CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 7 of 11
Posted Dec 15, 2011 · 09:49 UTC#151
If you are at v1.000
Post #1 - steps 1 - 5. Then skip to 11 ( no need to install CNSD-110FM) and continue from there.
Many thanks mate!!!! I'll give it a try during the weekend. Hope everything will go fine 8)
Posted Dec 15, 2011 · 19:48 UTC#152
Hi...
Just to let you my situation that i hope will help others... from the begining...
I've started from Step 1 to 5 everything went right but i got vertion 1.001 and not 1.002 or 1.003... after that i tried a lot of solution but the Avic was not reading any cards it woudn't mather the version it didn't read.
I tried puting CNSD-210fm in a SD carda and nothing... no reading... i was getting woried
Then i downloaded the CNSD-210fm again from the torrent in this topic... after waiting for the download that actualy was very fast e put the SD1 information in the SD card and whent to try... fantastic.. i worked... I gor version 3.001
Then I updated BT to version 3.10
I came back to the Mac and send the information in SD2 to the SD, deleting all the other information... and updated the BT with sucess.
One more thing... before all this, i was having prolems with my iPhone... and contacts where ordered by surname, name... this updated also corrected that problem.
Thank you very much for all your help and i hope to help somebody with this post...
Now let's just wait for Pioneers next update... :)
Posted Dec 15, 2011 · 23:05 UTC#153
I donwloaded trough Utorrent and found the torrent through google just look for CNSD-210fm EU.rar
I did go directly from F10BT to F30BT Thx Rons for the tips.
After the shortfuse update. Put in the 4GB sd with the SD1 directory Just the files not the sub dir itself....
Watch out I did the formatting on a windows7 pc (standard cluster size!) and it didn't work it only went till 75% Then I did the same on a windows XP pc and it just went on to 100% without problems!
After that first do the first BT update and after that the second BT update (sd2)
Works perfectly like the new layout! and BT works a lot better!! no more strange sound for the recipient.
Posted Dec 18, 2011 · 00:19 UTC#154
My problem is that I can’t download the CNSD-210fm Eu version, all the working torrent files I found seems to be US/can version. It would be great if someone could upload the EU version.
Thanks in advance.
Posted Dec 18, 2011 · 22:07 UTC#155
I'm seeding the EU version...
Posted Dec 20, 2011 · 09:07 UTC#156
Hello, the link to the CNSD-110FM died since the 17/12/2011, is what would be possible to reactivate, thank you
Posted Dec 20, 2011 · 13:33 UTC#157
If your goal is installing the latest upgrade (CNSD-210FM), then you don't need CNSD-110FM. See Post #147.
Posted Dec 20, 2011 · 21:34 UTC#158
many thanks... for this nice work
after installing on f920bt.. wil i need in navgatefeeds set the f30?? or wil it still handle the 920?
will we have acces those 3d map buildings? that looks great on the f30bt
Posted Dec 23, 2011 · 14:39 UTC#159
Can anyone seed? I've been stuck at 98.8% for the last 2 days now...
Posted Dec 28, 2011 · 13:48 UTC#160
Hi guys,
just wanted to confirm this update works without problems on F9220BT in my Ford Focus RS. I´ve done the update this morning on my drive to work. :wink:
My unit had already installed 2.003 installed. I downloaded the 2.003 update again from pioneer site und patched it with the two files from the StefanSki hack --> 2.004 shown on my unit!
After that I overwrote the contents from the SD1 folder with the SD2 folder on my harddisk (this is only the 3.22 BT FW upgrade), no idea why Pioneer took it apart and left the old 3.10 BT FW in the SD1 folder...
Copied the contents from the SD1 folder to the root of a empty SD card and then followed the instructions on the display. I used "passwordpassword" as password as other here mentioned and the update was ready after about 25mins - I think it depends on which SD card you usw. Mine is an 8GB SDHC.
Then I went to bluetooth settings / Firmware and the update to 3.22 was finished after abut 3mins.
Thank you very much to all involved people and this great forum!
PS: I did use the 210fm update which is split into 32 rar files and not the torrent one - just to mention.
Posted Dec 30, 2011 · 12:31 UTC#161
Many tanks
the update works on F9220BT in my Ford Mondeo (Italy).
The Bluetooth downgrade from 3.11 to 3.10 has failed 2 times, and i have proceed to direct update 3.22.
Success!!!
all's good, that ends good :-D
Thank you very much
Posted Jan 04, 2012 · 17:06 UTC#162
Hello everyone, maybe can somebody uploade from CNSD-210fm EU SD 2 folder? because i deleted it accidentally. Maybe can you help me please! Thanks
Edited Jan 04, 2012 by specialistas
Posted Jan 04, 2012 · 19:27 UTC#163
Hello,
I read all of the answers and I need someone to post all the things to do the upgrade F10BT-F30BT
Thanks for all
Posted Jan 05, 2012 · 17:21 UTC#164
Hello there,
I´m downloading CNSD-210FM EU from torrent file and already read this post carefully.
My unit is a F910-BT with map version 02.000600 and app version 3.021000, can i follow instruction on post #16?
Users allways talk about 2.003 and 2.004 version, i´m kinda confused now... can I upgrade maps?
Kind regards,
RR
Posted Jan 08, 2012 · 19:18 UTC#165
Hi
Problem updateing my F20BT to 2.004 using recomended cracked file.
Tried different SD cards, formated several times.
AVICF20BT starts updating but after 15/15 installs it says "update failed - please try again.
Anyone got the same message and solved the problem?
Posted Jan 08, 2012 · 20:22 UTC#166
Hi
Others have solved this problem by using a different PC or SD writer. SD writers are notorious for having problems, especially with SDHC cards. If that doesn't work, try to re-download the files (2.003) and the hacked files.
Edited Jan 09, 2012 by RonS
Posted Jan 10, 2012 · 06:52 UTC#167
Tried different SD-cards, different pc's, no luck.
Posted Jan 10, 2012 · 13:45 UTC#168
Are you sure you placed the hacked files in the correct directory? I don't have the details handy, but the 2 replacement files need to overwrite the v2.003 files of the same name - and they are in different folders.
Posted Jan 11, 2012 · 06:30 UTC#169
Hi,
Thanks a lot for the instructions and seeding the software !!!! patience is needed to collect all files but finally it works perfect......(F9220BT)..
There is one new item in the software that I don't like, the passenger isn't able to see anymore videoclips/movie on the display while driving the car. With the old software you could bypass this with the handbrake wire to ground now I get a popup that it isn't allowed to view and the video isn't visible. The display's in the back are working fine but I don't want to place a extra screen in the front for the passenger.
Does anyone know how to bypass this ???? i think the software checks now also the speedsensor and blocks the video output to the maindisplay when a signal is present???
HELP....
Posted Jan 15, 2012 · 09:51 UTC#170
Hello All!
well i have a problem, i can´t download some files, (rar), netloaded say (server error) and if i try in torrents... no seeds...
please, can somebody upload the files again? well; i just need (part03 - part06 - part09 - part12 - par15 - part18 - part21 - part24 - part27 - part30)
If any of you can do it, i will do a new torrent and a new upload with all the files availables. is a promise.
really thank you.
Posted Jan 16, 2012 · 18:17 UTC#171
Hello,
My fb9220bt unit already have the 2.003 update.
Is it possible to install the new maps to this unit ?
Do i first have to install the ShortFuse Crack and after that the StefanSki crack ?
How can i do this ?
I hope you can help me with this problem !
Arie
Posted Jan 17, 2012 · 00:34 UTC#172
Hello,
How can i do this ?
Arie
Follow the instructions in post #1 in this thread, starting at step #10. You need to create and install 2.004 using the Stefanski files and the 2.003 update.
Edited Jan 17, 2012 by RonS
Posted Jan 17, 2012 · 18:51 UTC#173
Thanks It works.
Posted Jan 17, 2012 · 19:01 UTC#174
I have already installed all files, so my system is version 2004 now however i now have to wait 5 days until the maps are finished downloading. Can someone please upload the files to a different server or as a torrent so i can download it at once.
Kind regards,
Tom Hartogs
Posted Jan 17, 2012 · 19:37 UTC#175
The only problem I have now is the Bleutooth doesnt update to 3.22.
Its downgrade from 3.11 to 3.10 and if I install the update to 3.22 at a moment it says ''Update Failure''
Hope to get some help from you guys.
Page 7 of 11
