AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 13 of 28
Posted Jan 15, 2012 · 21:15 UTC#301
Hey Ryar,
Just happen to pass-by and glad to see you're doing great. You're almost the only one right now to make the forum run and everyone owes that to you. Continue my friend! :)
I see that you have also made Primo 2.0 working great too and I'm really interested to see its new functionalities. I would incorporate it to my existing mod instead of using AVICnet though, but I believe that it would be only for my own usage, since my thread is now almost dead!
Not too late still can say Happy New Year to everybody!
Chuck.
Hey Chuck, it's nice to hear from you! Happy belated holidays to you as well. Unfortunately there are few new features with Primo 2.0 however I find it to run much smoother with higher fps which is a welcome and impressive change. A few things I have noticed, the upload on this thread has a custom skin built in. One thing I have found is after updating to GJ's newest skin Primo wasn't quite as snappy, be warned it is best to use it as downloaded for best performance. I haven't attempted to get TTS working with 2.0 however for those having issues make sure to use TTS files which worked with 1.2 and not 1.0. I believe they are on the 2nd post of the Primo thread.
Edited Jan 15, 2012 by ryar
Posted Jan 15, 2012 · 21:30 UTC#302
can someone help me I'm trying to run the app of my SD card, I try the step in the installation post but it doesnt since to work for me or I would like to put the content folder on my sd card and have IGO and Primo Grab it form there. If Anyone know how to do it plaese reply with the code so i can copy and pasted on Sys.text under folder. Any help will be appreciated. thank you
Make sure to delete all lines under (FOLDER) in the sys.txt. Primo will then look in the content folder for maps, ect.
Please excuse my unknowing. Is there a specific model we need to look for when downloading maps for TomTom or Garmin? I didn't see any specifics on that.
Also, is there a way to make the PRIMO the default map? When I load Primo, it loads the Primo w igo8, when I hit map, it reverts back to the w/o igo8 map look?
Going to try this out, just installing now. Coming from Abb's mod that has been installed for over a year, needed a change for a bit. Looks good, hope it runs good. Installing on a f90bt.
For TomTom the maps must be activated to your specific unit which is a bit of a process, do a google search and it will yield results on how to do this. I got the maps working and then deleted them to make room for more content for Primo, TomTom is lightyears behind Primo IMHO and not worth the space for maps. For Garmin it is a little easier, you can located and download pre-activated maps.
The button mappings only work on Primo 1.0, however for 1.2 and 2.0 the buttons will have the same functionality as stock. It seems NNG is buckling down with newer versions of Primo to handicap many functions on devices which were not originally shipped with Primo.
Posted Jan 15, 2012 · 23:55 UTC#303
Thank you Ryar, I did get IGO to grab the Map From the SDcard by Putting this code under folder
content="Storage Card\Content"
However I try doing the same step to primo and it doen't work.
Posted Jan 16, 2012 · 04:39 UTC#304
Ah, dang it, got the VSS issue with PRIMO.
Just to be clear.
1. Unhook VSS wire.
2. Hard reset.
3. Restart unit and open PRIMO
4. Once GPS is locked I can reconnect VSS?
Is this correct?
Edited Jan 16, 2012 by nissanfrontier
Posted Jan 16, 2012 · 14:58 UTC#305
Ryar,
I use diMkaWA P1.51 skin and didn't have the frame rate problem. Make sure that you use the GJ skin destinated for Primo 2.0.
I also have TTS Pro operational with the VAUTOV5.DLL and tts_nua_v5 folder sitting in the base Primo folder, there are 3 or 4 US English voices.
Please note that I embedded Primo 2.0 into my mod, so your usage with AVICnet might vary ... I also use the previous SYS.txt for Primo 1.2, but change the device name to device="Primo", but I don't think that matters.
As for the new features, the single most important one that I retained is the Artificial-Intelligence for congestion-detection and suggested alternated routing. I love it.
However the double-clicking to bring up the top Primo menu is no longer working? Any change that I should perform in the BUTTON.* or related setup?
Later!
Posted Jan 18, 2012 · 07:16 UTC#306
Hi, I have a problem. Can not see the camera back ... notice them, but the picture is not - see. photo.
P.S. yen in Prima.
Posted Jan 18, 2012 · 12:55 UTC#307
I know this is going to sound greedy...
Has anyone managed to get TMC working in Primo 1.0? I've got it working in 1.2 and 2.0 but I'd really like to have it in 1.0 as well as that one comes with audio enabled automatically.
Alternatively, are there any signs of 1.2 or 2.0 getting audio to work automatically (ie without playing an audio file from the scdard before launching).
Posted Jan 19, 2012 · 03:56 UTC#308
Alright, sorry for the questions, but when I haven't hacked in awhile, I get a little mixed up. I am trying to put PRIMO 2.0 on this thing now to check it out. I put the Prim3 folder in the APL2 folder and no Primo 2 icon. So I deleted everything out of the APL folder except iGo folder with maps, etc and installed the PRIMO3 folder and still nothing. Could you direct me a bit, please?
Posted Jan 28, 2012 · 03:10 UTC#309
main package links not working?
Posted Jan 28, 2012 · 12:03 UTC#310
Just to be clear.
1. Unhook VSS wire.
2. Hard reset.
Is this correct?
The VSS doesn't matter, it is the gyro which is the problem on the f900bt. You can hook it up and it will work fine.
I wouldn't say there is a framerate problem, I was just making an observation Primo runs smoother without custom skins.
Make sure to copy the files in the USER folder, these are the ones which will give you the new icon to Primo 2.0.
I will re-upload this weekend sometime. Thanks for letting me know.
Posted Jan 28, 2012 · 12:09 UTC#311
Not sure bud, it should work if the lines in the sys.txt are deleted. Since Primo shares content with the stock iGo, why not run if from your units flash disk? It takes minimal space without content.
Not sure about TMC but we need someone comfortable with decomplining exe files in order to get audio to work regardless of source. I have an idea where the issue lies but am not skilled enough to pick apart an exe. As our units are aging there is less interest in modding them, at this point unfortunately it appears as though we will not get sound working in 1.2 and 2.0.
Too bad, I was playing with one of Pioneers new in-dash GPSs at the store the other day and the stock gps program is terrible compared to Primo IMHO. A good example of how newer isn't always better.
Edited Jan 28, 2012 by ryar
Posted Jan 28, 2012 · 17:47 UTC#312
Μany greetings from GREECE. Please upload main package link. I follow the topic for 3 weeks. I have placed the Italian version but my Italian is non-existent and I can not set up. Between us, my English is not so quite well but I think I will do better thanks. I wait 3 weeks (for links) so I decided to write even from automatic translation.Thank you again very much
Posted Jan 28, 2012 · 23:23 UTC#313
Hotfile deleted all my uploads! I re-uped everything in post #2 of this thread, enjoy.
Posted Jan 29, 2012 · 08:23 UTC#314
thanks!!!!!!!!!!!!!!!!! A LOT!!!!!!!!!!!!!!!!! :-P :-P :-P :-P :-P :-P :-P :-P !!!!!!!!!!!!!!!!!
Posted Jan 29, 2012 · 17:00 UTC#315
Does CE6 improve start up time at all?
Edited Jan 29, 2012 by redz_newbie
Posted Feb 13, 2012 · 15:18 UTC#316
Hi, I would like to share some experience with you and ask you for advice with this problem:
After some time (don’t remember when exactly it happened and why) when Primo2 is on and I hit reverse gear the monitor does not switch onto a view from the reverse. All it shows is a warning of an upside down picture. I don’t know how to get back to the main menu when Primo2 is activated to turn on automatically. Should I deactivate the automatic switch on of Primo2?
I would also like to ask you for help with Mapchanger – how do I turn it on? I’d like add another map to SD card but I don’t know how to set directions.
Pat
Posted Feb 16, 2012 · 19:34 UTC#317
Ryar do not know the answer?? Please ... :idea:
Posted Feb 17, 2012 · 10:31 UTC#318
Hi there Patper! For your camera problems probably the best solution would be to install from scratch and after all your settings and favorites are set up back up your my flash disk in case you start having issues down the road. I run Primo 2.0 and my f900bt changes to and from the back camera without issue when reverse is engaged, I'm not sure specifically why you are having this problem.
You can't enter the avicnet menus while Primo 2.0 is running; part of the launch process kills ezrider in order to free up memory. If you need to change any settings from within the avicnet menu screens make sure to do so before launching Primo 2.0.
I have never used mapchanger, depending on what skin you are using it may be worthwhile to visit a forum where the skin is located for directions on how to use it. I found the following info with a quick google search, hopefully it helps:
Mapchanger operation
You should have the maps from the different map providers in separated subfolders within the Content folder. I presume you have currently one map folder in Content folder. Prepare two additional: the map_nt and map_ot. Copy the TeleAtlas maps to the map folder, the Navteq maps into the map_nt and the other (e.g. local CEE map providers) maps into the map_ot folder. Finally include the below section into your sys.txt as well. Take care about the name of your storage media in the path! Wayteq devices call the (micro)SD cards SDMMC.
[switchmap]
changer="\SDMMC\Primo\Utility\MapChanger.exe"
1=",map_ta,\SDMMC\Primo,,"
2=",map_nt,\SDMMC\Primo,,â€
3=",map_ot,\SDMMC\Primo,,â€
During the operation no maps are copied at all. The application mapchanger changes only the name of the map folders. The folder holding the actually selected map set is named: map, the other two are map_ta or map_nt or map_ot depending on the selected one.
Good luck Patper!
Posted Feb 17, 2012 · 15:08 UTC#319
Ryar and Patper, I did note rear view camera not working issue after Primo 2.0 was launched, in very rare occasions. It just not responds at all when you shifted to backing up or it just flashes the AVIC screen then back to Primo. When this happens, multiple tries do not help.
It also happened that the MP3 playback (never radio yet) just stop working when you shifted to backing up, and you have to change A/V source back to SD or USB in order to continue playback.
Therefore there must be some sort of interference between the A/V module and Primo 2.0 not been the native GPS navigation software on our AVIC.
Edited Feb 17, 2012 by Chuck88
Posted Feb 20, 2012 · 09:52 UTC#320
Hi. I'm from Spain, and I'd like to know if there is any way to change language to Spanish.
If you wish, I could translate it to Spanish (my English is bad, but my Spanish is perfect) :mrgreen: I just need the files I have to change, (or the way). Or pass me the text for the translation, if possible.
Thanks.
Posted Mar 20, 2012 · 08:55 UTC#321
Hi friends!
Maybe I'm totally stupid, but I can not figure it out how to do it .....
Posted Mar 20, 2012 · 18:55 UTC#322
Hi friends!
You can not enter the menus with Primo 2.0 running. It is possible if you used some low memory requierments settings in the sys.txt and did not kill the ezrider process. You would also need to prevent the soft reset "button" program from running when Primo is launched. If you would like to do this, delete or comment out the following lines in the My Flash Disk\APL2\Primo3\Run\primo.mscr file:
kill ("ezrider")
kill ("ezrider.exe")
and
Run(SystemPath("ScriptPath")\"Button\softreset.exe" )
As for the low memory requrement settings in the sys.txt, start by adding these lines and adjust them if you are still having issues:
[debug]
max_memory=35000000
reserve_memory=1700000
cache=600000
On another note, Ovalball for some reason the link you gave with the voices for Primo 2.0 did not work for me, perhaps due to my IP address beinging in North America? If it isn't too much trouble could you please re-up it? My SSD bit the dust awhile back so I lost alot of files and whatnot :(
Edited Mar 20, 2012 by ryar
Posted Mar 21, 2012 · 14:31 UTC#323
Ryar
Working away until Friday,I will check it out then.Great to here from you!
Posted Mar 24, 2012 · 05:33 UTC#324
Great, thanks Ovalball! May your AVIC guide you home safely :)
Posted Mar 25, 2012 · 15:10 UTC#325
Ryar
Can you please PM me with your e mail address and i will sen th dircetly.Damn Rapidshare!!
Page 13 of 28
