CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 10 of 11
Posted Sep 29, 2012 · 14:27 UTC#226
A minor point- you can't go US Z110 -> EU Z110. You must do it as part of the EU Z120, Z130, or Z140 software upgrade (CNSD-110FM or CNSD-210FM or CNSD-310FM). Besides the EU maps, the biggest change you'll notice is the iPod player look-and-feel is totally different. I actually like the old Z110 better.
Ok I gotthe unit to Z120Bt wit the sidelining menu... now the 31 part rar file should be downloaded to drop the Craked files in them to load in the avic am I right?
Posted Sep 29, 2012 · 14:43 UTC#227
Did you install the US CNSD-110FM upgrade? (Makes Z110 -> Z120) Why? The EU one won't install over it. Now you'll have to go through it all over again with the EU CNSD-210FM, or install the EU version of CNSD-310FM using the hack discussed in that thread (which is a totally different way to install the cracked file).
I don't know what this 31 part RAR is that you are referring to, so I can't help with that. Good luck.
Edited Oct 04, 2012 by RonS
Posted Oct 03, 2012 · 21:48 UTC#228
I got my F10bt(updated to f20bt with CNSD-110fm thanks to ShortFuse!) updated to F30bt (2011 maps+app) with CNSD-210fm thanks to StefanSKI (providing fake update to 2.004).
Everything works perfect - Bluetooth updated to 3.22 from 3.11 (first with SD1 of CNSD-210fm to 3.10 from previously installed 3.11 and after to 3.22 with sd2)
Thanks a lot guys and looking forward for next year's release!
Best Regards and BIG Thanks to CONDICZEK for all good work he does with his Hackmode!
Peter
Good day everyone... I recently did some updates and I think ended up grabbing or hacking the wrong folder I made. I have the EU torrent downloaded but updated my Z110bt to a 3.00 and 3.11 BT.. Now as stated earlier, will I be able to hack the eu or the current version I have with the 2.004 and update to the EU maps? or will I have to go back to a 1120bt version and then drop in the eu maps? Please advise.
Edited Oct 04, 2012 by wgreen
Posted Oct 04, 2012 · 17:54 UTC#229
Did you install the US CNSD-110FM upgrade? (Makes Z110 -> Z120) Why? The EU one won't install over it. Now you'll have to go through it all over again with the EU CNSD-210FM, or install the EU version of CNSD-310FM using the hack dicussed in that thread (which is a totally different way to install the cracked file).
Can you expoun on the route your are mentioning? I can just edit or crack the eu 210fm but with what file? And 310fm eu can be found where?
No Not the 110... I nstalled the 31 part eu torrent It made my unit a 130bt with 3.00 an 3.001 with 3.10 BT... I still have american mapthough>.>. Are you saying I should did the 2.00 whatevet thats cracked then do the cnsd eu ?
Edited Oct 05, 2012 by wgreen
Posted Oct 07, 2012 · 15:04 UTC#230
Hi,
The link for shortfuse hack v1.003 doesn't work!
Has somebody a solution
thanks
Posted Oct 07, 2012 · 15:22 UTC#231
OK, you installed the US/Can CNSD-210FM, so now you effectively running a US Z130. I don't think there is a known way of installing the EU version on top of the US version. The installation program checks the version number, and it is the same on US and EU.
While there may be a way of just transfering the EU maps via Testmode, That will probably have lots of usability issues (POI DB and address lookup).
I think your best bet is to find an EU version of the latest upgrade (CNSD-310FM) and install that using the methods described in that hack thread. See the simplified instruction on post #170. http://avic411.com/i...e/page__st__165
Edited Oct 07, 2012 by RonS
Posted Oct 19, 2012 · 00:06 UTC#232
hello to all
I apologize for bothering all of you but wonder if some can help me solve a serious problem, I have in my car that was Avic F20BT with soft 2.003, and already some time I have been reading your forum and then decided to upgrade it to the version of 2011 just to update the maps were outdated already because I did all the steps that are described in previous posts.
my unit already had the 2.003 EU. version, so I did the update download 2.003 as indicated in the post, and then did the download crack, replace the two files with splint explained and then did the download of the 32 parties comprising the file CSND-210, took a week-do the download the file and today, I prepared everything, after having already updated to 2.004 which is supposedly the crack, formatted the 8gb memory card and went to the car to update the system, I start the car because I knew that take 30m and put the memory card in the unit, was asked the password and then I put passwarpassword seemed to me a display say this system updating missing 30 minutes, then spent a couple of minutes got the following message, please change the Card, Card not accepted, the unit simply do nothing with that Feedback is always in display, and the only thing they do and open the panel to be putted another card not accepted, the unit simply do nothing with that information is always in the display , and the only thing they do and open the panel to be be putted another card, already started the car, turn off ,tried to do more home Boton plus « 'also nothing , I already changed my different memory cards 3 times and do not know more, please ask someone who could help me :unsure:
Posted Oct 19, 2012 · 00:59 UTC#233
Please dont post the same message in two threads.
Posted Oct 23, 2012 · 00:34 UTC#234
i folow all of thsi procidures but in last on , "Put the content of SD1 folder from the CNSD-230fm EU Version folder on the SD Card , were is the CNSD 230bt to dowload were only speak abouy the CNSD 2230FM
"tep 9. You can proceed with the update to 2.003 after you updated your device to 2.000 - you'll get it from here : Pioneer F20bt 2.003 update You only need to put the AVICZ110 folder from this update on the SD Card and put it into your F10bt upgraded to F20bt - It will ask you if you want to proceed with the update (I'm not sure if it did or didn't ask for your decission - can't remember).
Step 10. Now, time for the last stage - Thanks to StefanSki - update 2.003 to 2.004 the same way as in step 1 to step 4 but download StefanSki crack from here: zip.gif AVICZ110BT-2.004.zip 25.75K 1038 downloads
For 2.003 use the folder downloaded in previous step 9 and patch it with downloaded files from StefanSki crack - I personally think that you can proceed straight from 2.000 to 2.004 without updating from 2.000 to 2.003 but I went the way described above.
Step 11. Download CNSD-210fm European Version from here: CNSD-210fm EU Version Password for the archive is: digital-eliteboard
Step 12. Put the content of SD1 folder from the CNSD-230fm EU Version folder on the SD Card (4GB or larger) and insert the SD to your F10bt/F20bt - it will start the update that will take around 30minutes. After this you have F10bt updated to newest 2011 maps and app version 3.000
Step 13. Update your Bluetooth by going to Settings/Bluetooth/scroll down to Firmware update/ it will ask you if you want to proceed with the Bluetooth 3.10 update - accept it. After it is done clear the card and use the folder Firmware from SD2 of CNSD-230fm update - process to Bluetooth firmware update and that will update your Bluetooth FW to 3.22.
And that's it - your device will be updated to the newest version."
Posted Oct 23, 2012 · 00:46 UTC#235
In Step 12 it is a typo - should say SD1 of CNSD-210FM
Posted Nov 13, 2012 · 23:03 UTC#236
here is special VERINFO.DAT that can be used with CNSD-210FM (2011) update.
No hacks, dlls, mods, etc required. Just replace SD\Update\VERINFO.DAT with this one, then insert card in unit. It will not ask for password.
please test it out and let me know if it works ok. If it does, hopefully first post can be updated.. Also if somebody can find and post EU CNSD-310FM, then the special VERINFO.DAT on my CNSD-310FM/UC post will work fine for that one too.
Edited Nov 13, 2012 by pionara
Posted Nov 16, 2012 · 12:49 UTC#237
100% working
thanks of your work
Andrea
Posted Nov 21, 2012 · 08:40 UTC#238
Is it also possible to update a F10BT Version 1 directly to the CNSD 210FM with this adjustment ?
Posted Jan 20, 2013 · 12:31 UTC#239
Hello,
i have the F3210BT which maps can i use ? And how can i update it? Has anybody some idea or done it ?
Posted Jan 20, 2013 · 14:41 UTC#240
Hello,
I don't even know if a F3210B is compatible with any of the units covered by this forum. However it appears to be a 2012 model. So no updates are likely to be available until mid-summer 2013.
Posted Feb 12, 2013 · 19:42 UTC#241
attachicon.gifVERINFO.DAT
Hi i have updated my AVIC-F10BT to version 2.004 like the main thread here say to do, then i have get the CNSD-210FM EU map from here http://binsearch.info/?q=CNSD-210FM+&max=100&adv_age=1100&server= and i have the replaced the VERINFO.DAT with the one in Pionara's add, when i put the SD card into my device it show the SD card icon in colors, so it know i have an SD card in the SD slot, but nothing happens, its not starting, my map now is an orginal CNSD-110FM/EU5, why cant i run the CNSD-210FM install ?
I can see here, that another have the same problem with the CNSD-110FM, that he used the CARDINFO.cid from a US version on the EU version and then the map install started, but he was getting a few drawbacks.. http://avic411.com/index.php?/topic/29150-cracking-the-z11020bt-f10f20bt-included-region-changing/?p=230427 ..
Can see that i need to make some changes in the CARDINFO.cid for the madupdate CNSD-310FM if using EU http://avic411.com/index.php?/topic/35601-cnsd-310fm-eu-2012-update/?p=258776 someone know if i need to do this also to the CNSD-210FM CARDINFO.cid, and if yes what do i changes ?
Edited Feb 12, 2013 by tpbillund
Posted Feb 13, 2013 · 03:37 UTC#242
you dont need to upgrade to cnsd-210fm or any intermediate version. You can take f10+ or f920+ straight to 2012 (cnsd-310fm) software. You may just need to edit or use cardinfo.cif from previous version. See the instructions in the appropriate 2012 update thread. It's really not that hard!
Posted Feb 13, 2013 · 07:50 UTC#243
So u say i can use the cardinfo.cif file from my legal CNSD-110FM and overwrite the cardinfo.cif file in the not legal CNSD-310FM with that, and then is "maybe" work ?
Posted Feb 13, 2013 · 14:49 UTC#244
Sorry cannot help you with illegal things. If you have legitimately obtained version of CNSD-310FM, then my method is a simple way for you to install your legal software without having to enter the password.
The cardinfo.cif does not contain version information - only hardware model information. It's just a "marker" file that indicates to the unit that there is an upgrade card inserted. It has a list of hardware models encoded into it, so that is why certain cardinfo.cif's work only on certain models. Because the cardinfo.cif provided in some updates are only for certain models (like f930 & f30), I provided some instructions on how to update that cardinfo.cif to recognize older units.
Did you follow this information:             #2
Posted Feb 13, 2013 · 17:02 UTC#245
i have updated to 310 thx.
Posted Feb 22, 2013 · 20:53 UTC#246
First of all: hallo to everyone
Second: sorry for my bad english
now I explain: i've an avic f310bt with 2009 maps, i've upgrade the firmware version from 1.0001 to 1.0004 by the official pioneer firmware. Now some questions:
-should I update it further? (in which post of this site can find the new upgrade)
-after the new upgrade what maps should I download from various post of thi site? (i'm in italy) (CNSD-210FM or CNSD-310FM)
-should I use a 2 or a  4 gb sd?
Thank you for your attention.
Luca
Posted Apr 20, 2013 · 19:52 UTC#247
The download link for CNSD-210FM EU isn't working anymore. Can somebody reupload the files?
Thx
Posted Feb 28, 2014 · 22:01 UTC#248
x2
Will this work on F320BT ?
Posted Apr 22, 2014 · 09:21 UTC#249
Hi everybody,
I'm desperatly looking forward a link for downloading : CNSD-210FM EU (for AVIC F920-BT) ....or another updating file more recent than 2011 ?
Can someone help me please ???? I would really appreciate !
Bye
Posted Jun 09, 2019 · 18:50 UTC#250
Hi all, sorry for necroposting, but this is the only fotum talking abount f320bt and map  update, with some working link. I was able to find 2 torrent links working, both with 1 seed, but not downloading..... Can anyone please reupload the CNSD-210fm for the f320bt? It will be very appreciate....
Please.....
Page 10 of 11
