AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 12 of 28
Posted Jan 01, 2012 · 16:16 UTC#276
It works - in my SYS [device]
type="PIONEER746EW".....
Edited Jan 01, 2012 by patper
Posted Jan 02, 2012 · 14:09 UTC#277
Hi everybody.
I'm gonna trying to update my F910BT with the latest AVICNET EU version.
The language of the software is even in Italian or only english?
Is TMC working?
Thank you very much
Luka
Posted Jan 04, 2012 · 17:21 UTC#278
Hi,
functioning TMC + GJ-AK skin for iGO Primo 2.0 v1.02 ...
Edited Jan 04, 2012 by patper
Posted Jan 05, 2012 · 08:45 UTC#279
Thank You very much for your help :)
You are right, but for your version and TMC of your Country
I'm talking about TMC for Italian RADIO
Edited Jan 05, 2012 by lukappaseidue
Posted Jan 06, 2012 · 21:11 UTC#280
wow, great job with everything on this thread! I had some time to kill and slowly skimmed through this whole thing. i have an f90bt that i updated to v3 a long time ago, and now i'm thinking about attempting this.
i am an idiot when it comes to these things sometimes. so i've already bookmarked this thread! haha
dumb question no.1:
a majority of what i've seen on here refers to GPS customizing and internet functionality. while i would LOVE the internet functionality, the GPS stuff isn't that important to me, though it would be cool. but i havent seen anything about how all this works with bluetooth phone operation or satellite radio, as well as regular radio and ipod integration. what exactly is the usability of these items with this update?
Edited Jan 06, 2012 by blinkbomber
Posted Jan 06, 2012 · 21:43 UTC#281
did just watch this though... VERY impressive and desireable, but he didn't even play any music, lol...
http://www.youtube.c...bed/gwHOtPJxJd4
Posted Jan 07, 2012 · 04:24 UTC#282
It's the same thing, just an Italian version of avicnet. The creator has been watching this thread and added hobd and Primo 1.0 with sound and buttons which he got here. To answer your previous question all music and bluetooth should work as it did with stock.
Edited Jan 07, 2012 by ryar
Posted Jan 07, 2012 · 20:00 UTC#283
after installing hobd driver and copying everything from that folder i cant get the obdii working i have f900bt and the same elm adapter connected to the usb of my unit wanter to make sure that i have connected it to the right usb dont know if there is a usb in the back of my unit.. any help would be appreciated i tried different port numbers could not get it to work..
Posted Jan 07, 2012 · 22:07 UTC#284
OK, try these steps in this order:
1) Install driver (cab file)
2) Soft Reset
3) Check ports (My Flash Disk\System\serialports), make a note of which ports are used.
4) Plug in OBDII reader
5) Check ports again (My Flash Disk\System\serialports), OBDII should be on port 3, which was not present earlier.
6) Run HOBD, select port 3 (assuming serialport program shows OBDII as port 3)
The driver should auto-load when the OBDII reader is plugged in after the cab file is installed, checking the the serialport program before and after is a good indication if it is recognised.
Posted Jan 08, 2012 · 12:35 UTC#285
Hope I'm not being a numpty by asking, but with Primo 2 the POI seem to be a bit scrambled. I can't get speed cameras to appear (which isn't a POI I know but still...), some don't appear, others appear but are not designated as what they are, ie I get a Bar for a Parking? This isn't consistently so, but is there an issue, or have I missed something?
Posted Jan 08, 2012 · 14:33 UTC#286
hey Ryar I'm trying to update my f90bt from FX 3.1 to AVICnet, but when i try doing it it tell me that the disk doesn't have enough space. Any help will be kindly appreciated.
Posted Jan 08, 2012 · 18:17 UTC#287
Try deleting all the map,poi,building files that you don't need.Get rid of maps which you won't need.
Posted Jan 09, 2012 · 00:33 UTC#288
OK, try these steps in this order: 1) Install driver (cab file) 2) Soft Reset 3) Check ports (My Flash Disk\System\serialports), make a note of which ports are used. 4) Plug in OBDII reader 5) Check ports again (My Flash Disk\System\serialports), OBDII should be on port 3, which was not present earlier. 6) Run HOBD, select port 3 (assuming serialport program shows OBDII as port 3) The driver should auto-load when the OBDII reader is plugged in after the cab file is installed, checking the the serialport program before and after is a good indication if it is recognised.
thanks alot i got it...
Posted Jan 09, 2012 · 03:21 UTC#289
Hmm, I didn't notice any difference. I only use 1 POI file, I believe using multiple map files with Primo has caused other grief in the past. Maybe try just 1? You can comment out or delete the lines for the shared POI filets in Primo's sys.txt file. It is:
poi="..\..\IGO\content\poi"
You can then add which POI files you wish to the Primo3\content\poi folder. Hopefully this will help, if not try deleting existing POI files and udpating.
Edited Jan 09, 2012 by ryar
Posted Jan 09, 2012 · 18:52 UTC#290
Thanks it Work
Posted Jan 09, 2012 · 19:10 UTC#291
OK guys since I'm new doing this I like to know if by deleting the folder of the app you don't want will delete the app or is their more to it for example if I go to APP2 folder and delete the Primo folder will it delete the app or is their more leftover somewhere else. I also like to know if all map compatible with all GPS app or no. OK one more thing since I'm in USA How would I delete all non English voice. I though it would be in the Voice folder but them file are to small so I though their would be more to it in another folder.
Posted Jan 11, 2012 · 03:55 UTC#292
Hey Ryar,
Just happen to pass-by and glad to see you're doing great. You're almost the only one right now to make the forum run and everyone owes that to you. Continue my friend! :)
I see that you have also made Primo 2.0 working great too and I'm really interested to see its new functionalities. I would incorporate it to my existing mod instead of using AVICnet though, but I believe that it would be only for my own usage, since my thread is now almost dead!
Not too late still can say Happy New Year to everybody!
Chuck.
Posted Jan 11, 2012 · 07:18 UTC#293
Chuck,great to hear from you again.Best wishes for 2012,and hope you continue to visit,we need you!
Posted Jan 11, 2012 · 14:32 UTC#294
Hey Ryar, Just happen to pass-by and glad to see you're doing great. You're almost the only one right now to make the forum run and everyone owes that to you. Continue my friend! :) I see that you have also made Primo 2.0 working great too and I'm really interested to see its new functionalities. I would incorporate it to my existing mod instead of using AVICnet though, but I believe that it would be only for my own usage, since my thread is now almost dead! Not too late still can say Happy New Year to everybody! Chuck.
Hey Chuck, I connects to the wishes of the new year :)
AvicNet with Primo 2 is nice, but can be better with Primo2 only :( So is there any possibility to convert PioneerUI skin for old IGO8 to the new .lua format ? Or we can use some other launcher like ExtlLaucher, but we can't get a working copy of this :( I think that this is an inevitable step because old IGO waste system memory and storage size only for nice avicnet menu.. but how it can solve this ? any ideas? are we looking for some programmer or hacker? :)
lot of work is already done, so thank you to everyone who contributed
TM
Posted Jan 12, 2012 · 08:19 UTC#295
Great job to everyone involved with this.
Just a question - If using Garmin, OZI etc. Does ipod, radio and Bluetooth calling recieving still work?
Posted Jan 12, 2012 · 08:54 UTC#296
In one word, yes. Those functions are still available under the main menu and BT connects and works as per normal. The only thing that doesn't show is the AV icon in the bottom of the map screen.
Posted Jan 13, 2012 · 13:17 UTC#297
Just installed the base base package and I'm impressed! Primo is so much better than standard IGO.
Edited Jan 13, 2012 by saeb
Posted Jan 13, 2012 · 19:49 UTC#298
Has anyone who has installed primo 2 to Avicnet managed to get TTS and TMC to work?At the moment I can't get either to go.
Posted Jan 13, 2012 · 20:30 UTC#299
can someone help me I'm trying to run the app of my SD card, I try the step in the installation post but it doesnt since to work for me or I would like to put the content folder on my sd card and have IGO and Primo Grab it form there. If Anyone know how to do it plaese reply with the code so i can copy and pasted on Sys.text under folder. Any help will be appreciated. thank you
Posted Jan 15, 2012 · 19:55 UTC#300
Please excuse my unknowing. Is there a specific model we need to look for when downloading maps for TomTom or Garmin? I didn't see any specifics on that.
Also, is there a way to make the PRIMO the default map? When I load Primo, it loads the Primo w igo8, when I hit map, it reverts back to the w/o igo8 map look?
Going to try this out, just installing now. Coming from Abb's mod that has been installed for over a year, needed a change for a bit. Looks good, hope it runs good. Installing on a f90bt.
Edited Jan 15, 2012 by nissanfrontier
Page 12 of 28
