By copying the below files you can try out Primo on your unit. Be warned, you will not have the same functionality that you did with the original iGO. With a f500bt this is not an issue as I only use mine for a GPS, nothing else. With other models which are used for radio, ect some of these abilities may be restricted while Primo is running. Primo does not replace the stock iGO on your GPS, launching it merely ends the process of ezrider and then starts Primo. Upon a reboot of the unit all original functionality is regained and the unit will load normally.
Warnings
Before attempting install and run Primo make a complete backup of your current AVIC My Flash Disk just in case something goes wrong. You are and only you are responsible for your AVIC! Note I have tested it on a F500BT and I am not sure how it will behave on other units.
Launch Options and Installation Instructions
At this point, you have several options to launch Primo;There are some caveats with each, they will be described below.
Option #1: If you use Diaftia's mod downlaod the main package and the update in post #2, and copy to your unit.
Option #2: Install Chuck's latest Mod. See post #1 of his thread: http://avic411.com/i...ted-2011-07-15/ You will have to launch Chuck's Mod and start Primo through a shortcut in his Apps #2 menu. Using this option your AVIC will still allow the back-up camera to kick in when in reverse, and the unit will properly go into standby when the vehicle is turned off. Chuck has reported that X710BT, AV playing fine, able to switch between radio and SD MP3 music. **TTS voices are no longer included, see post #2 for link. Chuck has included this version of Primo in his latest update.
Option #3: Use the provided testmode to auto-launch Primo when your unit is turned on. This method can be used with any mod, for those of you who are not using Chuck or Diaftia's mod. Note that if you launch this way the unit will turn off and restart when the ignition is turned off/on and the unit will not go into standby.
To launch using this method, follow the directions below:
Option #3:
1. Download the AVICmod file from the link in option #1.
2. Unzip, copy to SD Card. Insert card into unit. If you are using another Mod beside Chuck's, delete the ui_pioneer folder (found in ALP2\iGo\ ui_pioneer) from the SD card before copying to your unit.
3. Boot you AVIC. From the SD card, copy the Primo folder (SD Card/My Flash Disk/APL2) to you unit (My Flash Disk/APL2). Ensure a path exists on your unit which is My Flash Disk/APL2/Primo/Primo.exe.
4. Download this file: Testmode.rar
5. Unzip, copy to SD card. Insert in unit, boot and Primo should launch upon startup.
There are other methods to use Primo on your device (such as the Russian mod, found here: http://avic411.com/i...__1#entry221492 ).
Important Notes - read on
To enable sound on your unit put in an SD card with music on it before launching Primo.
Enjoy everyone! Please provide some feedback and feel free to offer any advice on how to better integrate Primo into our units.
Thanks to the creators of GJA for modding this awesome version of Primo and to Chuck for his awesome mod, and for dedicating so much time to help people with their AVICs.
Changelog:
-AVICmod 10.11.11 - Chuck's UI files removed as he has provided Primo as an update in his thread, a few other tweaks.
-AVICmod 09.22.11.2 - Chuck's autolaunch is now included.
-AVICmod 09.22.11 - Cleaned up sys.txt file, soft key enabled in stock Top Menu to bring you back to Primo, many schemes deleted to save space, HardKeyTest file included (launch through quick menu/external programs) to enable hard buttons within Primo; buttons restored to default upon reboot.
-AVICmod 09.13.11 - Updated to Primo version 1.2, new GJ skin included. Hard buttons working, but only when booting off testmode on SD. Voices omitted, see post #2 for links. All TTS Pro voices now working!
-AVICmod 09.11.11 - Shortcut in external programs to view stock Top Menu for 30 or 60 seconds. A finger friendly way to change settings not controlled by Primo without minimizing/restarting.
-AVICmod 2.09.10.11 - Save folder included, sound issues hopefully resolved.
-AVICmod 09.10.11 - Updated data.zip, GJA 2.6. Primo Icon in Chuck's mod now working. Save file deleted, all settings are default.
-AVICmod 09.09.11 - Original
