys,
For the record.... it works perfectly on the ...
AVICf-F9210BT
I upgraded the unit in my car this morning, thanx everybody for the info!!!!
Grtz Alex
Posted Sep 21, 2011 · 08:47 UTC#88
Thank you for the fine instruction. Works on mine Avic F20BT without problems.
Edited Sep 21, 2011 by bclaus
Posted Sep 24, 2011 · 07:21 UTC#89
Make sure the files are not in the "SD1" folder on your SD card. They need to be seperate. Basically just open the SD1 folder on your computer and select the 3 items in there, copy, and then paste those 3 things on to your SD card.
Posted Sep 26, 2011 · 13:05 UTC#90
Hi, I am from Greece and I own an AVIC-F10BT version 1.000 and I will try to install this latest update.
MANY THANKS to all of you for the Guide and the Files! Great Work!
I hope the FIRST Post is Correct-Updated, because I got lost with all these 6 pages of comments...
and I intend to follow precisely those 13 steps :P
Please tell if those steps are outdated!
Currently I am downloading all files described in the first post.
(I will keep seeding those torrents for as long as I can, through my crappy 1mbps upload-rate-dsl)
I will post Success (or failure) when I complete the procedure, to let you know.
Edited Sep 26, 2011 by dimitris71
Posted Sep 26, 2011 · 18:16 UTC#91
you guys all speak of SD1 and SD2 maps.. mine are called: Speicher1 and Speicher2
i went tonight looking at the linkedin download site and i found i downloaded from page 1 the 110fm sd's instead of the 210fm sd's so i went to the : http://linksave.in/8682446534e3da6a37032a site and downloaded the 32 parts ( i used superhide ip to download past the 1500mb limit) and now i see the dates on the files are from 05-2011 and not 2010 anymore! yayyy tomorrow i will go and put this sd inside my pioneer and i hope it now shall update :) thanks for having me doublecheck the files :)
Edited Sep 26, 2011 by Sentic
Posted Sep 27, 2011 · 12:31 UTC#92
CNSD-210FM torrent stopped at 36.9% .... so it seems that I won't be updating my unit :-(
Edited Sep 27, 2011 by dimitris71
Posted Sep 27, 2011 · 20:28 UTC#93
i went tonight looking at the linkedin download site and i found i downloaded from page 1 the 110fm sd's instead of the 210fm sd's so i went to the : http://linksave.in/8...534e3da6a37032a site and downloaded the 32 parts ( i used superhide ip to download past the 1500mb limit) and now i see the dates on the files are from 05-2011 and not 2010 anymore! yayyy tomorrow i will go and put this sd inside my pioneer and i hope it now shall update :) thanks for having me doublecheck the files :)
today got the update in my 920bt !!! top! everything is now version 3.0 and 2011 thanks for the forum!
Posted Sep 28, 2011 · 07:07 UTC#94
Hello guys,
can anyone help us cracking firmware update for u310bt (cnsd 130fm)?
I saw in a first post that u have cracked this two firmwares, so maybe this can be cracked at the same way?
I know taht this is not u310 subforum, but please help...
Link for cnsd 130fm
http://www.4shared.com/file/w_uO6zHt/CNSD_130FM_firmupdate.html
Edited Sep 28, 2011 by vojopg
Posted Oct 01, 2011 · 04:22 UTC#95
Hi all,
it worked perfectly on my F9210BT. Just follow all steps from #9 on.
Regards
tritronic
Posted Oct 04, 2011 · 17:32 UTC#96
Hello.
Is this update fork for Avic Z130BT
And make it EU version F30BT ?
Posted Oct 04, 2011 · 22:05 UTC#97
Hello.
That probably will not work without some additional hacking via TestMode. The first thing the update does is check the existing software version number. The update/upgrade must be a higher version. I believe that the Z130BT and F30BT are both version 3.0.
If you had a Z110 or Z120, you could very likely update it to the EU v3.0 software/maps.
I would also point out that the CNSD-210FM (US or EU) upgrade does not turn an older model into a Z130 or F30BT. The hardware is different. The upgrade adds a few new features and updates the maps. If you did find a way to force the update to load the EU upgrade on a Z130BT, you would likely loose some of the features like auto equalization.
Edited Oct 04, 2011 by RonS
Posted Oct 15, 2011 · 09:40 UTC#98
Hi,
Step 8 doesn't work for me.
I insert the SD card in the F10BT and I don't see anything.
My radio keeps playing...etc
Any ideas?
I have done steps 1-7 exactly as described.
Posted Oct 15, 2011 · 19:50 UTC#99
Updated my F10BT today , I followed the manual from post # 1 and had NO problem at all .
In about 2 hours everything was fixed .
TNX to PeterMmX for the nice manual ,keep on going :wink:
Posted Oct 17, 2011 · 05:50 UTC#100
Hi,
Any ideas?
OK. Update complete!
It seems I had to spend hours and download those 30+ files....
The torrents for CNSD-110FM and for CNSD-210FM contain wrong files.
Page 4 of 11
