CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 9 of 11
Posted May 04, 2012 · 23:14 UTC#201
Good luck guys smile.gif and most important thing!!! MAKE A BACKUP!!!
Its more that 3gb, it will take ~1h or even more.
what is the procedure to make a bakup?
thanksssss
Edited May 04, 2012 by husus1
Posted May 05, 2012 · 12:13 UTC#202
hi ppl, ive read every post and im stuck on my z110bt and ive been without a working unit for almost a week now and i feel so frustruated. i got stuck at 98% upgrading with the cnsd210bt after applying shortfuse crack and only thing i can do is boot to testmode or view the failed update pop up. my question is simple, thinking its my sd card with the problem, what sd card brand is best fcor the update!!!!! pleaaaassssssseeee help im busting myself daily because i think ive bricked my device!
Posted May 05, 2012 · 21:10 UTC#203
Buy a couple 4GB SDs of different brands. They are cheap compared to the cost of the AVIC. BTW are you trying to load the EU CNSD-210FM onto a US Z110-BT?
Posted May 05, 2012 · 23:49 UTC#204
no, i did the us version and failed after 98%. i tried reformating card and reloading files but system says upgrade failed retry but nothing happens when i touch on retry. i used micro sd card on sd adapter u think thats my problem??
Posted May 06, 2012 · 13:29 UTC#205
This is an EU thread.
In theory it shouldn't matter. However, I also tried a micro w/adapter to install an update, and had problems. Probably the safest is to buy a reputable brand 4GB SDHC. They aren't very expensive (Staples usually have them on sale). Avoid large capacity ones - they seem to have more problems. 4GB is all you will need.
Afterwards, if you have no other use for it, use it to store music/photos/vids to play on the AVIC. Or, for fun, format it, and insert it into the HU, then turn on "Track Log", and record a history of everywhere the car goes. Just beware that the SD will eventually fill and you'll get a warning.
Edited May 06, 2012 by RonS
Posted May 06, 2012 · 16:14 UTC#206
RonS thanks, sorry for posting on EU. I'm actually going to buy a a pair of sd now. Thanx , can I pm u I have another question but I don't wanna take up more EU thread space (sorry thread!)
Posted May 14, 2012 · 18:12 UTC#207
can be updated directly by f 10 to 210? because the link is broken CNSD 110 eu?
thanks
Edited May 14, 2012 by husus1
Posted May 14, 2012 · 22:03 UTC#208
can someone reupload the cnsd-110fm eu?
thanks
Posted May 19, 2012 · 14:40 UTC#209
Hello, first sorry for my English and congratulations for this wonderful post. I have an avic F10BT v1.000 and BT v2.50 and I want to upgrade to CNSD-210FM but I can not download files http://ds1.downloadt...re/1.001000.zip Shortfuse Crack. The first always leads me to the main page and the second tells me that you can not find the website. Can anyone help me and tell me where I can download these two files?
After reading the forum I understand that I must follow the upgrade steps 1 through 5 of the first post and then move directly to 11 is it right?
I thank dosage and greetings
Edited May 20, 2012 by carichip
Posted May 27, 2012 · 12:20 UTC#210
Hello!
I want to download CNSD-210FM EU. Do you know any good link where I can download it from, for free? I tried the link from the first post, but it is not working.
Thank you.
Posted Jun 23, 2012 · 16:49 UTC#211
any news about new release?
I' m not able to organize the mp3 song in the hard disk... not in alphabetical order???
Posted Jun 25, 2012 · 00:32 UTC#212
thank you guys, i've updated my f920bt, i've read the post in one day, and when i had time, i've tried to install it. After many tries i was able to do it. read the try again, read and try again. So... two things i need to tell you.
1. it was very confusing for me how to update from 2.003 to 2.004. When copying files from 2.004 to 2.003 on sd card. YOU NEED TO KNOW THIS: file "EU090APL.VER" will go inside AVICZ110, first level, AND "RenewalIFLib.dll" file will go inside "APL" directory. after that good knowledge, everything went JUST FIME.
2. the torrent file for "CNSD-210FM Eu Version", very slow download without a premium account.
thank you guys, the effort was worth it, the device is loading much faster, the animation is much better(no lagging), and of course the map is much detailed.
Posted Jul 07, 2012 · 22:35 UTC#213
Anyone needing help updating the EU maps or the US maps? If so, just PM.
Posted Jul 08, 2012 · 09:12 UTC#214
THK from Italy!!!
All is ok.
with a 16GB micro SD, is best format it every time that use it, because avic has problem to see it
Edited Jul 08, 2012 by fighterv60
Posted Jul 25, 2012 · 11:50 UTC#215
Hello,
Thank you for this forum, unfortunately I tried to install the new version CNDSFM210 on the 920BT and now mapping the home and not work. I put the new version 2.004 and installed CNDS-FM210 EU corrupt.
Now even when I put an SD it does not recognize. How to force the update with the micro SD
Thank you for the information, and excuse me for the text I'm French
Posted Aug 01, 2012 · 08:49 UTC#216
Hello,
Jean-Marc from France
I have done the update but the gps and the HOME menu does not work, and when I put a card with the right programs the 920BT does not perform the update of the map.
Thank you for your help because I go on holiday soon. :-(
Posted Aug 21, 2012 · 11:00 UTC#217
Hello everybody,
is there already any source where I could get the
2012 European Map Update for AVIC-F30BT, AVIC-F930BT, AVIC-F9310BT
already? The 2011 Update was/is available here but I couldnt find anything about the 2012 update here.
Many thanks.
Posted Aug 23, 2012 · 18:29 UTC#218
i have made a big s*it.
i forgot to make a backup from ndata and hope someone have it for me. ( avic f920)
So my problem is, i can not use the navi. Always when i want to shearch a street, the navi dont memorise it.
Can you please help me?
Posted Sep 01, 2012 · 06:20 UTC#219
Normally the update come out in august! It take a time to test/hack
I think that we have the update in september!!!
Posted Sep 11, 2012 · 17:15 UTC#220
I need the .....CNSD-110fm .....please...my pioneer cant update the cnsd-210 .....it say ....wrong sd - card.....insert the correct card...omg....all downloads offline....torrents are not avible....
Can anybody upload the CNSD-110FM......Please...and Thanks.....
Posted Sep 24, 2012 · 23:05 UTC#221
Help to try to at least start this mod..
both the Step 1. Download ShortFuse crack from here: ShortFuse Crack
Step 2. Download 1.001 update for Pioneer Z110bt
Did the moves on the SD cards and loaded it in unit. Update started and completrd but the vesion still say 1.000. . Is there something wrong or is there another option ot look at for the version numbers.
I have a stateside Z110bt Im trying to load the EU map while Im stationed here in Italy.
I have the EU version being downloaded and should be finished today.
So since this thread has been up for the past 2 years , should we be downloading updated cracks and or pioneer versions to crack?
Edited Sep 26, 2012 by wgreen
Posted Sep 26, 2012 · 14:17 UTC#222
If you had a Z110 or Z120, you could very likely update it to the EU v3.0 software/maps.
I would also point out that the CNSD-210FM (US or EU) upgrade does not turn an older model into a Z130 or F30BT. The hardware is different. The upgrade adds a few new features and updates the maps. If you did find a way to force the update to load the EU upgrade on a Z130BT, you would likely loose some of the features like auto equalization.
As stated above are you sayin to follow the instructions to make an US spec Z110Bt currently running version 1.001 hack with 2.5 Bluetooth.
To update to EU maps since Im stationed in italy.... but downloading the 30 peices and hack that too and then moke ot stage 2.003 thane 2.004 thru the eu stuff? Im not tryin to go to Z130Bt I would like the maps and updates EU version at the least
Posted Sep 26, 2012 · 15:06 UTC#223
In the post of mine you quoted, I believe the point I was addressing was that I loading the EU CNSD-210FM on to a US Z110 or Z120 doesn't completely turn it into an EU Z130 (or whatever that model is called). For example, no auto-eq support.
I do remember seeing posts of US units being converted to a different continent (EU or AU), but I don't have any specific experience doing it - or what other usability problems you might have after loading the EU firmware.
Edited Sep 26, 2012 by RonS
Posted Sep 26, 2012 · 23:30 UTC#224
Yes thanxs for the reply... I wanted to just change my Z110Bt to eu. I will be trying it. im downloading the cdsd 31 parts tonite. the unit is already hacked to 1.001 yesterday.
Posted Sep 27, 2012 · 00:29 UTC#225
A minor point- you can't go US Z110 -> EU Z110. You must do it as part of the EU Z120, Z130, or Z140 software upgrade (CNSD-110FM or CNSD-210FM or CNSD-310FM). Besides the EU maps, the biggest change you'll notice is the iPod player look-and-feel is totally different. I actually like the old Z110 better.
Page 9 of 11
