CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 6 of 11
Posted Dec 10, 2011 · 23:10 UTC#126
Hello.
I wil try update my F9220BT unit.
I have my pioneer installed in a Ford S-MAx.
With this update, besides upgrade the maps. What major features have the new software?
Does it have compability with the convers+ screen dashboard?
TKS.
Posted Dec 10, 2011 · 23:23 UTC#127
I humbly Solute you guys for making this work!!!!!!!!!
Keep up the good work!
The UI seems a lot more responsive than before, haven't checked the Navigation.
And I know the Can-bus has been updated for VW & Ford cars, did any one got that to work?
According to the specs, you should see your park-assist in the screen + Airco control.
Do we need a separate cable for that?
That specs, park-assist and Aircon control is for both cars, ford and VW?
The ZENEC radio have already that features. I hope Pioneer have improved on that.
Posted Dec 11, 2011 · 12:04 UTC#128
Thank you to DR MONG and PeterMmX and of course StefanSki for the excellent work
I update my unit ( F9220BT) with success without any issues.
For those who have Ford the convers+ still not work and you dont see the park assist neither aircon control.
The new first features i can see is the new icons with better definition.
Best regards
Posted Dec 13, 2011 · 16:00 UTC#129
Hi guys,
Thanks for all the info the only thing missing is a link to download the CNSD-110fm European Version I cant download it anywere. Nothing to find in the torrents or on this site I can only download the file in scam sites and give them my creditcard info ;-(
Can somebody help me out? I really want to upgrade my F10BT to a F30BT EU version!
Great site keep on the good work!
Posted Dec 13, 2011 · 16:32 UTC#130
You don't really need CNSD-110FM installed to install CNSD-120FM. The upgrade will go from a F10BT to F30BT directly. But you must install the Shortfuse hack v1.003 first. It will bypass the password check. Then install CNSD120-FM.
Posted Dec 13, 2011 · 17:05 UTC#131
Hey guys. I have major issues downloading the CNSD-230fm European Version (Step 11). Can somebody provide me with a link for a working torrent that I can use instead? :neutral:
Posted Dec 13, 2011 · 20:07 UTC#132
I did downloaded it through one of the links on this topic I thought the one on the second page. Did you use Utorrent to download it? otherwise search on google for the file name and you will find it (for free)
Posted Dec 13, 2011 · 21:35 UTC#133
Hi,
where can i find the Shortfuse hack v1.003 to install?
I also can't download CNSD-110fm
I already have the CNSD-210Fm
When you say 120 you mean 210 right?
Thank you very much
Edited Dec 13, 2011 by marcolima79
Posted Dec 13, 2011 · 21:57 UTC#134
Hi,
Thank you very much
Yeah, I meant CNSD-210-FM. To do the 1.003 Shortfuse hack, you need his patched files and the official Pioneer 1.001 update.
You can get them from the links in post #1 in this thread:
http://avic411.com/i...-download-2011/
As I've mentioned, it isn't necessary to install the CNSD110-FM upgrade, just go directly to CNSD-210FM after installig the hack. So, using post #1, follow steps 1 - 5, then skip to 11. And don't forget to manually update the BT firmware twice (SD1 and SD2). Don't ask me why twice.
Edited Dec 13, 2011 by RonS
Posted Dec 13, 2011 · 22:18 UTC#135
Thx... I've done steps 1-5 everything ok...
I've version 1.001
Now i just have to jump to 11 i don't need to put 2.003 and 2.004 because i tries to put it in the SD and nothing append.
About the BT firmware, can i do it before the update or after?
Thx again
Posted Dec 13, 2011 · 23:05 UTC#136
After.
Posted Dec 13, 2011 · 23:41 UTC#137
I have my avic in version 1.001 with the steps 1-5 done... all i have to do now is to do from step 11 to the end right?
You refered to havin it in 1.003... does it make a diference?
I'm i doing anything wrong?
I tried to put the info from SD1 folder in a Pen diks but it didn't work... it didn't move.. does it has to be in a SD card?
Thank you once again
Posted Dec 14, 2011 · 00:47 UTC#138
First, all updates and upgrades must be from SD. I hope your v1.003 (ShortFuse hack) was via SD. For CNSD-210FM, you need a 4GB SD or greater. The others only need less than 1GB.
If you did the Hack correctly, your Application Version will be 1.003 or greater. You might not be looking at the right version.
To check the Application Version:
  • Press the "Home" key
  • Select the "Settings" tab
  • Select "System Settings"
  • Select "Service Information"
  • Press & hold upper left corner of the "Service Information" screen for a few seconds
Check the "Application Version"
Edited Dec 14, 2011 by RonS
Posted Dec 14, 2011 · 08:29 UTC#139
I have downloaded the CNSD-210fm through a torrent. I have trouble downloading the CNSD-230fm file. I did try googling using the filename but I could not find it ... :?
Also a question: Which set of instructions is the correct one, the one in page 1 or the one in page 2? Because different files appear in the steps of each set of instructions ... :neutral:
Posted Dec 14, 2011 · 08:41 UTC#140
And one more question, apart from the CNSD-210fm and CNSD-230fm, do I also need the CNSD-110fm EU update? Do I need all three of these?
My unit is the AVIC F10BT version 1.0
Posted Dec 14, 2011 · 14:21 UTC#142
Update: Oops, pionara beat me to it.Thanks.
CNSD-230FM is not for an AVIC F10BT. You don't want that one. I didn't even know it existed. From the Pioneer web-site:description of CNSD-230FM:
Use this update for your AVIC-F320BT, AVIC-F3210BT or AVIC-F220 with software version 1.000x or your AVIC-F310BT with version 2.000x.
An AVIC-F320BT with software version 2.000x needs not be updated.
An AVIC-F310BT, AVIC-F3210BT or AVIC-F220 with with software version 1.000x can be updated with the CNSD-239FM.
You don't need CNSD-110FM if you followed my directions. If you do install it, then you need to also install the latest ShortFuse hack (v2.003?) in order to again bypass the password check.
Here is the process:
ShortFuse 1.003 hacks the password check for whatever upgrade is installed next. If you ultimately want CNSD210FM, just install it.
However, if you install CNSD110-FM, than you need to install the newer ShortFuse hack (v2.003?) after installing CNSD110-FM, so that when you install CNSD210-FM, you can get past the password check.
So, why bother with CNSD110-FM???? Go right to CNSD210-FM.
I hope I got all those hack version numbers correct. Its been a while. There is ony one hack for each upgrade. (CNSD110, CNSD210).
If I've gotten you confused, then go back to the beginning of this thread re-read it. I find it really helps if - rather than just following a bunch of steps, instead try to understand what each step does and why. Then you will see how simple this really is.
Posted Dec 14, 2011 · 15:04 UTC#143
Hi,
The first time i did steps number 1-5, everything whent fine, at lest i thought so... But i got version 1.001
Now i can't get the Avic F10BT to recognize anything... i've tried to put the SD card with the steps 1-5 again in it but nothing append. I've also tried with the original 1.001 and nothing.
I can't get version 1.003... I've CNSD-210Fm ready to install but i can't get version 1.003 as you say...
What can be wrong? Any ideia?
Thank you very much
Edited Dec 14, 2011 by marcolima79
Posted Dec 14, 2011 · 16:21 UTC#144
You can only install a higher version number than the one you currently have. So that explains why nothing is happening when you try it again. The only reason that I can think of is that you didn't apply the ShortFuse hack correctly. Maybe you didn't copy/replace the files in the correct directory.
Or, maybe I'm wrong about the version numbers displayed. In that case, I'd go ahead and install CNSD-210FM. It can't hurt anything - if there is a problem with the password (the only reason for the Hack), then you will not be able to install it. Just remember to use an all-alpha password, like the suggested "passwordpassword". If it rejects this password, then your ShortFuse hack was done wrong. Let us know how it turns out.
Posted Dec 14, 2011 · 19:04 UTC#145
Thx... I did everything as mentioned.. copied all the files to the right place...
I've tried 1.004, sent from pioneer and nothing...
I've tried the CNSD-210FM in a 4GB SD card and nothing... it does allways the same... it does not recognize the SD Card...
Very stange...
Posted Dec 14, 2011 · 21:02 UTC#146
RonS and pionara thanks for the answers guys!!!!
I was a bit confused by the title of the set of the instructions in page 2 wrote that the whole lot was for upgrading F10BT
Sure, no problem! I'll give you the step by step instruction of what I did to get my F10bt updated to F30bt.
Anyhow ... let me just understand this correctly. For upgrading my AVIC F10BT ver 1.00 to F30BT, I need to upgrade the firmware first correct? And from what I understand, I need to go from ver 1.0000 to 1.0001 then 2.0000 and finaly 2.0003. After doing all these I will need to update my navigation maps using CNSD210-FM with the appropriate crack.
Is this the correct steps? :idea:
Posted Dec 15, 2011 · 03:35 UTC#147
If you are at v1.000
Post #1 - steps 1 - 5. Then skip to 11 ( no need to install CNSD-110FM) and continue from there.
Posted Dec 15, 2011 · 07:24 UTC#148
Happy to find this thread to update the f10bt :)
Is there any other link to download the CNSD210-FM ? The other links seem to be dead!
Posted Dec 15, 2011 · 07:58 UTC#149
I was looking for the same thing... i wanted to try a diferent file... since mine dosn't do any thing...
The Avic does not read anything... only BT firmware... i does not star from the SD card.
Thx
Posted Dec 15, 2011 · 08:02 UTC#150
Step 11. Download CNSD-230fm European Version from here: CNSD-230fm EU Version Password for the archive is: digital-eliteboard
Step 12. Put the content of SD1 folder from the CNSD-230fm EU Version folder on the SD Card (4GB or larger) and insert the SD to your F10bt/F20bt - it will start the update that will take around 30minutes. After this you have F10bt updated to newest 2011 maps and app version 3.000
Step 13. Update your Bluetooth by going to Settings/Bluetooth/scroll down to Firmware update/ it will ask you if you want to proceed with the Bluetooth 3.10 update - accept it. After it is done clear the card and use the folder Firmware from SD2 of CNSD-230fm update - process to Bluetooth firmware update and that will update your Bluetooth FW to 3.22.
And that's it - your device will be updated to the newest version.
All credits go to ShortFuse, Condiczek (for his GREAT support and cooperation) and of course to StefanSki for providing cracked 2.003 update.
One more and the MOST important thing : You're doing everything on your OWN RISK! There is always a risk of bricking your device!!!
NO RISK = NO FUN! :wink:
When i trie to go to the page in step 11 it gives me all the parts, but i don't undestand how do i download them...
There are a lot of download buttons but all of them come to a popup window asking for a mobile phone... can any one give me a help?
Thx
Page 6 of 11
