AVICnet 2.1 for AVIC F series, working OBDII! Updated 2014/04/30
By ryar · Oct 19, 2011in Completed Mods/Themes💬 700 posts👁️ 270,055 views
Page 8 of 28
Posted Dec 03, 2011 · 17:58 UTC#176
If you go to the 1st link in post #19 there are directions on how to active the TomTom maps with your unit. Newer maps are always best!
Didn't spend much time on the OBD2 reader, FourG mentioned there may be driver issues. Depending on if you are in North America or Europe use the firmware in post #1. With an F900BT make sure to flash the firmware in post #3 (after flashing 3.0) to disable the gyro.
Thanks Ryar! One last thing, I was reading through the whole FX3.1 thread and just wanted to confirm if you upgrade WindowsCE on any avic it will use more free space of the internal 2gb? So is upgrading WindowsCE worth it, meaning is the upgrade of CE what is making the unit more responsive or is it the firmware which makes the unit better?
Posted Dec 03, 2011 · 18:58 UTC#177
It shouldn't take up much more space since you will only be flashing to a new winCE image. I think it would be a bit of both, a newer winCe and installing polished firmware (a custom mod) will help make your unit more responsive. You could take out all maps except areas you frequent, this will give you plenty of free space.
Edited Dec 03, 2011 by ryar
Posted Dec 04, 2011 · 03:24 UTC#178
Thanks Ryar! Was looking through the file and have been reading over the forum a lot, can any windows ce program be run as long as all the required files are in APL4? If not where did all these programs come from (Bubblets, Mastermind, Calc98CE, etc)? Looking into modifying and it seems like there are two ways to do it, LeetCoders way of doing where you run a self created version of the UI to run on windowsCE or the way it seems like most other mods are going is just changing/improving Pioneers UI, what are your thoughts? Really just trying to understand everything as most information is scattered through out different threads.
Posted Dec 04, 2011 · 20:17 UTC#179
Are there any Euro users who have working TMC?
Yes....
Posted Dec 04, 2011 · 20:58 UTC#180
Hi. I have an AVIC-F320BT unit.
Is this mod working on it ?
thx
Posted Dec 04, 2011 · 21:27 UTC#181
You can put the programs anywhere and they will run, most are in APL4 for consistency. I moved Primo to APL2 so it would share the maps with iGo8, for some reason when it was in APL4 it would not see the maps. Some programs are in the system folder as well. If you would like to add programs you can create an icon by taping AVICnet, settings, settings menu, programs (for example), and add. There you can select an icon for the program, and must fill in the program name and path. The path would be for example: \My Flash Disk\APL4\example\example.exe.
It seems that working around the stock iGo is the easiest, now that we know system memory can be freed up by killing the ezrider process starting from scratch doesn't seem to be a feasible option. LeetCoder was very creative and talented, too bad he stopped development some time ago.
Posted Dec 04, 2011 · 21:32 UTC#182
Yes....
Thanks, did you try Primo 1.0? If so is TMC working in that version? Odd how you have it working but other users are having difficulties. Thanks again for the upload.
thx
Sorry, no. Regarding Primo on your unit, Eam has a few posts near the end of the Primo thread but was having difficulties caused by his unit going into standby every 30 minutes. Maybe send him a PM and see if he has corrected the issue.
Posted Dec 05, 2011 · 06:25 UTC#183
Only 1.2 - post 151 ....
Posted Dec 05, 2011 · 11:31 UTC#184
I can confirm that TMC works in the Primo 1.2 from Patper running w/o Ezrider. My guess is that it's working only because the ezrider.exe process is stopped. I haven't found a way yet to dissable TMC in ezrider, changing comport still makes tmc work in ezrider... Maybe by dissabling tmc it will work in Primo or maybe the comport can be splitted????
Posted Dec 05, 2011 · 16:23 UTC#185
Could you explain how to use patper's primo 1.2? ? ie how to integrate it into avicnet?
Posted Dec 05, 2011 · 19:25 UTC#186
Download the file on post #151 --> here it is - http://www.edisk.cz/...r_137.56MB.html
Remove all Primo2 data en copy files into Primo2 folder
Thats it!
Posted Dec 05, 2011 · 22:41 UTC#187
I'm coming over from a diaftia mod with an auto installer...how do I access test mode?
Posted Dec 05, 2011 · 22:55 UTC#188
The Diafta mod has testmode in it. When you launch with diafta's mod on a sd card it takes you to a screen with a number of options (if the unit is US, EU, etc...) but at the bottom is a button that says CANCEL. If you press that you drop out into WinCE desktop.
Edited Dec 05, 2011 by palexr
Posted Dec 06, 2011 · 05:56 UTC#189
Really enjoying AVICnet so far, except for the double start but I'm working on a fix for that...
Just wondering if anybody knows where the settings would be found for the screen dim for when you turn your headlights on?
The original software and a some of the other mods still dimmed the screen when you turned your headlights on but AVICnet doesn't.
Posted Dec 06, 2011 · 08:43 UTC#190
The double start should only happen initially or after you boot into test mode; it is possible to disable but keep in mind it is loading many reg keys, ect which is what allow features such as making it more finger friendly in total commander by showing a lesser resolution, for example. Initially it booted WinCE into Russian but I changed it back to English.
My unit dims with the headlights fine, just set your screen brightness with them off and again with them on. It will remember your settings and dim accordingly.
Posted Dec 06, 2011 · 14:43 UTC#191
1. I want to change some names ("games", "programs", "Utilities", etc..) on the otherc (in my native language).
Where I find a file (and which) and how to edit? (some program name)
2. Is it possible to map to the navigation software (igo, garmin, TomTom, etc) read from SD or USB. Avic is low on internal memory, unfortunately,
Sorry for my English - I use a translator ;)
Posted Dec 06, 2011 · 16:54 UTC#192
With going of what sk4000 said is there a way to make this run purely off the SD card or USB drive?
Posted Dec 06, 2011 · 17:56 UTC#193
I have some older loq voices work with Primo 1.0, I will upload them shortly and put them in post #2 of this thread. I didn't particularly like the UK voices because it says "please" before every command. The less chatter the better IMHO.
To mute tap the top right icon on the map screen, and tap the speaker. That will mute/unmute.
I guess for me I only use Primo so the plain stock interface doesn't bother me, although the interface of the stock iGo may be slightly modded. After much searching I found a download of Avicnet 2.1 which seems to include a custom mod. Half of mine is still in Russian, I will translate the rest and share it here when I find some time. It probably won't be anytime in the near future though.
Go to settings and regional. There you can select units, ect. I believe I left the default to English US. I will upload the English UK voices to post #2 of this thread shortly.
To be honest I got this version of Primo from an Avicnet 2.1 package which I finally found. I am not sure if the .exe has been modified to load the proper dlls, ect or if it natively worked. I looked into modifying the Primo 1.2 .exe to load the required dlls but am way out of my league in preforming such a task. If anyone with knowledge on the subject can help I would be grateful! I noticed the Russian Avicnet threads have disappeared from 4pda.ru and most versions of 2.1 out there are .exe files which ask you to make a payment to unzip :( Too bad, I have a feeling there will be no more updates from the creators.
One more thing to mention, I finally received my OBDII to usb reader. Although it works perfectly on my laptop I cannot get my AVIC to work with it. I tried a few 3rd party programs as well as the included program with no luck :( It sees that it is plugged into port 8 but no program I have tried can recognize it. I am considering ordering an ODBII to bluetooth adapter and using a bluetooth dongle (avicnet has a bluetooth stack built in which allows dongles to work, mainly for bluetooth modems I am assuming), however I have read it the ODBII bluetooth drains the battery down quickly if it is left plugged in. I am suborn and don't give up easy however, xD and will keep give it another shot when I find some time.
Ryar I found this for check engine:
Setting up the USB connection
Connect the power adapter USB-ECU to the USB-port. And the computer will detect the adapter and will choose the driver to install.
If you connect your computer could not find the right driver and the adapter remains in the device list as "Unknown Device" - remove the AC adapter from the USB-port of the computer, install the adapter driver, USB-ECU, which is available at Download Site www.check-engine.ru. Then plug the adapter into the USB-port.
For the program Check-Engine with an adapter, the program must select the right COM-port. To determine which COM-port adapter, a connection is selected, go to My Computer> Properties> Hardware> Device Manager. In the list of devices, locate the "Ports (COM & LPT)". In the drop-down list should appear device USB Serial Port (COM X), where X - number of virtual COM-port. Select the program settings "Check-Engine" is the port.
So CheckEngine can select port 8 and should be able to work correct?
Posted Dec 06, 2011 · 17:57 UTC#194
I also often restart ...
Posted Dec 06, 2011 · 18:03 UTC#195
I found this in AppProperties.xml:
<COMPortPrefix>COM</COMPortPrefix>
<COMPortNo>1</COMPortNo>
Can you try switching it and see if it works? Would love to get this working.
Posted Dec 06, 2011 · 18:52 UTC#196
Let's just say that I was an idiot and deleted the Diaftia mod to load this on the SD card. What's the alternate way of entering testmode.
Thanks,
John
Posted Dec 07, 2011 · 13:42 UTC#198
Anything on bluetooth OBD connections?
Posted Dec 07, 2011 · 21:16 UTC#199
Thanks for the info. Here is where we are at with the OBDII: It seems the Russian check engine program only works with the module they sell, which is why it has been omitted in the Italian mod. While I can successfully connect my reader to other OBDII programs for PC, I cannot connect to Check Engine. In the settings you are promoted to enter the serial number for the OBDII reader. My reader is an ELM327 and there is no serial number present, which likely the reason the software will not connect.
There is other software for winCE OSBII readers, some specificly for the ELM327. No luck on any of the ones I tried as well. FourG mentioned back in post 160 and 162 that is is possibly a driver problem. I haven't tried playing with any drivers yet, I guess that is the next step.
I can confirm that the driver for Windows 7 on the Check-Engine website did the trick for my ELM327 on my PC. Hopefully the Windows CE driver from that site will work for my AVIC and OSBII. Now it is a matter of configuring the driver for the reader. I will post back with any news.
Posted Dec 07, 2011 · 21:19 UTC#200
Neither my F500BT nor F900BT do a double start except after booting to testmode or when initializing for the 1st time. I wonder if the problem is Vehicle specific due to a voltage drop when turning the engine over when starting?
Page 8 of 28
