CNSD-210FM European SD Card download (2011)
By PeterMmX · Aug 09, 2011in Hacks/Mods💬 251 posts👁️ 128,387 views
Page 5 of 11
Posted Oct 17, 2011 · 14:25 UTC#101
I cant download the Shortfuse crack, when I click I will be redirected to the main page.. can somebody plz help ?
Posted Oct 18, 2011 · 17:11 UTC#102
Worked perfect on my AVIC-F920BT - now with new maps.
Thx to everyone who contributed!!!
1. Used the original Update from Pioneer; v.2.00300 From 30-08-2010
2. Pulled the two StefanSki crack-files inside and overwrote the org. files (one in the main folder and one in APL folder) put the SD-card in the stereo. It updated and rebooted fine. It took 4-5 minutes.
3. I took the SD 2, BT files and overwrote the BT files in SD 1 - so I had all the files for the update. No need to downgrade BT firmware.
4. Updated the Bluetooth first - it took 2-3 minutes.
5. Updated the maps, firmware with the new CNSD-210FM - it took 30 minutes.
Posted Oct 24, 2011 · 10:31 UTC#103
Im trying to update the F10BT , what happened :
Till step 5 it goes perfect, he updated with the cracked files, after that I copied the CNSD-110fm files into the SD card but noting happens, I tried till step 5 to crack the device again but then nothing happens, what can I do ?
Posted Oct 24, 2011 · 10:36 UTC#104
Hi
I have a question,when I unzip CNSD-110fm i got Pioneer.exe file and when I unzip CNSD-210fm EU I got two folders SD1 and SD2 is that correct?
Thanks.
Posted Oct 27, 2011 · 19:48 UTC#105
I got the same problem, anyone know how to fix this??
Posted Oct 27, 2011 · 20:41 UTC#106
Hi , i've uploaded the Shortfuse Crack here: http://fileape.com/dl/iCieNSjBzvv2L7w1 hope this can help you ;-)
Posted Oct 27, 2011 · 21:20 UTC#107
I thank you very much with a avic f20bt I have it updated and running thank you very much from Spain
Posted Oct 27, 2011 · 21:26 UTC#108
with this user and the explanation of the post 102 is the one that came out to me at first, follow the steps one by one and in no time you have it done, thanks again
Posted Oct 31, 2011 · 11:09 UTC#109
Hi,
Congratulations for the wonderful forum, and sorry for my bad English.
I have a AVIC F920BT and I wanted to know if the European version is fine on my system which is Italian, so if I can do the update, thank you very much and good day
Posted Nov 02, 2011 · 18:39 UTC#110
Hi,
yes italian is european version too! you can use this info to upgrade your device! g.l.! my version is dutch and it worked perfectly until 5 days ago... my car got stolen so now the new owner has an updated 920bt in his/my car :(
Edited Nov 02, 2011 by Sentic
Posted Nov 04, 2011 · 00:23 UTC#111
Congratulations.
will I be able to execute this procedure and include other countries map in the US version of the Z130 or is it better to purchase Z120 to guarantee success ?
Edited Nov 04, 2011 by mizonn
Posted Nov 04, 2011 · 22:41 UTC#112
Superb!! Have just now updated to the latest maps and firmware :D :D
Big Big thanks to shortfuse/stefanski/Dr Mong and PeterMmx for the crack, installation steps and the whereabouts of all the files and map updates.
The shortfuse crack can be found on this thread for all looking for it...
http://avic411.com/i...10bt-to-z120bt/
Edited Nov 04, 2011 by Laney
Posted Nov 17, 2011 · 20:12 UTC#113
Updated post with link for download and manual how to update F10bt/F20bt to the newest F30bt 2011 maps
I got it from digital-eliteboard forum but here it is - the 2011 European Map Update from Pioneer for Avic F10bt/F20bt/F30bt - CNSD-210fm.
CNSD-210FM Eu Version
Password for file is: digital-eliteboard
Torrent FILE : CNSD-210fm EU.rar or LINK to Torrent file - Please forgive me but I will only be able to seed it tmw from 10-6 GMT+1 as I only have broadband @work. Please be patient!
Manual to update F10bt to F30bt (For F20bt users start from Step 10 but download the file from Step 9 - doesn't matter if your device IS or IS NOT updated to 2.003 version - You STILL have to download 2.003 update from Pioneer to use it with StefanSki crack):
First of all check version of firmware that you currently have on your device - mine on the beginning had version 1.000 (yours can be already updated to 1.001 but you still have to start from Step 1) - that was the beginning of my story.
Step 1. Download ShortFuse crack from here: ShortFuse Crack
Step 2. Download 1.001 update for Pioneer Z110bt - http://ds1.downloadt...re/1.001000.zip
Same procedure as with US version - what made me think it didn't work was after flashing the ShortFuse Hack I got 1.0001 version not the mentioned 1.0002!
Step 3. Extract ShortFuse crack and extract 1.001 update to separate folders and copy&overwrite 2 files from ShortFuse crack into 1.001 update folders - File from ShortFuse folder called EU090APL.VER should be put in AVICZ110 (from 1.001 update) main folder (it will ask you if you want to replace the file) and then second file from ShortFuse folder called RenewalIFLib.dll should overwrite/replace the file in AVICZ110 / APL (from 1.001 update)
Step 4. Copy patched with ShortFuse crack AVICZ110 folder from 1.001 update to clean, formated to FAT32 file system(with default cluster size!) SD Card - you should have only one folder called AVICZ110 on the SD Card.
Step 5. Put the SD Card in your F10bt - it will start the update immediately - do not turn of your radio during that process !!! It may take up to 10minutes to finish.
Step 6. When it's finished your device is able to accept any password for CNSD-110fm update
Step 7. Download EUROPEAN version of CNSD-110fm from THIS website: http://linkcrypt.ws/...r919151s0xxj509
When you download all the parts - get it unpacked and use the same procedure as you would do with us version (copy content of SD1 folder to a 4GB or larger SD Card formated in FAT32 file system with DEFAULT CLUSTER size).
Step 8. Put the SD card into F10bt and it should ask you if you want to proceed with the upgrade. Type in ANY password but use ONLY LETTERS - no digits. It worked perfect for me the first time i did it. The update took about 30-35minutes. Now your device is updated to F20bt - congratulations! Don't forget to update your bluetooth by going to Settings/Bluetooth/Scroll down to firmware update/ and proceed with the update to 3.10 version. After update to 3.10 is finished delete the content of sd card and use the folder Firmware from SD2 from CNSD-110fm and paste it on the SD Card. Proceed with the update of Bluetooth to 3.11.
Step 9. You can proceed with the update to 2.003 after you updated your device to 2.000 - you'll get it from here : Pioneer F20bt 2.003 update You only need to put the AVICZ110 folder from this update on the SD Card and put it into your F10bt upgraded to F20bt - It will ask you if you want to proceed with the update (I'm not sure if it did or didn't ask for your decission - can't remember).
Step 10. Now, time for the last stage - Thanks to StefanSki - update 2.003 to 2.004 the same way as in step 1 to step 4 but download StefanSki crack from here: AVICZ110BT-2.004.zip
For 2.003 use the folder downloaded in previous step 9 and patch it with downloaded files from StefanSki crack - I personally think that you can proceed straight from 2.000 to 2.004 without updating from 2.000 to 2.003 but I went the way described above.
Step 11. Download CNSD-210fm European Version from here: CNSD-210fm EU Version Password for the archive is: digital-eliteboard
Step 12. Put the content of SD1 folder from the CNSD-230fm EU Version folder on the SD Card (4GB or larger) and insert the SD to your F10bt/F20bt - it will start the update that will take around 30minutes. After this you have F10bt updated to newest 2011 maps and app version 3.000
Step 13. Update your Bluetooth by going to Settings/Bluetooth/scroll down to Firmware update/ it will ask you if you want to proceed with the Bluetooth 3.10 update - accept it. After it is done clear the card and use the folder Firmware from SD2 of CNSD-230fm update - process to Bluetooth firmware update and that will update your Bluetooth FW to 3.22.
And that's it - your device will be updated to the newest version.
All credits go to ShortFuse, Condiczek (for his GREAT support and cooperation) and of course to StefanSki for providing cracked 2.003 update.
One more and the MOST important thing : You're doing everything on your OWN RISK! There is always a risk of bricking your device!!!
NO RISK = NO FUN! :wink:
this maps work on the Avic-F320bt too?
Posted Nov 23, 2011 · 15:53 UTC#114
I humbly Solute you guys for making this work!!!!!!!!!
Keep up the good work!
The UI seems a lot more responsive than before, haven't checked the Navigation.
And I know the Can-bus has been updated for VW & Ford cars, did any one got that to work?
According to the specs, you should see your park-assist in the screen + Airco control.
Do we need a separate cable for that?
Posted Nov 24, 2011 · 14:32 UTC#115
Hi, first of all thanks for all this information to upload my avic F10, great work by you all guys (even it´s not to easy to do). I´m downloading all the things in the first topic (any last advise?) and when I got to " Download 1.001 update for Pioneer Z110bt " I was stuck on file 3 that seems to be broken. Can anybody help me here?, is there other way of getting these files or other options of doing all this. Thanks
Edited Nov 24, 2011 by foxymans
Posted Nov 24, 2011 · 14:45 UTC#116
Hold on fiends, it looks like I can download this file in my 12º atemp. I´ll keep you updated if I have futher problems, thanks
Posted Nov 26, 2011 · 09:20 UTC#117
Patience, lots of patience and time, but finally done. Lots of thanks to all of you, all topics help me a lot. soon it will be back to it in 2012, jeje. Chears
Posted Nov 26, 2011 · 10:16 UTC#118
Hi.
since im not good with computers etc i need help to update my avic-f10bt.(updated to f20bt)
i have
firmware: 2.0000
bluetooth: 3.11
if someone can send me a pm with exactly witch step i need to do, i will reward 50$ to the person sending me the "update from f20bt to version 3 guide for dummies".
Thank you. :)
Posted Nov 26, 2011 · 23:53 UTC#119
... i will reward 50$ to the person sending me the "update from f20bt to version 3 guide for dummies".
I thought that's what this thread was. :-P
Posted Nov 27, 2011 · 22:32 UTC#120
Hi guys,
I'm totally new to this forum ( I live in Germany) and right now trying to update my F10BT to the F20BT - I used the shortfuse way to get to FW 1.001 which seemed to work. Unfortunately I can't do any updates besides this. When I put the SD-card with the cnsd-110FM update in the machine nothing happens. Maybe the test mode can help, but what do I have to press precisely to get there?
Thanks in advance,
Ossi
Posted Nov 28, 2011 · 13:14 UTC#121
I'd forget TestMode, there's something wrong with your SD. What format is it - should be FAT32. Next, name the files in the root directory. One common problem is that the extracted files are not in the proper hierarchy.
BTW, The ShortFuse hack should leave you with V1.003 - which you should verify. However, even without the hack, that is not why nothing happens when you insert SD1.
I can only think of 3 possible problems:
1 - something wrong with your SD - reformat or try another.
2 - SD files are not in the correct dir tree layout
3 - You already have V2.0 (or higher) installed.
BTW, why are you installing CNSD-110BT? After the Shortfuse hack (1.003), you can go directly to CNSD-210BT.
Edited Nov 28, 2011 by RonS
Posted Nov 28, 2011 · 20:20 UTC#122
Hi everybody, hi RonS
I finally made it to F30BT with the new bluetooth update and FW 3.000 - don't ask me what went wrong so many times before. The only thing I can think of is formatting the (new) SD-card before doing a single step.
So "all's good, that ends good",
Thanks to everyone making this possible.
Ossi
Posted Dec 03, 2011 · 17:07 UTC#123
I came back to this forum after a long time and see that it is possible to update 120BT to 130BT. I am in US. Can someone please link me if there are instructions already written on this forum to save me time from digging through forums and different threads? I would greatly appreciate it and TIA.
Posted Dec 10, 2011 · 11:23 UTC#124
hello, the process of updating to 3.00 it takes about 30 minutes?
that is, as my car has a system EcoMode (disconnects the radio after about 15 min), it is better to do updates on the working car?
Posted Dec 10, 2011 · 15:30 UTC#125
Yes, you could damage your unit if your "EcoMode" shuts off power during the flash of the new software. If you can't disable that, then either connect your red and yellow wires directly to your battery, or (much easier) do it while the engine is running. Do it outside, just to be safe.
Page 5 of 11
