AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 10 of 28
Posted Dec 19, 2011 · 14:02 UTC#226
Hello,
Once installed Avicnet in EU dispositive I have the following problems are likely solution:
1 - The USB device is not recognized by the system (as if the key is not connected)
2 - Avicnet does an automatic reboot if I start (even, with inserted SD and without)
3 - Avicnet performed mute the car radio (even without running Primo), and do not activate it again (with Pioneer v2.07 I could hear the car radio and when the GPS speak the radio sound is muted, then continue the radio. When I was listening to the radio or USB or SD, GPS mute the music to speak). Not now, whenever I boot AVICNET radio is muted. (and the GPS speak over SD music - This is not a problem ) ¿?
I still use Primo 1.2 incorporate in Avicnet, is posible that Primo 1.0 (post 2) be the solution?
4 - adjustment of pioneer (not avicnet) MUTE button is inactive
And is it possible to use a USB phone as a modem? How? (nokia c6-01)
Thank for your contributions, and excuse me for mi bad english (I´m spanish)
Posted Dec 20, 2011 · 13:45 UTC#227
USB problem: Resolved (format FAT32 the USB key and now run OK)
The divx from USB cause many jumps, any solution?
Posted Dec 20, 2011 · 21:51 UTC#228
Likely your NAV unit is not capable of playing the divx file due to limited available resources. Have you tried using a divx file with a lower resolution?
Posted Dec 20, 2011 · 21:52 UTC#229
Has anyone found a USB wireless adapter that works with Windows CE 5?
Posted Dec 21, 2011 · 00:31 UTC#230
Hello,
Hi, I'm not quite sure what you are asking but will try to help.
1) Glad your USB is working.
2) It reboots after a hard reset (after booting into testmode or booting for the first time). This is to change the registry to support additional USB devices, load smaller DPI to make Total Commander easier to use, ect. Some users have reported a double reset each time the unit starts; I believe this may be vehicle specific due to a low voltage upon starting. I have been busy lately but when I find some time I will upload a fix so the double restart doesn't happen.
3) You could try Primo 1.0, although it is not as polished as 1.2 the sound and buttons work perfectly. Note the spoken dialog for directions does not mute the music like the stock iGo does; rather it speaks overtop.
4) Which mute button are you referring too? Is it in the settings somewhere? I haven't noticed this issue.
So far as a phone for a modem, I believe the drivers included are for certain usb 3g devices. It would be quite an accomplishment to share internet from a phone, but there are no RNDIS drivers present. At this point it is not possible.
On another note, did anyone else try HOBD yet? I bought the full version which gives you trends and graphs on most of the specs, wow is it awesome!
Edited Dec 21, 2011 by ryar
Posted Dec 21, 2011 · 02:01 UTC#231
Hy Ryar.
I ordered the ELM327 USB reader and waiting for it to come. When I do I will let you know how it works for me. Did you buy the full version of HOBD for $21?
Jimbo
Posted Dec 21, 2011 · 02:16 UTC#232
Yeah, I couldn't help it after trying the teaser free version.
Posted Dec 21, 2011 · 05:28 UTC#233
ryar I too ordered an ELM327 (yesterday.) Does HOBD allow custom codes to be programmed?
I have a Scangauge II and added codes for friction braking force and a bunch of custom data so I wonder if HOBD can do the same.
Posted Dec 22, 2011 · 05:28 UTC#234
I have a few questions.
1) Is it possible to replace igo8 with primo completely?
2) whenever I start Primo 1.0, after a minute or two I get a message saying something like: main power failed will continue on battery. Is it possible to fix that?
3) Is it possible to have the IPOD current track display like it did in igo8?
4) Is it possible to have the on screen highway signs display smaller?
-Thanks.
Posted Dec 22, 2011 · 22:48 UTC#235
I don't see anywhere where you can add custom codes in HOBD.
To answer your other questions,
1) I wish we could replace iGo8 with Primo, but unfortunately we can't just yet. I tried replacing the stock ezrider.exe with a Primo exe renamed ezrider.exe and Primo does boot but the "System startup, please wait" message does not go away and the unit reboots in about 5 minutes. The system seems to be looking for some confirmation from ezrider that iGo8 booted OK and Primo does not provide that confirmation. I searched and searched but couldn't find anything on how to remove that message, You can set Primo to autostart, it is a minor inconvenience waiting a little longer but at least the unit boots to Primo.
2) I think Primo was designed for dash-top units with batteries and it seems to get confused and display that message. There are many sys.txt commands and their explanations on many sites, maybe all it would take is the right one to insure that message does not appear. Again, it is a minor inconvenience that wouldn't be worth the time it would take to find a fix.
3) Maybe, try the auto launch option. The AV windows seem to go overtop of the window to the program they see upon launch (Igo8). Note if it did display that information it would overlap the bottom of the screen where Primo has it's info bar.
4) That would depend on the skin and their aren't too many fro Primo 1.0, especially for 800x480 devices. When I started using Primo it was on my WiMo phone with it's tiny screen, and large signboards were required to view them properly. Perhaps that is the reason they are so large, because it was made for devices with smaller screens? Funny, I remember preferring to use my Phone for navigation over my AVIC just because I found Primo so user friendly. Anyways, look around and you may find a skin for Primo 1.2 that allows for smaller signboards.
On another note I see that there are versions of Primo 2.0 available here and there, with licensing issues unfortunately. I can't wait for a cracked version with 800x480 support :)
Posted Dec 23, 2011 · 11:14 UTC#237
So I tried it .... I do not have GPS signal ...
Posted Dec 23, 2011 · 13:36 UTC#238
My double start issue was caused by the voltage drop when I start my 4x4. I fixed it by running the main 12v wire (the yellow wire) from my aux battery (dual battery setup).
I went 4 wheel driving the other weekend and really liked the Oziexplorer maps, very helpful :)
The only thing I would like to change is the default igo program with the one from Diaftia's mod as it look better, but I think I read somewhere that it would be too much work to do???
Posted Dec 23, 2011 · 16:26 UTC#239
I would like to get the default as daftia's mod too, I agree that it looks better.
Posted Dec 23, 2011 · 19:29 UTC#240
Hi, this is on 800 * 480
http://www.4allmobil...p?f=107&t=40363 .....
Thanks Patper, I gave the Becker Active 50 a try a few weeks ago but found it too simple compaired to Primo. The version I am refering to is Go Cruise Primo 9.6.2.209584. Set your sys.txt GPS settings to port 6 and it will work.
Edited Dec 23, 2011 by ryar
Posted Dec 23, 2011 · 19:37 UTC#241
I believe some custom mods use more memory then others which could mean less for secondary programs such as Primo and OziExplorer, even if all the files in th ui_pioneer are set up to work on Diaftia's it may produce negative results. Hold on a bit, i'll up avicnet 2.1 one of these days when I get a change to finish translating it and whatnot, it has a custom mod preinstalled. It isn't Diaftia's but it is much nicer then stock.
Posted Dec 23, 2011 · 19:37 UTC#242
Oh - and I apologize... :oops:
Posted Dec 23, 2011 · 21:53 UTC#243
Hi, many thanks for really nice work. Everything works perfect after first setup. There are some minor bugs, but main system is nicely usable. I have only one feature request for now. Is it possible to add support for usb keyboard ? I tested my bluetooth keyboard and it partially works, but keymap is completely wrong :( I have to make some test's with wired keyboard in the near future.
Edited Dec 23, 2011 by timemaster
Posted Dec 23, 2011 · 23:08 UTC#244
ryar, It wouldn't even be bad if ig8 kept running in the background so long as the hardware Map button were set to control primo.
also, how do you populate the programs list in primo 1.0?
I'd love to add core player to the primo 1.0 programs list.
Posted Dec 24, 2011 · 04:04 UTC#245
No need to apologize my friend, thanks for the link! I didn't try it yet with native 800x480 support, just with a stretched lower resolution. I'll give it a go and add it to 2.1 when I upload it, it is newer and runs fairly smooth. By any chance did you find a cracked exe for 9.6.2.209584 on any Czech sites? I can't find anything on any English sites that I frequent.
Posted Dec 24, 2011 · 16:55 UTC#246
What would the kleyboard be used for, I cant that of any logical uses for it?
Posted Dec 24, 2011 · 21:31 UTC#247
Bluetooth keyboard with some direction keys might be good for internet browsing while driving (from passenger seat of course). Onscreen keyboard is not as accurate...
Of course, main reason is that I have one unused :)
Edited Dec 24, 2011 by timemaster
Posted Dec 25, 2011 · 23:00 UTC#248
I tested USB hub with two devices, CDMA modem AnyData and usb flash disk. Work's great together..
Posted Dec 26, 2011 · 19:52 UTC#249
:D Today, yes! http://www.4allmobil...p?f=107&t=40846
Edited Dec 26, 2011 by patper
Posted Dec 27, 2011 · 01:55 UTC#250
Great, I repacked it for avic with content folder from primo 1.2 and data.zip with support for avic resolution (800x480).. nice feature is online poi's for the first sight, I'm not sure whether this feature in older igo.
So it's ready for testing, someone from czech forum reported shutdown because out of memory after 15 minutes :( but don't know any details..
Here is it .. Primo 2 for avic [TESTING] :)
www.megaupload.com/?d=B1AJELOY
Edited Dec 27, 2011 by timemaster
Page 10 of 28
